The time now is Thu May 23, 2013 1:35 am
 Forum index » Featured Tools » CnC Editing Tools » SHP Shell Extension
Good IDEAS
Moderators: CnCVK
Post new topic   Reply to topic Page 1 of 1 [13 Posts] View previous topic :: View next topic
VK
PostPosted: Sun Jul 16, 2006 10:53 am    Post subject:   Good IDEAS
Subject description: Do you have any idea that will help SHP Shell Extension to become even better?
If anybody have good ideas post it here Smile
Siberian GRemlin
PostPosted: Sat Jul 22, 2006 2:13 pm    Post subject: Reply with quote
Extra Option:
Get from registry Install Path for TS and RA2, scan folders for MIX, scan MIX'es for palletes and finaly create palletes list. What you think about it?
Westwood Studios forever!
VK
PostPosted: Sat Jul 22, 2006 7:08 pm    Post subject: Reply with quote
Good idea but...
if install path is not correct Question
or I have 3 different copies of YR:)
And I need go to registry and rewrite InstallPath for FinalAlert, XCC Mixer every time Sad
Dupl3xxx
PostPosted: Fri Feb 23, 2007 3:13 pm    Post subject: Reply with quote
Sorry to bump, I know this project may be on ice, but make a controlable zoom. It would come in handy.
PostPosted: Fri Feb 23, 2007 4:09 pm    Post subject: Reply with quote
how about making it easy to uninstall
Wing Commander,
Phoenix Division
Chrisse
PostPosted: Fri Feb 23, 2007 10:43 pm    Post subject: Reply with quote
make it so you can just doubble click on the shp file instead of right click > properties, would bea lot faster
pd
Plasma Trooper
PostPosted: Sat Feb 24, 2007 7:50 am    Post subject: Reply with quote
that would mean making it a standalone program instead of a shell extension...
Move those shovels!
Bos187
PostPosted: Fri May 18, 2007 2:31 pm    Post subject: Reply with quote
Also be able to view shps that were uploaded to a site as attachments just like images are viewable like that?
VK
PostPosted: Fri May 18, 2007 5:21 pm    Post subject: Reply with quote
this is possible, but only for several browsers.
which support image filters or ActiveX controls, but, again, here palette-select-problem Sad
ARM forever - x86 sucks
Bos187
PostPosted: Sat May 19, 2007 4:28 pm    Post subject: Reply with quote
well i'm not very technical... so in simple language you're saying that if someone uploads a shp to a forum, i can see a preview with this extension, if i have the right browser, but theres some technical difficullties to it?
If so, which browsers does it support?
VK
PostPosted: Sun May 20, 2007 7:29 pm    Post subject: Reply with quote
At first, this isn't done.
For example IE support ActiveX, probably Opera.
BrianPrime
Shrapnel Sniper
PostPosted: Fri Aug 31, 2007 3:01 am    Post subject: Reply with quote
*Bump*
Make the preview window stretch for larger SHPs, rather than shrinking the SHP.
Bobingabout wrote:
I've got more naruto porn than furry porn
PostPosted: Fri Aug 31, 2007 2:41 pm    Post subject: Reply with quote
I believe that is not possible as the Properties dialog window size might not be editable. So the preview space is limited to the Properties dialog.
[ Time: 0.2439s ][ Queries: 13 (0.0512s) ][ Debug on ]
