The time now is Wed May 22, 2013 9:34 am
 Forum index » Modding Central » Tiberian Sun Editing Forum
Hamachi tutorial and General LAN setups
Post new topic   Reply to topic Page 1 of 1 [44 Posts] View previous topic :: View next topic
Judeau
PostPosted: Sat Oct 22, 2005 9:21 am    Post subject:   Hamachi tutorial and General LAN setups Reply with quote
I have edited this post and quoted Fenring's tutorial how to play LAN game matches via Hamachi. Scroll to the bottom of this post if you have Vista or Windows 7. Thanks to Tony for this find. ~DonutArnold
Unlike Judeau's, the images will actually be here! #Tongue
Bear in mind this is for Windows XP since Windows Vista and higher deprecated the IPX protocol. After some testing, m666 and I have determined that the RA2/TS LAN Patch does not work.
Install Hamachi. The latest version of it fixes the IPX protocol so no old versions are necessary; if this proves to be a misnomer, use version 1.0.1.1.
! The following works as good practice for standard LAN play but instead of Hamachi, use your main Local Area or Wireless Connection !
Open the Network Connections panel. You can either right click on My Network Places > Properties or go Start > Settings > Network Connections.
Either way, you should have something similar to this;
Now we need to install the protocol.
Right click Hamachi and select Properties and you will see this;
As the arrow indicates, click Install.
Then this screen will show;
Highlight Protocol and click Add.
The "Select Network Protocol" box will appear.
As the arrows indicate, highlight NWLink IPX/SPX/NetBIOS Compatible Transport Protocol and then click OK.
Then you will go back to the Hamachi properties main dialog.
The new protocol should be in the list; highlight the NWLink IPX/SPX/NetBIOS Protocol and click Properties.
The properties will appear and you will have several options.
Disregard the Internal Network number. It has no effect and should not be touched; set the Frame Type to Ethernet 802.2; then set the Network number to 00000001. Then click OK.
Windows will likely ask you to reboot, which you need to do.
If Windows does not ask, reboot anyway.
Enter your game of choice - Tiberian Sun, Red Alert 2 or their expansions and go Options > Network. In the network card slot, set it to the card that shows 00 00 00 01 : xx xx xx xx.
Make sure you have a Hamachi channel/network and your players are connected before attempting to play a game.
Then hit the Network lobby and you should be good to go.
Some people still play on Windows 98, I know, I did up until two years ago. For those of you still running that archaic system, fear not! Wink
Firstly, Hamachi does not work on Windows 98/SE or ME. So that's already out but you can easily play a LAN game on it.
First, we need to install the IPX/SPX Protocol as we did before but it's a little different.
You need to open the Network properties, which you can do by right clicking Network Neighborhood > Properties or by going Start > Settings > Control Panel > Network.
However method, you'll get this;
As before, click Add to bring up Network Component Types install dialog box.
As the arrow indicates, highlight Protocol and click Add.
This is where things differ from Windows XP.
There is a box on the right with a list of choices, mine shows four but you need to highlight Microsoft, then IPX/SPX-Compatible Protocol and then click OK.
You will be brought back to the Network dialog once again.
In my sample, I have chosen the Dial-Up Adapter but this is where you choose your required network device - your network/Ethernet card. Then click Properties.
Your particular device's properties will appear.
As in the image, go to the NetBIOS tab and tick the box if it is not already.
Click over to your Advanced tab and you will see the main screen available.
As the arrows indicate, highlight the Frame Type and set it as Ethernet 802.2 as before.
Highlight Network Address and put in 1 instead of 0.
Click to the Bindings tab to ensure that NetBIOS is bound to that IPX/SPX connection and then click OK.
As with Windows XP, Windows will ask you to reboot, which you must do.
If it does not, reboot anyway.
Then attempt a LAN game.
If issues persist, let me know and I will look more into it.
Vista and 7 fix:
The following steps are the least you'll need to do in order to play most games:
How the metrics and the Hamachi properties should look like in Vista.
1. After installing Hamachi, run it once and insure you've configured your firewall properly and have set port forwarding on your router(s) (if you have one).
2. Re-prioritize your network adapter order:
For XP/2000: Start > Control Panel > Network Connections, then, on the menu bar, click Advanced > Advanced Settings and put Hamachi at the top of the list.
For Vista: Start > Control Panel > Network and Sharing Center, then, on the left side panel, click on 'Manage Network Connections'. Now press Alt, click on Advanced > Advanced Settings and put Hamachi at the top of the list.
For Windows 7: Start > Control Panel > Network and Sharing Center, then, on the left side panel, click on 'Change adapter settings'. Now press Alt, click on Advanced > Advanced Settings and put Hamachi at the top of the list.
3. Configure the gateway and metrics:
In Network Connections right click on Hamachi > Properties, select TCP/IP(v4) > Properties > Advanced. Ensure that the default gateway is 5.0.0.1, if not, then add/edit it and set its metric to Automatic (this is the Gateway Metric).
Below 'Default gateways' tick 'Automatic metric' (this is the Interface Metric).
Quick notice: Some users have reported that their internet connection fails when Hamachi is turned on. Removing the Hamachi gateway (5.0.0.1) should resolve the problem. It is not known why this is happening, but it might be the ISP's fault. Entering a Gateway Metric manually (for example, the default "1500") can restore the internet connection, but gaming functionality may still not be available.
4. If you're running Vista disable TCP/IPv6 (untick it in the Hamachi properties)
5. If you're running Vista ensure that Hamachi appears in the 'Network and Sharing Center' as a 'Private Network' .
If it doesn't, then press customize (at Hamachi, of course) and set it to 'Private Network'.
6. Reboot.
7. Create/Join a Hamachi network and check to see if you can ping/chat with one another. If either one of these don't work ensure you haven't forgotten anything and check again. Still not working? check section 3.1 and 3.2 of the 'Advanced Guide' below.
8. The game host must be running Vista when playing with XP users!
For those who want know where to find this and to view the advanced guide:
logmeinwiki.com
Micro TS
Portable, no campaign, movies or music, just the engine and needed resources for skirmish and lan.
PostPosted: Sat Oct 22, 2005 8:05 pm    Post subject: Reply with quote
In your Hamachi settings, disable "File and Printer Sharing for Microsoft Windows" to prevent people from getting access to shared stuff on your PC.
No one likes to get a ton of paper spit out of his printer with junk from someone halfway across the globe #Tongue
If you have problems chatting or connecting to a game while you DO see eachother in the lobby, and you have only one network card option in the TS network options, go to the Hamachi settings, open the settings of the IPX protocol and change the "Internal Network Number" to 00000001.
Press OK, then press OK again to enable the new settings. Then, open it again and change it back to 00000000. Oddly enough, that seems to fix the problem.
Clazzy
Karma Police
PostPosted: Sat Oct 22, 2005 8:39 pm    Post subject: Reply with quote
Hmm, there's a Linux port as well. Do you think this would allow for multiplayer TS to work through Linux? You see, shared internet components don't work on Linux.
This is sexier than what this forum was supposed to tolerate. - Banshee
PostPosted: Sat Oct 22, 2005 8:48 pm    Post subject: Reply with quote
WINE normally takes care of all network stuff... so it should be possible.
Clazzy
Karma Police
PostPosted: Sat Oct 22, 2005 9:19 pm    Post subject: Reply with quote
You wouldn't possibly know how to configure IPX would you, Nyer?
Von Kriplespac
PostPosted: Sat Oct 22, 2005 9:34 pm    Post subject: Reply with quote
BTW, when you install, MAKE SURE to restart your PC, or its going to _NOT_ work correctly. #Tongue Learned that the hard way.
PostPosted: Sun Oct 23, 2005 8:49 am    Post subject: Reply with quote
And then you pretended to rebootbut really didn't and whinedd some more Rolling Eyes
Anyway, not for Linux Alkov. Linux never needs reboots, not even if you update Linux itself to a next version. In Linux, you could do the equivalent of upgrading Win98 to WinXP without needing a single reboot #Tongue
In linux/Wine? Not a freaking clue. But from what I've heard from other people, RA1 seems to have no problems with network stuff on Linux.
Clazzy
Karma Police
PostPosted: Sun Oct 23, 2005 12:54 pm    Post subject: Reply with quote
Erm, a kernel upgrade requires a reboot.
PostPosted: Sun Oct 23, 2005 8:57 pm    Post subject: Reply with quote
no it doesn't... I've done it in my Gentoo. auto-update with Emerge, and it just does it all. No reboot necessary
oh wait... right. You do need to reboot to actually USE the new Kernel. But not to install it :p
PostPosted: Fri Oct 28, 2005 7:40 am    Post subject: Reply with quote
For RA1, join this network:
password: RAForever
Wink
If you use FullRA, make sure you DO install the 3.03 patch, and DON'T add the INI files.
Judeau
PostPosted: Sun Oct 30, 2005 9:14 am    Post subject: Reply with quote
the tutorial has been updated with some relevant stuff
Micro TS
Judeau
PostPosted: Fri Aug 25, 2006 7:46 pm    Post subject: Reply with quote
bump for ye lazy ones
Micro TS
Titan
Location: the Netherlands Posts: -Access Denied- BuildConst: -Operational- -Target Acquired-
PostPosted: Fri Aug 25, 2006 9:20 pm    Post subject: Reply with quote
Sticky!
PostPosted: Fri Aug 25, 2006 10:06 pm    Post subject: Reply with quote
Sticky!
It appears it is now.
Jenkins
Vehicle Thief
PostPosted: Mon May 14, 2007 1:07 am    Post subject: Reply with quote
OFF TOPIC-NESS!! What mod do you have running in the background? It looks interesting and it might be what you are talking about. If it is, then call me an idiot. (Sorry, I didn't & obviously put a lot of time into reading your descriptions.) Your descriptions are very good though. I will (when I have the time) come back for them.
Thanks!
Peace through power, Power through untiy, Unity through the Brotherhood, The Brotherhood of Nod
View user's profile Send private message Send e-mail Yahoo Messenger
m666
PostPosted: Sat May 19, 2007 11:48 pm    Post subject: Reply with quote
Jenkins, get off our forum if you're too lazy to read, which is EXACTLY what you do on forums.
To EVERYONE ELSE! Hamachi version 1.0.2.1 has an IPX bug! In order for your YR, RA2, or TS to work online, you need to dig up and download Hamachi 1.0.1.5 for a fixed Hamachi network experience.
Judeau SHOULD update this sooner or later, but I'll keep posted on this issue and it's resolution.
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
Team Black
PostPosted: Sat Jun 09, 2007 7:40 pm    Post subject: Reply with quote
BTW you can find all the versions of hamachi here
"Good thing you paid attention in chemistry, sir", stated McGormly
"Don't kid yourself LT, I don't know what the hell any of this stuff really is", admitted Price
-Attack on Hammerfest
Judeau
PostPosted: Mon Aug 13, 2007 8:43 pm    Post subject: Reply with quote
tutorial updated, it was desperately needed.
Micro TS
phoenixankit
PostPosted: Mon Oct 15, 2007 10:32 am    Post subject: Reply with quote
What do you mean by
fire up hamachi now, follow it's tutorial, and once done, Join the network "TS-Network" with the password "none"
What tutorial?
And If I want to create my own network, then after creating, my friend just joins it, and then we open the game, go to LAN(or whatever it is) and we should see each other there?
Judeau
PostPosted: Sun Oct 21, 2007 4:42 pm    Post subject: Reply with quote
phoenixankit wrote:
What do you mean by
What tutorial?
hamachi has a small in-built tutorial on how to use it.
well, follow THIS tutorial, and you should be able to see each other once you are on the same network.
Micro TS
PostPosted: Sat Dec 01, 2007 5:00 pm    Post subject: Reply with quote
The IPX bug has been fixed see http://hamachi.cc/changes for more details
Wing Commander,
Phoenix Division
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger MSN Messenger
Judeau
PostPosted: Sun Dec 02, 2007 5:24 pm    Post subject: Reply with quote
no dice, last time we tested that it failed.
Micro TS
PostPosted: Mon Dec 03, 2007 5:27 pm    Post subject: Reply with quote
when was it last tested new version just came out yesterday
Wing Commander,
Phoenix Division
m666
PostPosted: Mon Dec 03, 2007 9:43 pm    Post subject: Reply with quote
* Added Korean translation
* Fixed a problem of automatic update on Vista
* Fixed a bug with double-clicking on the peer status indicator
* Fixed a bug with opening network chat window using a systray
notifcation
* Minor cosmetic UI changes
Never mentioned at all, unless you backtrack to 1.0.2.3. I also tested this new version, and got the same result as Judeau. Also; check on these things before randomly posting, some of us value Hamachi quite a bit. Wink
Hemlig
GDI Hacker
PostPosted: Wed Dec 26, 2007 3:16 pm    Post subject: Reply with quote
This one is good to, for RA2/YR
http://logmeinwiki.com/wiki/Hamachi:Red_Alert_2
IcySon55
PostPosted: Thu Dec 27, 2007 7:20 am    Post subject: Reply with quote
You must be blind if you didn't notice that setting this up for both games is EXACTLY the same...
Team Black
PostPosted: Mon Sep 22, 2008 4:56 pm    Post subject: Reply with quote
Judeau, your pictures don't seem to be showing anymore - might be time for another update?
PostPosted: Sun Oct 19, 2008 3:08 pm    Post subject: Reply with quote
I know this is a major bump, but has anyone find a solution for this so Vista users can play TS online too?
Revolutionary
Location: Scotland, starting a Revolution Cameo: metricon. Posts:???
PostPosted: Sun Oct 19, 2008 3:24 pm    Post subject: Reply with quote
do you have the lan patch?
Creator of TS:BoB and some other things that might be good when finnished.
PostPosted: Sun Oct 19, 2008 3:54 pm    Post subject: Reply with quote
AFAIK, lan =/= online, so no...
Revolutionary
PostPosted: Sun Oct 19, 2008 3:56 pm    Post subject: Reply with quote
it worked for me if it dosent fix it try the Xwis wedsite
PostPosted: Sun Oct 19, 2008 8:24 pm    Post subject: Reply with quote
yes look for the UDP patch I believe there is a page referencing it on medenc.
EDIT Uploaded it for you
ts_ra2_lanpatch_1_00.zip
put the dll in your sun/ra2 folder
 Filename:  ts_ra2_lanpatch_1_00.zip
 Filesize:  23.18 KB
 Downloaded:  682 Time(s)
Wing Commander,
Phoenix Division
PostPosted: Mon Oct 20, 2008 1:27 pm    Post subject: Reply with quote
I'll try it when I've got some more time. Still thanks for the file Wink
EDIT: ok, when I try to start the game, it doesn't work: it gives an error and it quits Confused
PostPosted: Mon Oct 20, 2008 6:56 pm    Post subject: Reply with quote
thats odd your the first I've heard about that problem.
Wing Commander,
Phoenix Division
Revolutionary
PostPosted: Mon Oct 20, 2008 6:57 pm    Post subject: Reply with quote
Question have you patched the game you with any 3rd party patches or any other 3rd party software(eg no cd cracks)
PostPosted: Tue Oct 21, 2008 1:30 pm    Post subject: Reply with quote
I'm using TI, which uses a custom exe. Maybe that's the problem? Also, it must work with TI, because I don't play original TS online Wink
Revolutionary
PostPosted: Tue Oct 21, 2008 1:40 pm    Post subject: Reply with quote
id try it with out the mod to see if it works then if it dose work wothout the mod then try it with
PostPosted: Thu May 28, 2009 8:54 pm    Post subject: Reply with quote
Another bump, the UDP patch does NOT work for RA2. I tested this throughly.
PostPosted: Thu May 28, 2009 8:59 pm    Post subject: Reply with quote
Judeau, please update the images above. I want to kick Team Black's ass on TI Online. Razz
"Aro is the entire universe" - Gangster
Dark Templar X
PostPosted: Thu May 28, 2009 9:29 pm    Post subject: Reply with quote
It's not hard to set up without images.
PostPosted: Thu May 28, 2009 11:05 pm    Post subject: Reply with quote
It is for people like me who know nothing about Hamachi.
Dark Templar X
PostPosted: Fri May 29, 2009 1:05 am    Post subject: Reply with quote
It has nothing to do with Hamachi; it has to do with Windows and connections. It's still not hard to do.
Though I agree, he should get the images back on the thread.
PostPosted: Fri May 29, 2009 1:09 am    Post subject: Reply with quote
If you want me to keep doing your requests you should stop trying to make me look stupid. #Tongue
Dark Templar X
PostPosted: Fri May 29, 2009 6:36 am    Post subject: Reply with quote
More information and new tutorial posted here.
http://www.ppmsite.com/forum/viewtopic.php?t=23456
[ Time: 0.6228s ][ Queries: 12 (0.0473s) ][ Debug on ]
