Posted: Wed May 19, 2010 12:10 pm Post subject:
Getting Movies into Generals
I just tombled upon this while searching more useful modding programs and thought this might be useful for other modders as well.
Maybe some of you already wanted to add your own video to Generals but found that generals used Bik files, than this "Tutorial" will show you how to get your video into a ,Bik format.
How To make your movie:
Simply use Movie maker or another program, or record part of a scirmish with a recording program like AutoScreenRecorder.
Now we have our movie and RAD Video Tools, RAD Video Tools can open quite a substantial ammount of file types, so lets assume the movie is in an openable format. Now what we do is opening the file with RAD Video Tools, you'll be presented with a screen similar to that in the picture. I put a red circle around the Bik button, pressing that button opens up a new screen in which you can adjust some settings.
The seccond screen I've also added, I also marked with red the converter button so it'll be easy to find. Pressing that button closes this screen and opens another, that screen shows the progress of convertion. Converting a movie or video takes quite a lot of time, when having one minute of film, then ten minutes of converting time is a reasonable guess.
For people who don't like reading, here the story in short:
1 make/get a video/movie
2 Get RAD Video Tools
3 Open the movie/video with RAD Video Tools
4 Press the "Bink it" button
5 Press the "Bink" button, and wait till it's converted.
6 Name your new .bik file after the filename of the video you wish to repace, or... open up GameData.ini and edit the name of the intro movie to match yours.
looking at their FAQ http://www.radgametools.com/binkfaq.htm tells me bink uses stuf from other applications: "The RAD Video Tools uses QuickTime to import compressed sound formats." however without having quicktime(at least i never told to install it), just vlc at home it still works.
Hmm, i'm not very fond of quicktime, but do you have it installed? I'll also check if i have it home(just to be sure) to before advising to install it.
Note: my dislike of quicktime mainly comes from my liking of vlc, and the anoying way apple software update tries to install iTunes and Safari with it(where i dislike iTunes for it being slow on my system). QUICK_EDIT
I do have Quicktime.. at least, a quick search through my programs says I do.
I've run through their FAQ before, and I couldn't find anything to solve my problem. I've run it as Adminstrator, I've given full permissions to the formats I've tried.
I'm really stumped on this issue, and may just have to find someone to "Bink" Them for me, since, for whatever reason, I can't get it to work. -_-; _________________ QUICK_EDIT
Searching through google tells me more people have this problem, and especially on windows 7. Now i used to run it on windows 7 without problem, strange.
I have a friend with windows 7 64bit, but there it does work, the problem with disfunctional software is it's always annoying to find the cause.
Next step would be to try and let bink think it's running on windows XP, try compatibility(right click the exe -> properties -> compatibilty select Windows XP), if that doesn't work then i'm starting to run out of idea's :S
For ultimate solutions there are 2:
-asking at their helpdesk, which i'll do when it isn't solved soon.
-i'll convert them for you. QUICK_EDIT
