hi, i just joined the forum but have quiet a lot of rules ini experiance....i am helping another guy at the mo but if you want toshell some light work to me i'd be happy to help! QUICK_EDIT
Ok so what is needed for cocding in this I hav basically no idea wats in general's real since I never really looked into it. _________________
All hail me
QUICK_EDIT
check here - http://www.cncden.com/gen_units.shtml that's all the units with a brief description, you can also view the structure, upgrades and exp. upgrades from there too.
Also i have begun construction of a temporary website to use as propaganda (and before you all reach for your quotes i know i said that it could wait but i had a change of mind), and if any of you know of a very easy to install news script (or one of you would be able to install a news script to the site (when it's up)) please tell me. Thanks. QUICK_EDIT
Ok well this isn't gonna be easy but I will do the best just because I wanna game with the F-22 which just happens to be my fav plane. I'll start work tommorow coding the individual unit's.(I'd do it tonight but everyone in my house want's the comp for one worthless thing or another . So I'll just eat all of the fudgesicle's and not share . QUICK_EDIT
T34 sam can you begin work on the construction dozer for the usa i've attached a pic below. Technofreak, can you help hellfire with coding the units into the game, you can start with the toxin tractor that i made earlier (it's around here somewhere) if one of you does the art.ini and one does the rules.ini (you decide but i guess it'll be whoever reads this first gets first choice) and i will begin work on the Humvee and ambulance VXL's.
The construction dozer is effecrively the new MCV so code it as one for now, we'll work on the advanced options later.
EXCELLENT!!! yes we will be doing maps as well, are you offering? Also if you could do the same for GLA and china cameos that would be brilliant (provided you want to, otherwise i'll do them). QUICK_EDIT
ok, great. i should have a new voxel for you soon, i d/l a humvee voxel from RESCEN (yes i will be including credit to the maker) which i am modifying to make the Humvee unit. QUICK_EDIT
Posted: Sun Feb 02, 2003 4:59 pm Post subject:
I'm doing them now. And I'd like to do the maps as well. Plus I can doini and SHPs. _________________
I'm here....what am i coding for? can i have some unit specs......hellfire get me on msn! Last edited by tecnofreak on Sat Apr 23, 2011 11:34 pm; edited 1 time in total QUICK_EDIT
Tratos: Leader, voxel maker, cameo maker.
Hellfire: Ini coder.
T-34 Sam: Voxel maker
Clazzy: Cameo maker, map maker
tecnofreak: Ini coder
One Of a Kind: Ini coder. Last edited by Banshee on Tue Feb 04, 2003 12:40 pm; edited 2 times in total QUICK_EDIT
I just formated my HD so I'll be inactive until I get kazaa back so I can DL a key gen for everything since I happened to lose all of mine. _________________
All hail me
QUICK_EDIT
K I'm mostly bac online with the exception of Firestorm which is not needed for this so it doesn't really matter. I will finish coding the american unit's tommorow. I already have most of the infantry, just need to work out a few bug's in the air craft's and tank's. _________________
All hail me
QUICK_EDIT
ok, well i've already coded in the rangers (im using the seal image), the pathfinder (currently using the sniper but that should change if we can find someone good at editing infantry SHP's) and the humvee, also Col. Burton but i've run into trouble with him. He was working fine, he had a huge chaingun that ripped through infantry AND TANKS (though not as fast as a rocket but still pretty quickly), but now everytime i try to build him i get the message "Red Alert 2 has encountered an internal error and is unable to continue functioning normally" i haven't got a clue what's gone wrong, i can post the code on here if it helps and someone can check to see if i have anything in there that shouldn't be there. QUICK_EDIT
Only real problem I've had with the infantry was the ranger since it's ability to take over building's is an upgrade but I just gave it straight to him. Wat did u do to get the camoflouge effect to go. _________________
All hail me
QUICK_EDIT
The ranger doesn't have the camoflage only the pathfinder and Burton, i'm going to use cloaking like in TS only without any sort of uncloak and decloak sound and it only works when they stop moving. I think the code is
Ya that wat I'm using. Also I never really gave any of them new image's just codes existing unit's to be like them. I'll start on the tank's after I eat something(Got the day off school again due to snow.) _________________
All hail me
QUICK_EDIT
hmmmmm.....and yes i know about the elite weapons i'm sorting it but it's quite hard to balance when his chaingun does 600 damage and is anti-infantry normally. QUICK_EDIT
well u could just remove the elite weapon's completely it isn't needed really. Also my work will be delay'ed since I use Tibed for most of my work and it isn't working for some reason. _________________
All hail me
QUICK_EDIT
could you try and code in the refinery for China, it can look like the service depot (soviet) for the moment but the crane should move when the harvester unloads at it. And i'll work on the new harvester voxel. QUICK_EDIT
If u'r really wanting to help u could do the tank's since I'm out at the moment, and can't do it.
Also on a lil off-topic doe's anyone hav an e-mail address for ATI, I need to complain before I break someone form the anger I am experiancing from there BEEPING website, and BEEPING costumer service. _________________
All hail me
QUICK_EDIT
tratos delete the line
Occupier=no ; I can Occupy UC buildings
it isn't used instead go to the tesla troop and get the one that says i clearout uc building _________________ Life is but a mere battle in easy mode on generals... hey that last china mission was hard! QUICK_EDIT
