The time now is Fri May 24, 2013 8:50 pm
 Forum index » Modding Central » Media Hut » 3D Models
Marder IFV
Moderators: Global Moderators, Media Hut Moderators
Post new topic   Reply to topic Page 1 of 1 [11 Posts] View previous topic :: View next topic
The-Light
PostPosted: Sat Jul 30, 2011 12:14 pm    Post subject:   Marder IFV
Subject description: public w3d
One German Marder IFV public w3d model.
Notes:
-high poly 750-800 (still within generals range though)
-comes with draw code
-normal + damaged model + textures
-small: the model is made using generals engine scale, this means you'll have to add " Scale = 1.2" to the units code in generals for more generals styled scale.
Constructive Critisism is welcome, other critisism not, for it is useless.
Marder IFV preview
 Filesize:  512.39 KB
 Viewed:  1837 Time(s)
MarderIFV.zip
A rar with the files, to open use winrar or similar.
 Filename:  MarderIFV.zip
 Filesize:  863.47 KB
 Downloaded:  145 Time(s)
PostPosted: Sat Jul 30, 2011 4:05 pm    Post subject: Reply with quote
It's hard too see where you spend all those polies on Confused From the looks of it I could remake it with about half the amount of polies and it would still look the same.
The-Light
PostPosted: Sat Jul 30, 2011 6:10 pm    Post subject: Reply with quote
Count about 16 wheels, then a 175 poly hull, and yes i know i'm not poly efficient. I was happy enough with getting to learn texturing by myself.
This means that i actually used polys for where i could have used texture, like on the hatches, wheels, holes in the side armor.
I'm getting better, see the abrams, it has around fourhundrend polys.
The problem for me really is that i can't help but having to put more detail in it. 2 years ago i used to make miniture cars (scale 1 to 160) which had loose wheels and opening doors, that's a 2,5 cm car from paper with opening doors a steering wheel, and wheels. I can't help but adding detail :S
But I'll see if i can make it less poly efficient.
Two question though:
-do you know how to get a transparent texture? been messing with it for idunno 5 hours? and still can't get it to work.
-any idea how the thread texture can get to move?
PostPosted: Sat Jul 30, 2011 7:54 pm    Post subject: Reply with quote
Replace the tracks with a block to save a massive amount of polies. Besides, the wheels won't be usable ingame anyway, as the engine isn't build for that (nor are the TW and RA3 engines).
Madin
PostPosted: Sun Jul 31, 2011 12:28 am    Post subject: Reply with quote
Not true (at least on the C&C3 front, I couldn't care less about RA3).
PostPosted: Sun Jul 31, 2011 4:22 pm    Post subject: Reply with quote
I always assumed all TW vehicles that use tracks have solid tracks, as in blocks. The only game I can quickly think of that has actual moving wheels in the tracks is Company of Heroes.
FurryQueen
PostPosted: Sun Jul 31, 2011 9:50 pm    Post subject: Reply with quote
Then you've clearly not seen Shockwave. I'm 99 percent sure they have moving tracks and all that funky jazz.
Ponies are awesome.
PostPosted: Mon Aug 01, 2011 4:48 pm    Post subject: Reply with quote
Moving tracks as in: a block with an animated texture, which is coded into the game to animate when the vehicle moves. That is how all tracked vehicles in Generals do this. The only other option are turning wheels, as seen on the Humvee or SCUD Launcher.
What I meant is having AND an track that animates when the vehicle moves AND turning wheels inside the tracks, as Company of Heroes has in example. As I mentioned before, normally Generals' tracks are blocks with an animated texture, and not both animated tracks and turning wheels. The engine simply doesn't support it, and I'm almost 100% sure that TW and RA3 don't support that either. The reason for that is simple: it saves a hell lot of polies. Having a block with an animated texture, or having both the tracks and all the seperate wheels, which need to turn as well.
EVA-251
PostPosted: Mon Aug 01, 2011 8:36 pm    Post subject: Reply with quote
What Dutchy is trying to describe is a working suspension for the vehicles. CNC-3 and RA3 allow articulated bodies but that's the best you'll get.
If you want a functioning suspension, World in Conflict and Company of Heroes feature it (WiC's implementation better compared to CoH's, which is much too springy and makes vehicles seem too tall)
Kinda not modding anymore.
RIP Star Strike 2005-2012
RIP RA1.5 2009-2012
RIP Z-Mod 2008-2012
PostPosted: Tue Aug 02, 2011 4:29 pm    Post subject: Reply with quote
I blame my lack of certain English terms for that. Thanks for explaining what I meant Wink
The-Light
PostPosted: Sat Aug 06, 2011 8:52 am    Post subject: Reply with quote
I just heard a good idea: deforming blocks.
And well yes it might be better using blocks than wheels.
There's one ZH mod doing it different however, which is Cold War Crises, although it's still technically blocks, but with flat wheels attached to the side.
Ya know the reason i actually tried this is the rotten suspension on tracks in ZH, wheels do a lot better, but I'll find something different.
[ Time: 0.0737s ][ Queries: 16 (0.0108s) ][ Debug on ]
