The time now is Fri May 24, 2013 12:35 am
 Forum index » Modding Central » Red Alert 2 Editing Forum » Tutorials Vault
[ARES] Recreating the Fleajump/Jumpjet Ability
Post new topic   Reply to topic Page 1 of 1 [14 Posts] View previous topic :: View next topic
PostPosted: Thu May 31, 2012 3:33 am    Post subject:   [ARES] Recreating the Fleajump/Jumpjet Ability
Subject description: From RA3/KW
Using Ares we can now recreate these 2 Abilities from the newer games. For this tutorial I will be using the Terror Drone.
First we need to create a new dummy unit which acts as the jump zone of the terror drone.
; ArmorTypes Section introduced by Ares
[ArmorTypes]
PounceMe=light
; New Warhead for Jumping around
Verses=0%,0%,0%,0%,0%,0%,0%,0%,0%,0%,0%
Versus.PounceMe=100%
Versus.PounceMe.ForceFire=yes
Versus.PounceMe.PassiveAcquire=no
Versus.PounceMe.Retaliate=no
Parasite=yes
Rocker=yes
InfDeath=1
Then we'll need to create a superweapon for which to create the jump marker unit.
[FleaJumpSpecial]
UIName=NOSTR:Flea Jump
Type=UnitDelivery
Action=UnitDelivery
Deliver.Types=JUMPBEACON ; Up to you...
ShowTimer=no
DisablefromShell=no
SidebarImage=XXXXX ; Up to you...
RechargeTime=.1
FlashSidebarTabFrames=0
IsPowered=false
SW.Sound=XXXXX ; Up to you...
SW.AITargeting=none
Next will be the Beacon Unit...
[b]Vehicle Version:[/b] (I assume its going to be a SHP)
;Drone Beacon
[DRONBEACON]
UIName=NOSTR:Drone Beacon
Name=Drone Beacon
Prerequisite=NAWEAP
Category=AFV
Strength=80
Armor=PounceMe
Parasiteable=yes
Primary=BeaconWep
AttackFriendlies=yes
CanPassiveAquire=yes
OpportunityFire=yes
CanMobileFire=yes
GuardRange=255
DefaultToGuardArea=yes
OmnicrushResistant=yes
Crusher=no
TechLevel=-1
Sight=3
Speed=3
CrateGoodie=no
Owner=Russians
AllowedToStartInMultiplayer=no
Cost=500
Soylent=500
Turret=no
Points=5
ROT=40
Crewed=no
Explosion=JUMPEXPL
VoiceSelect=TargetPaint
VoiceMove=TargetPaint
VoiceAttack=
VoiceFeedback=
DieSound=
Locomotor={4A582741-9839-11d1-B709-00A024DDAFD1}
MovementZone=Normal
ThreatPosed=0   ; This value MUST be 0 for all building addons
Insignificant=yes
ImmunetoRadiation=yes
ImmunetoPsionics=yes
ImmunetoPoison=yes
IdleRate=1
Size=15
IsSelectableCombatant=yes
DamageSelf=yes
Now comes the Jump Projectile & Weapon for the Terror Drone, which it will use to simulate jumping in the air. The Weapon must be set as the Primary to work properly.
; Imma hoppin' hoppin'
[DroneHop]
Damage=80 ;This ensures it kills the Dummy Unit.
ROF=120
Range=14 ; To be certain I can jump over cliffs
Projectile=DRONHOP
Speed=10
Warhead=DroneHopWH
LimboLaunch=yes
Report=TerrorDroneAttack
[DRONHOP]
Image=DRONP
Shadow=yes
Ranged=yes
AA=no
AG=yes
Arcing=true
Lobber=yes
FirersPalette=yes
SubjectToClifs=no
SubjectToElevation=no
SubjectToWalls=no
Level=no
;Beacon Weapon
[BeaconWep]
Damage=8
Range=-2
ROF=90
AreaFire=yes
OmniFire=yes
Projectile=InvisibleAll
Warhead=DroneBeaconWH
AffectsEnemies=no
Report=DUMMY
[BeaconWH]
CellSpread=.5
Wall=yes
Wood=yes
PercentAtMax=1
Verses=100%,100%,100%,100%,100%,100%,100%,100%,100%,100%,100%
AffectsAllies=yes
AffectsEnemies=yes
Conventional=yes
InfDeath=0
One more note... You will need to put this bit of information on every other Warhead aside from DroneHop & on the weapon the Beacon uses to damage itself.
And finally some tweaks to the Original Terror Drone...
For the Terror Drone we removed its Virtual Scanner and replaced that with Guard Range which achieves the same effect.
; Terror Drone,  ooohhh scary
[DRON]
UIName=Name:DRON
Name=Terror Drone
Category=AFV
Prerequisite=NAWEAP
Primary=DroneJump
Secondary=DroneHop
NavalTargeting=6
IsSimpleDeployer=yes
DeployingAnim=DUMMY
UnloadingClass=JUMPDRON
DeployFire=yes
Deployer=yes
Strength=100
SuppressionThreshold=5; damage below this amount won't suppress the parasite
ReselectIfLimboed=yes ; If selected when limbo on attack of infantry, reselect when unlimbo
DefaultToGuardArea=yes ; the much awaited terror drone default to move and attack when resting
GuardRange=5
Armor=special_1
TechLevel=4
Turret=no
IsTilter=no
CrateGoodie=no
Sight=4
Speed=10 ; gs Don't go higher than 20, or he gets stuck running in circles
Owner=Russians,Confederation,Arabs
Cost=500
Soylent=500
Points=20
ROT=40
Crusher=no
Crewed=no
Explosion=TWLT070,S_BANG48,S_BRNL58,S_CLSN58,S_TUMU60
VoiceSelect=TerrorDroneSelect
VoiceAttack=TerrorDroneAttackCommand
VoiceMove=TerrorDroneMove
VoiceFeedback=
DieSound=TerrorDroneDie
MoveSound=TerrorDroneMoveLoop
MaxDebris=2
Locomotor={4A582741-9839-11d1-B709-00A024DDAFD1};<drive>{55D141B8-DB94-11d1-AC98-006008055BB5}
MovementZone=Destroyer
ThreatPosed=25   ; This value MUST be 0 for all building addons
DamageParticleSystems=SparkSys,SmallGreySSys
Weight=.5
ImmuneToPsionics=yes
ImmuneToRadiation=yes
Parasiteable=no
Explodes=no
AccelerationFactor=5 ; really fast
DeaccelerationFactor=5 ; This is TS's mizspelingg knot min
ZFudgeColumn=8
ZFudgeTunnel=13
Size=2
Accelerates=false
Trainable=yes
VeteranAbilities=STRONGER,FIREPOWER,SIGHT,FASTER
EliteAbilities=SELF_HEAL,STRONGER,FIREPOWER,ROF
SelfHealing=yes
Bunkerable=no; Units default to yes, others default to no
;Dummy Jump Drone
[JUMPDRON]
Image=DRON
UIName=Name:DRON
Name=Terror Drone
Category=AFV
Prerequisite=NAWEAP
Primary=DroneJump
Secondary=DroneHop
NavalTargeting=6
Strength=100
UnloadingClass=DRON
Deployer=yes
GuardRange=5
Armor=special_1
TechLevel=-1
Turret=no
IsTilter=no
CrateGoodie=no
Sight=4
Cost=500
Soylent=500
Points=20
ROT=40
Crusher=no
Crewed=no
VoiceFeedback=
MaxDebris=2
Weight=.5
Parasiteable=no
Explodes=no
DeaccelerationFactor=5 ; This is TS's mizspeling knot min
ZFudgeColumn=8
ZFudgeTunnel=13
Size=2
Accelerates=false
Trainable=yes
SelfHealing=yes
The New Terror Drone can now jump over to selected beacons. Though it requires alot of micromanagement.
1) Place Beacon
2) Select Drone
3) Deploy Drone
4) Force Fire on Beacon
5) Undeploy Drone
And viola... you can now have flea jumping terror drones to further cause headaches to your enemies. Very Happy
This can also be used as a work around for a Chrono Tank-Style Unit by giving the Jumping Weapon infinite range(Probably InvisibleAll Projectile & 100 Speed with Turboboost=yes) and changing the death animations of the Beacon Unit into the appropriate Chrono Smoke.
~~~Stay calm & be one with Yuri~~~
You can call me Jem if my Username is too long.
~Peace through Ponies
Last edited by Atomic_Noodles on Wed Sep 05, 2012 11:50 pm; edited 2 times in total
ArvinCool
PostPosted: Mon Jun 04, 2012 1:09 am    Post subject: Reply with quote
Nice.
A possible bug is if the drone have an other target while placing the beacon.
Why is TurretSpins used?
And when the drone is "jumping", I assume it just travel in a straight line rather than move upwards like Lobber=yes would do?
"I'll be staying strapped cuse my mac-eleven make my nuts bigger"
PostPosted: Mon Jun 04, 2012 1:23 am    Post subject: Reply with quote
ArvinCool wrote:
Nice.
I've tried putting Lobber yes but it pretty much just flies toward the target like other missile style projectiles.
TurretSpins=yes is for if your using a Voxel VehicleType Dummy Target. Though I prefer Infantry more since they aren't hardcoded to explode.
Banshee mentions in the News Thread you can also allow area damage. This can be achieved by giving the dummy target unit a deathweapon that has AffectsEnemies=no. on its Warhead. In this case, a VehicleType is much preferred as it already has a "explosion" effect to simulate shellshock explosion.
Location: Iszkaszentgyorgy, Hungary ... silly php update broke accented locations -_-
PostPosted: Mon Jun 04, 2012 6:56 am    Post subject: Reply with quote
Infantry can explode too. It's just that they use DeathAnims instead of Explosion.
Orac wrote:
Any opinions you get from here will be honest, because so far nobody has really cared enough to lie to avoid hurting your feelings.
RP wrote:
I like this guy, that Graion Dilach. He seems to know one or two things about people. Mister Dilach can identify a moron in less than five posts!
PostPosted: Mon Jun 04, 2012 12:59 pm    Post subject: Reply with quote
Yeah that's what I'm trying to point out. VehicleTypes are hardcoded to explode where as Infantry don't. So unless your planning on not using an "exploding jump" you could use Infantry. Smile
Starkku
Tiberian Fiend
PostPosted: Mon Jun 04, 2012 1:32 pm    Post subject: Reply with quote
No, they are not hardcoded to do anything like that. The explosion animation(s) used for VehicleTypes, AircraftTypes & BuildingTypes is specified by Explosion, which takes comma-separated list of animation ID's. Game plays one explosion animation per each cell taken by the object in question (always 1 with vehicles & aircraft), picked randomly(?) from the list. You can omit Explosion all together if you don't want vehicles to show explosion animations when destroyed.
Additional explosions can be added through DeathWeapon, which itself required Explodes flag to be set to true to work. This one also works with InfantryTypes, of course.
PostPosted: Tue Jun 05, 2012 5:34 pm    Post subject: Reply with quote
Oh my God. Flea Jumping in RA2? How far we've come to put in all of these crazy abilities nobody would've dreamed about ten years ago. Now the challenge is to find a good use for it without cloning the Sickle.
That said, there isn't a gif is there? I want to see this. Lol.
ArvinCool
PostPosted: Tue Jun 05, 2012 6:20 pm    Post subject: Reply with quote
Pic isint needed. It looks like a terror drone with a longer range really.
Its also difficult to implement this, we would need a 32 frame rotation of a unit.
PostPosted: Tue Jun 05, 2012 9:34 pm    Post subject: Reply with quote
Plus IMO using a SW makes it just too annoying to use ingame, I imagine.
PostPosted: Wed Jun 06, 2012 1:13 am    Post subject: Reply with quote
Some people might not like lots of micromanaging so its not for everyone.
Well you could get away by just making 4 copies of each frame.
PostPosted: Wed Jun 06, 2012 1:47 pm    Post subject: Reply with quote
he should have said it the other way round.
"Infantry are hardcoded to ignore the Explosion key." Wink
SHP Artist of Twisted Insurrection. Main Nod building SHP creator.
5 GDI, 5 Nod, 1 Mutant unit, 1 Scrin unit, 1 GDI building
TMP Shop
PostPosted: Wed Sep 05, 2012 11:52 pm    Post subject: Reply with quote
Updated the Tutorial. Now only uses a Vehicle Dummy Unit exclusively.
I've had problems with the Custom ArmorType but changing the Drone into a SimpleDeployer seems to work for it. Though this means yet another step for the big micromanagement already... Confused
NimoStar
PostPosted: Wed Nov 14, 2012 10:09 pm    Post subject: Reply with quote
Infantry can explode (at least in Ares RA2YR) if you use Explodes=yes and a DeathWeapon... they just don't use a "explosions" lists but this can be put on the DeathWeapon Warhead code.
PostPosted: Wed Nov 14, 2012 10:17 pm    Post subject: Reply with quote
Yeah, because it uses DeathAnims instead of Explosions... which has the sideeffect of overriding all death animations.
[ Time: 0.2028s ][ Queries: 10 (0.0303s) ][ Debug on ]
