The time now is Wed May 22, 2013 2:40 am
 Forum index » Featured Projects » The Dawn of the Tiberium Age » Maps
Sandpit
Moderators: The Dawn of the Tiberium Age Staff
Post new topic   Reply to topic Page 1 of 1 [11 Posts] View previous topic :: View next topic
ReFlex
PostPosted: Fri Apr 02, 2010 2:54 pm    Post subject:   Sandpit
Subject description: Small 2 Player Map
Another day another map...
Huge:
http://www.huizkistn.at/rumplkistn/maps/cnc2/dta/sandpit.jpg
Download:
http://www.huizkistn.at/rumplkistn/maps/cnc2/dta/sandpit.zip
SMIFFGIG
PostPosted: Fri Apr 02, 2010 3:08 pm    Post subject: Reply with quote
Looks bland and also only 2 tiny bridges leading to each base will inevitable lead to choke points and boring gameplay
I think you should allow some land access either side and also put more detail on the map
ReFlex
PostPosted: Fri Apr 02, 2010 4:02 pm    Post subject: Reply with quote
that is the point of the map.
PostPosted: Fri Apr 02, 2010 4:45 pm    Post subject: Reply with quote
Well I have to agree with Smiff, it's bland if anything. Looks like you left it unfinished.
PostPosted: Fri Apr 02, 2010 4:52 pm    Post subject: Reply with quote
The detail around the river area is fine, it's just the base areas that look really bland. Why doesn't anyone use the pebble set? #Tongue
PostPosted: Fri Apr 02, 2010 5:02 pm    Post subject: Reply with quote
You could also add some cliffs near the base area.
SMIFFGIG
PostPosted: Fri Apr 02, 2010 6:32 pm    Post subject: Reply with quote
Hmm ok if two tiny choke points is the idea in the map then fine, but i would edit the bottom tiberium area, as the top player can use long range units (especially in Enhanced Mode) to fire continually at harvesters. The top player will not have this problem as the tiberium does not go down that far Smile
but tbh i would add a land bridge either side too or in the middle (maybe a central tiberium field could be interesting?) but its totally up2 u
ReFlex
PostPosted: Mon Apr 05, 2010 1:36 pm    Post subject: Reply with quote
UPDATE!
Please reload...
PostPosted: Mon Apr 05, 2010 1:43 pm    Post subject: Reply with quote
MUCH better. Though the choke points remain...
PostPosted: Mon Apr 05, 2010 2:19 pm    Post subject: Reply with quote
That looks really good and well detailed.
I actually like the 2 choke points, but i can also see the point in adding some more land access.
How about making the map a lot wider to the left and right and then add far away on the east and west border a much bigger passage over the river. This way the player can decide if he wants to use the dangerous but near choke points or the much farther away but bigger passage.
You could this way also add some more tiberium fields as the one field for each player isn't very much.
TMP Shop
Much better indeed, although I do agree the choke points might make the map a bit annoying to play on.
Another thing I noticed (Toxic Passage has the same issue as well) is that in some places you placed too many impassable cells and in others places too few.
Just view one of DTA's original maps in marble madness mode and compare it with yours to see what I mean...
Also, destroyable terrain objects (these are always single trees) should never have impassable cells under them.
[ Time: 0.1045s ][ Queries: 10 (0.0250s) ][ Debug on ]
