The time now is Fri Apr 19, 2024 6:08 am
GDI Fourth Challenge mission
Post new topic   Reply to topic Page 1 of 1 [4 Posts] Mark the topic unread ::  View previous topic :: View next topic
Bu7loos
PostPosted: Wed Oct 26, 2011 10:54 am    Post subject:  GDI Fourth Challenge mission Reply with quote  Mark this post and the followings unread
In this challenge mission it's you vs Nod forces (they don't know your here) but expect patrols to come your way. The mission is a good old find and destroy the Temeple of Nod, there is a timer you have 1 hour to do so and reinforcement are very limited. I'll put this mission for download today so stay tuned... BTW I'm confused where do I modify global lights in triggers or Rules.INI? Confused
 Filesize:  249.68 KB
 Viewed:  2475 Time(s)
 Filesize:  139.96 KB
 Filesize:  256.09 KB
GDI Challenge mission 4.rar
 Filename:  GDI Challenge mission 4.rar
 Filesize:  71.09 KB
 Downloaded:  162 Time(s)
PostPosted: Wed Oct 26, 2011 11:29 am    Post subject: Reply with quote  Mark this post and the followings unread
GDI barracks' new foundation is 3x3, I suggest you add more room for that.
When you click Edit->INI editing, you can edit all sorts of rules.ini-related settings, but only for the map. As for changing lighting via triggers, if you go to Map Tools -> Tool Scripts, you can select and run one of the "change lighting to X" or "add-day-night-loop" triggers, and use them as an example.
Bu7loos
PostPosted: Wed Oct 26, 2011 1:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Crimsonum, dont worry I'll make room for the barracks.
Bu7loos
PostPosted: Wed Oct 26, 2011 4:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok challenge mission ready, I've added the download to the first post, have fun also need feedback please. Very Happy
[ Time: 0.1931s ][ Queries: 16 (0.0114s) ][ Debug on ]
