The time now is Thu Apr 18, 2024 7:29 am
Bug/Glitch
Post new topic   Reply to topic Page 1 of 1 [12 Posts] Mark the topic unread ::  View previous topic :: View next topic
Lopunny777
PostPosted: Mon Dec 24, 2012 9:39 pm    Post subject:  Bug/Glitch
Subject description: menu visualizations
When i try to navigate through the menus or open them the screen freezes and then i have to minimize then reenter to see the new menus or options but ingame its fine. The problem is i cant see the options at all in skirmish or the maps i chose because the screen wont read it. I cant even see the bar changed when i set game speed, difficulty, faction or anything uness i minimize and go back in. Can someone help me out...the launcher wont let me fix it?
PostPosted: Mon Dec 24, 2012 9:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nordos
PostPosted: Mon Dec 24, 2012 10:50 pm    Post subject: Re: Bug/Glitch Reply with quote  Mark this post and the followings unread
I had the same issue.
I'm playing on a laptop, and noticed a strange thing - whenever I didn't had power supply, the menu workes as it should! I checked what would be that different, and finally found it: I had two graphiccards and the one, which got activated with power supply, didn't work with TS.
Maybe it helps you, too - the gracca may be incomaptible
So, yeah, I've created a new acc. 'cause no one could remember Ordosherrscher - and I didn't like that name anyway.
PostPosted: Mon Dec 24, 2012 11:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
PostPosted: Tue Dec 25, 2012 12:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Whoops indeed. I forgot PB4 introduced the launcher and still remembered the PB3 layout. Laughing
Lopunny777
PostPosted: Tue Dec 25, 2012 2:26 am    Post subject: Reply with quote  Mark this post and the followings unread
on the screen resolution screen i click detect but literally nothing happens...i have windows 7 btw
PostPosted: Tue Dec 25, 2012 10:20 am    Post subject: Reply with quote  Mark this post and the followings unread
What kind of System do you have? (Which GPU and which drivers)
Try updating your GraCa drivers.
PostPosted: Tue Dec 25, 2012 12:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
I assume an Intel. That's known to do such and if I'm right, no driver update can fix that. -_-
That's why that tool exists. RA2 menu also generates this thing.
Lopunny777
PostPosted: Mon Aug 05, 2013 8:13 pm    Post subject: Still not fixed menu freeze Reply with quote  Mark this post and the followings unread
seriously...does anyone have a fix...i want to play this game again badly...but i cant because of this...i thought the update would fix this...makes me wonder if the game needs to be scrapped and redone on a newer Cnc game so its compatible
PostPosted: Mon Aug 05, 2013 8:31 pm    Post subject: Re: Still not fixed menu freeze Reply with quote  Mark this post and the followings unread
More like Intel needs to fix their graphics drivers since the game works perfectly on Nvidia and AMD graphics processing units. Unfortunately the staff cannot do anything to fix Intel's drivers.
PostPosted: Mon Aug 05, 2013 8:42 pm    Post subject: Re: Still not fixed menu freeze Reply with quote  Mark this post and the followings unread
There's no driver fix AFAIK. If you have multiple GPUs, force the game to use the other GPU instead of the Intel GPU. If you don't have any other GPUs, use LH_Mouse's fix. Graion already gave you the link for the fix at the top of this post. LH_Mouse, not Machine. If it still doesn't work, then too bad for you.
Glukv48
PostPosted: Sun Aug 11, 2013 3:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
I propose a different (universal) way to solve this problem. I made a small package based on WineD3D and utilities MoveToTray. Just unzip the files in a folder with the game.
To start the game, use the run.bat. I configured it to run ra2md.exe, if you want to use this tool with RA2 or TS, then you have to replace 'ra2md.exe' run.bat in the corresponding *.exe file
WineD3D does not allow minimizing the game the classical way (Win or Alt+Tab). Therefore, in order to minimize the game, use the keyboard shortcut Ctrl+Alt+M. The game will be minimized to the system tray.
Edit: Also, it can take an adventure video mode at 16 bit color. In Windows8 it can be done in a setting compatibility ra2md.exe.
DDraw.dll_for_menu_bug.rar
 Filename:  DDraw.dll_for_menu_bug.rar
 Filesize:  730.61 KB
 Downloaded:  61 Time(s)
[ Time: 0.1660s ][ Queries: 13 (0.0105s) ][ Debug on ]
