The time now is Wed Jun 19, 2013 1:32 am
 Forum index » Featured Projects » Twisted Insurrection » Your Input
TI: Internal Errors (Report Them Here!)
Post new topic   Reply to topic Page 1 of 3 [101 Posts] View previous topic :: View next topic
PostPosted: Wed Aug 25, 2010 2:13 pm    Post subject:   TI: Internal Errors (Report Them Here!)
Subject description: This thread is for internal errors only, post feedback and bugs in a new topic.
This is the only topic here I don't want to see getting any replies. Hopefully there will be no Internal Errors, but if you do come across any, please upload the except.txt and logfile.txt here. A Description of what happened before the Internal Error occurred, what map and settings you had set would help us too.
If you receive an Internal Error upon loading a map, try setting GAME.EXE compatibility to Windows 98.
[CRIMSONUM]
IsAWuj=true
TheWhitestOfFangs
Vehicle Thief
PostPosted: Wed Aug 25, 2010 5:02 pm    Post subject: Exception Reply with quote
getting IE upon starting a game - any game.
Tried all possible competability modes.
Running WinXP 64bit (SP2)
except.txt
 Filename:  except.txt
 Filesize:  20.74 KB
 Downloaded:  239 Time(s)
PostPosted: Wed Aug 25, 2010 5:17 pm    Post subject: Reply with quote
Try re-installing. It could be a corrupt download.
[CRIMSONUM]
IsAWuj=true
Hassan_2030
PostPosted: Wed Aug 25, 2010 5:41 pm    Post subject: And here comes the next internal Error! Reply with quote
This error occurs everytime if I want to start a Game in TI!!!
Could you please help!?
except.txt
 Filesize:  20.74 KB
 Downloaded:  224 Time(s)
PostPosted: Wed Aug 25, 2010 5:42 pm    Post subject: Reply with quote
Did you remember to set the compatibility to Windows 98...?
[CRIMSONUM]
IsAWuj=true
Hassan_2030
PostPosted: Wed Aug 25, 2010 5:44 pm    Post subject: Reply with quote
I am using Win XP prof 32 bit!!!
Hijacking is the solution for every vehicle problem!!! If you need a vehicle just capture it!!!
TheWhitestOfFangs
Vehicle Thief
PostPosted: Wed Aug 25, 2010 5:45 pm    Post subject: Reply with quote
by "reinstalling" you mean re-extracting or downloading the rar again?
I'm downloading atm, however putting the files @ TS folder makes it run (although not too well - but i CAN get into the original campaign and such)
PostPosted: Wed Aug 25, 2010 5:48 pm    Post subject: Reply with quote
No, No, No. Listen. Right Click on TI's GAME.exe, then click on Properties, then click on the compatibility tab. In that section, select Windows 98 compatibility, make sure the box is ticked, apply and then try.
Re-downloading. Are you following the installation instructions properly? You don't need Tiberian Sun to run TI, it runs standalone...
[CRIMSONUM]
IsAWuj=true
Hassan_2030
PostPosted: Wed Aug 25, 2010 5:50 pm    Post subject: Reply with quote
Ok I got it!!! Very Happy
It works now Exclamation
Alex06
PostPosted: Thu Aug 26, 2010 12:14 am    Post subject: Reply with quote
What?! And here I was thinking I had to dig up my old TS CD and re-install... Very Happy
CnCSaga (DE) | CnCSaga (FR) | CNCNZ | Generals 2 Wiki
TheWhitestOfFangs
Vehicle Thief
PostPosted: Thu Aug 26, 2010 7:55 am    Post subject: Reply with quote
copied it to a WinXP 32bit computer and it worked with ease... download is fine and so is the mod - however it doesn't work on WinXP64...
Any chance you could help me out running this on my 64bit PC? (the other one is a laptop and it's screen is in a status where the game is simply too dark to see well)
P.S: the original TS runs smoothly on my system
JK-Terminator
PostPosted: Fri Aug 27, 2010 4:05 pm    Post subject:   Cannot play online. Reply with quote
I just can`t play online. I installed the files that come with tiberian sun but when I press OK, it gave me this error and yes I registered on XWIS.com
except.txt
 Filesize:  20.74 KB
 Downloaded:  217 Time(s)
PostPosted: Fri Aug 27, 2010 5:05 pm    Post subject: Reply with quote
Try downloading the online components from here instead. http://www.cnc-comm.com/community/index.php?action=downloads;sa=view;down=42
[CRIMSONUM]
IsAWuj=true
JK-Terminator
PostPosted: Fri Aug 27, 2010 6:59 pm    Post subject: Same. Reply with quote
It still give me the error but when I double clicked the registerWOL when I first installed it, it gave me this error message ( Uploaded image) but the second value succeded. I also re-included the except. Is there a way to add WOLAPI and WOL Browser manually ?
 Filesize:  157.27 KB
 Viewed:  11177 Time(s)
except.txt
 Filesize:  20.74 KB
 Downloaded:  202 Time(s)
PostPosted: Fri Aug 27, 2010 7:05 pm    Post subject: Reply with quote
Do you have administrator rights?
SHP Artist of Twisted Insurrection. Main Nod building SHP creator.
5 GDI, 5 Nod, 1 Mutant unit, 1 Scrin unit, 1 GDI building
TMP Shop
JK-Terminator
PostPosted: Fri Aug 27, 2010 7:32 pm    Post subject: Yes. Reply with quote
Yes I have administrator rights. I even tried run as administrator but when I try it the window loads and quits in a second.
PostPosted: Fri Aug 27, 2010 8:43 pm    Post subject: Reply with quote
Got this on Super Bridgehead Round II with 8 AI players (Level 2) after about 30 minutes of gameplay.
Seems to be a rare error, I've played multiple 6-player skirmishes to end without any IEs in this build.
except.txt
 Filesize:  20.74 KB
 Downloaded:  223 Time(s)
TI.txt
 Filename:  TI.txt
 Filesize:  301.09 KB
 Downloaded:  219 Time(s)
Tore
PostPosted: Fri Aug 27, 2010 9:30 pm    Post subject: Reply with quote
XWIS.com doesn't exist. You don't have to register anywhere to play TS online, just type in a username and 8 character long password.
and did you try my Westwood Shared Internet Components installer?
JK-Terminator
PostPosted: Sat Aug 28, 2010 6:15 am    Post subject: Yes. Reply with quote
Yes I installed your components but it keeps giving me that stupid error that`s in the picture. Oh and sorry it was XWIS.net. Here`s the website : http://xwis.net/
daTS
Mr. Moosey
PostPosted: Sat Aug 28, 2010 8:02 am    Post subject: Reply with quote
i get the same thing... and my LAN just flat doesnt work. :/
"Reality is a lovely place, but I wouldn't want to live there."
-Adam Young
View user's profile Send private message Send e-mail Visit poster's website AIM Address MSN Messenger
PostPosted: Sat Aug 28, 2010 8:12 am    Post subject: Reply with quote
I've never seen that error ever occur before with TI or any other C&C. Confused Revert things back to normal and arrange games on Hamachi LAN instead, at least until I figure out what causes that.
[CRIMSONUM]
IsAWuj=true
daTS
Mr. Moosey
PostPosted: Sat Aug 28, 2010 8:28 am    Post subject: Reply with quote
i click LAN and nothing happens. :/
-Adam Young
PostPosted: Sat Aug 28, 2010 8:30 am    Post subject: Reply with quote
I've had and fixed that problem before, but I can't for the life of me remember how. When I next catch you on MSN, I'll give you a walk-through to try and get XWIS working.
[CRIMSONUM]
IsAWuj=true
Tore
PostPosted: Sat Aug 28, 2010 10:38 am    Post subject: Re: Yes. Reply with quote
Why are you using registerWOL.bat with my installer? That will screw up the installation of a working shared internet components install. -_-
Hell, my installer doesn't even come with registerWOL.bat because it already registers the components in the registry!
Ordosherrscher
PostPosted: Sat Aug 28, 2010 11:03 am    Post subject: Reply with quote
And TI is a standalone, right? And it get fucked up if you copy it into a folder where you had a vanilla game, right? Wasnt there something like that?
Think of me as Nordos, 'cause Banshee wouldn't rename me
JK-Terminator
PostPosted: Sat Aug 28, 2010 11:08 am    Post subject: Re: Yes. Reply with quote
Actually that`s the internet folder that came with Tiberian Sun. Plus it would just be plain stupid if I did that.
Tore
PostPosted: Sat Aug 28, 2010 12:07 pm    Post subject: Re: Yes. Reply with quote
Then what have you done?
My installer doesn't give errors like that.
As for registering them manually open up registerWOL.bat with notepad and check there.
JK-Terminator
PostPosted: Sat Aug 28, 2010 1:09 pm    Post subject: Ok. Reply with quote
Guys it`s ok now. I managed to fix it. It turns out the problem was with Windows Vista having User Account Control on. If anyone else has Vista and cannot connect to the XWIS server has to turn off User Account Control and re-register the .dll files.
Tore
PostPosted: Sat Aug 28, 2010 1:49 pm    Post subject: Reply with quote
Or you could just use the "Run as administrator" button. Wink
JK-Terminator
PostPosted: Sat Aug 28, 2010 2:28 pm    Post subject: Reply with quote
Actually that didn`t work. It just would quit in a split second but still it`s working now.
PostPosted: Tue Aug 31, 2010 1:52 am    Post subject: test Reply with quote
Playing GDI on bay of Pigs, didn't get far ingame til IE.
except.txt
 Filesize:  20.74 KB
 Downloaded:  212 Time(s)
TheWhitestOfFangs
Vehicle Thief
PostPosted: Wed Sep 01, 2010 7:44 pm    Post subject: Reply with quote
Hey,
Still no luck running it on my WinXP64bit, any chance you'll have a look at it? (.txt attached before)
PostPosted: Wed Sep 01, 2010 8:32 pm    Post subject: Reply with quote
That's obviously the compatibility problem. If none of the compat modes allows you to start a game, i fear you have to find a solution yourself or wait until another winXP64 user gives the answer.
Once we fixed the compat problem at all, it might also fix your problem.
btw, can you play vanilla TS or does it give you an IE too?
TMP Shop
TheWhitestOfFangs
Vehicle Thief
PostPosted: Fri Sep 03, 2010 9:39 am    Post subject: Reply with quote
As I've mentioned earlier - Vanilla works without a glitch
PostPosted: Fri Sep 03, 2010 2:17 pm    Post subject: Reply with quote
These exceptions are getting annoying, most skirmishes end in an IE again (I know it's a beta though).
5 Level 2 AI's on Pig of Bays. It's probably my tenth unfinished game on this map.
TI.txt
 Filename:  TI.txt
 Filesize:  184.9 KB
 Downloaded:  210 Time(s)
except.txt
 Filesize:  20.74 KB
 Downloaded:  252 Time(s)
PostPosted: Fri Sep 03, 2010 2:57 pm    Post subject: Reply with quote
This is again the same EIP 004D2451 which you had before and is already known for a while to us. Though one of our the exe hackers hasn't yet deciphered the cause for this EIP.
TMP Shop
Barawusch
PostPosted: Fri Sep 03, 2010 5:54 pm    Post subject: Reply with quote
Hello,
first off all, yeah, I set compatibility to Windows 98 / ME, and it's used as a stand alone Wink
Trying to start any game leads to the following procedure:
When reaching "gathering theorie on likely enemy plan" task manager shows that the process is freezing for a short periode (3 secs, sometimes Cool.
Then it springs to "secondary check on combat zone" (or somethin' like this) - and shows the internal error.
Seems some access-violation, but I'm affraid I've got no idea how to help it.
Thaks for your help Smile
PS: Windows XP 32, tried on both admin and normal.
Edit: TI-Log has a bit more substance ^^
TI.txt
 Filename:  TI.txt
 Filesize:  7.79 KB
 Downloaded:  199 Time(s)
except.txt
 Filesize:  20.74 KB
 Downloaded:  185 Time(s)
Barawusch
PostPosted: Sun Sep 05, 2010 3:25 pm    Post subject: Reply with quote
It's now sorted out, but I'm still clueless why that happened.
The games must have communicated with the registry (not possible^^), or would have been corrupted by an rules.ini in the backup-folder on drive C (quite impossible as well).
Well, I have no idea how to read these Logs, so if you are interested in the cause as well, would be happy to hear what really happened.
Although it's no more a must, cause (as standing above) the problem is now solved.
Have a nice day,
Bara(wusch)
PostPosted: Sun Sep 05, 2010 9:42 pm    Post subject: Reply with quote
well, in except.txt, the most important part is this line:
Exception occurred at 00451C16
That 00451C16 is the address of the instruction that went wrong, so the disassembler guys can look up in which game function that piece of code is located.
The other text file seems to be a log file, so they don't only see where it went wrong, but also in which context that function was called at that moment.
daviperdragon
PostPosted: Fri Sep 17, 2010 2:29 am    Post subject: Reply with quote
Cant get past any of the load screens with out an IE.
file enclosed.
except.txt
 Filesize:  20.74 KB
 Downloaded:  193 Time(s)
Total Annihilation is the only battle strategy.
my Moddb.com account
Ordosherrscher
PostPosted: Fri Sep 17, 2010 6:21 am    Post subject: Reply with quote
Did you set the compatibility mode?
3 - Once Extracted, open the TI Public Beta 1 Folder and Set GAME.exe compatibility to Windows 98 (IMPORTANT!)
daviperdragon
PostPosted: Tue Sep 28, 2010 12:01 am    Post subject: Reply with quote
never mind, had to re-install the patch to fix the issue.
ooo111
PostPosted: Fri Feb 04, 2011 1:41 am    Post subject: Exception Reply with quote
Map: Omicron City
Starting loc: Button Left
my Faction: GDI
AI Faction: N/A
- Trying to select my kazuar
except.txt
 Filesize:  20.74 KB
 Downloaded:  139 Time(s)
logfile.txt
 Filename:  logfile.txt
 Filesize:  35.65 KB
 Downloaded:  148 Time(s)
PostPosted: Sun Feb 13, 2011 9:45 pm    Post subject: Reply with quote
ooo111 : Drawing a shape on the screen. Would not know where to begin.
ooo111
PostPosted: Sun Feb 13, 2011 11:28 pm    Post subject: Reply with quote
@CCHyper
How do I "draw a shape on the screen ?....
screenshots ?
PostPosted: Mon Feb 14, 2011 2:42 am    Post subject: Reply with quote
I meant, the game crashed when drawing a shape object (unit artwork).
ooo111
PostPosted: Tue Feb 15, 2011 10:33 pm    Post subject: How can I help... Reply with quote
@CCHyper
How can i help with it ?
Only mass one unit and see if that unit can fail ?
PostPosted: Tue Feb 15, 2011 11:24 pm    Post subject: Reply with quote
Can not really help, its 99.9% that this was random, unless this same error occurs every game.
TiberFCSL
PostPosted: Sun Feb 27, 2011 12:00 am    Post subject: Reply with quote
Map: Omicron City
Sides: GDI vs GDI (just me against one AI)
They were attacking me but I don't remember any more than that.
I noticed something strange, the Hov-vee wasn't available, instead there was a Nod Attack Cycle icon that gives me a humb-vee that fires rockets.
except.txt
 Filesize:  20.59 KB
 Downloaded:  127 Time(s)
New missions coming soon!
Download the latest beta: http://www.moddb.com/mods/cc-tiberian-sun-tech-level-war
PostPosted: Sun Feb 27, 2011 7:19 am    Post subject: Reply with quote
The Hum-vee replaces Hov-vee in maps with Ion Storms.
Post new topic   Reply to topic Page 1 of 3 [101 Posts] Goto page: 1, 2, 3 Next
[ Time: 0.8906s ][ Queries: 13 (0.0402s) ][ Debug on ]
