The time now is Thu Apr 25, 2024 3:37 am
SHP Shell Extension: The BETA #4 available NOW
Moderators: CnCVK
Post new topic   Reply to topic Page 1 of 1 [23 Posts] Mark the topic unread ::  View previous topic :: View next topic
VK
Pyro Sniper
PostPosted: Fri Aug 25, 2006 6:41 am    Post subject:  SHP Shell Extension: The BETA #4 available NOW
Subject description: Support TD and RA files now!
This version support TD and RA SHP files Exclamation
Also now you can see frame type:
for TD/RA 80,40,20
for TS/RA2/YR Compressed or not
 Filesize:  43.12 KB
 Viewed:  80183 Time(s)
 Filesize:  32.57 KB
 Viewed:  80182 Time(s)
 Filesize:  67.32 KB
SHPShellExtSetup_1_04.zip
 Filename:  SHPShellExtSetup_1_04.zip
 Filesize:  185.42 KB
 Downloaded:  3276 Time(s)
ARM forever - x86 sucks
ChielScape
PostPosted: Fri Aug 25, 2006 6:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
it rocks. great suff VK!
VK
Pyro Sniper
PostPosted: Sat Aug 26, 2006 9:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Now I think to add saving palette name for each file Smile
ChielScape
PostPosted: Sat Aug 26, 2006 10:26 am    Post subject: Reply with quote  Mark this post and the followings unread
not a voxel shell extension?
stucuk
Geek
PostPosted: Sat Aug 26, 2006 12:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Voxels are VXL, this is a SHP Shell Extention, not a VXL Shell Extention.
Free Map Editor - Game Requirements - Stucuk.Net
ChielScape
PostPosted: Sat Aug 26, 2006 2:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
oh, i really didnt know that! [/sarcasm]
thats exactly what im asking for!
VK
Pyro Sniper
PostPosted: Sat Aug 26, 2006 8:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
But I think about... MIX SHELL EXTENSION!
Which allow edit/view files in mixs as usual folder Smile
PostPosted: Sat Aug 26, 2006 9:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
That would own. But mix is very complicated.
I'm unable to understand Olaf Van Der Spek's code #Tongue
Siberian GRemlin
PostPosted: Sun Aug 27, 2006 4:03 am    Post subject: Reply with quote  Mark this post and the followings unread
How about a CPS and WSA shell extension? Or may be rename SHP Shell Extension into Westwood Graphics Shell Extension...
Westwood Studios forever!
VK
Pyro Sniper
PostPosted: Sun Aug 27, 2006 10:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Can be. CPS is simple, but WSA... Kyrandia, C&C,... different formats.
Yes. But I not want to use Olaf Van Der Spek's code Exclamation
I get information directly from EXE Very Happy
stucuk
Geek
PostPosted: Sun Aug 27, 2006 11:38 am    Post subject: Reply with quote  Mark this post and the followings unread
You asked if its a voxel shell extention. If you format your questions properly then you actualy get the responce you desired.
Examples:
Can you add an ability to use voxels with this
Can you make one for voxels
Etc.
BTW you need a [sarcasum] at the start, just having an ending one sorta ruins it.
You can't get everything from the EXE. You need to know how Olaf does his or you WON'T be able to get the names of the files in custom mix files for example. You would also be best to 'nick' his list of Mix filenames or you will have to spend a while working them all out. Mix files store a HEX as in ID, it stores NO filenames. (Filenames are basicaly converted into a HEX)
There is also blowfish encryption on encrypted ones (which afaik is every mix file in TS and RA2, and every mix in YR except one.) so you need to know how to handle blowfish or u won't get anywhere.
ChielScape
PostPosted: Sun Aug 27, 2006 12:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
it was a reaction to this:
so, instead of a saving palette name, a VXL Shell Extension.
MIX Extension is a good idea!
care considdering a .max/.3ds one? (for later)
stucuk
Geek
PostPosted: Sun Aug 27, 2006 1:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
I know what u were replying to and what u ment. But u still never asked what u ment.
ChielScape
PostPosted: Sun Aug 27, 2006 2:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
no offence, but from your spelling i conclude you just might have not really understood it at the moment. not sure...
[offtopic] hey, you just need 5 more posts! [/offtopic]
stucuk
Geek
PostPosted: Sun Aug 27, 2006 7:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes i do not spell all words correctly, iv never been a good speller. I was even taken into a 'shit spellers' class for a while. But spelling doesn't matter. The brain can work out what word the person means as long as the start and end letters are there and the word is the correct length. (obvacly it has to contain most of the correct letters)
What does matter is how you phrase your words, otherwise ppl do not understand what you are asking. If they don't know what you are asking they will be much less likly to respond to you, or respond to you with an answer you desire.
So far for example iv seen noone reply to your VXL Suggestion which is proberly due to how u phrased it. Spelling means nothing.
VK
Pyro Sniper
PostPosted: Sun Aug 27, 2006 8:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
You don't know me...
I disassemble GAMEMD.EXE during two years:)
I found String -> ID function already in EXE.
I know it Smile
It's very stupid idea: store file names into 'nick' list Sad
It's easy... using BlowFish.DLL Very Happy
stucuk
Geek
PostPosted: Sun Aug 27, 2006 11:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well if u don't use the list Olaf made you will have to convert every name of every file used in TS/RA2/YR etc. Since otherwise all the users would see is a Hex ID.
Also you would need to support how XCC does custom Mix files. (as in how it stores the filenames)
Which is why you can't get everything from the EXE as it doesn't hold all the answers.
Siberian GRemlin
PostPosted: Mon Aug 28, 2006 8:33 am    Post subject: Reply with quote  Mark this post and the followings unread
All standart ID->filenames can be stored in global database, for custom mixes may be created local databese located in same folder with mix file, like that:
mymix.mix - custom mix
mymix.ini - local filenames databese for mymix.mix
All filenames for global databese getting from EXE's...
What you think about this idea? May be you have yourself ideas? =)
VK
Pyro Sniper
PostPosted: Mon Aug 28, 2006 2:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
I talk about code.
I try to write IDtoStr which convert ID to file name back Very Happy
It's difficult, but possible Smile
stucuk
Geek
PostPosted: Mon Aug 28, 2006 3:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Its imposible. You can't convert back when u loose data.
'Your' ideas are basicaly what Olaf did b4 u had any ideas. Olaf uses a global database and he stores a list of the filenames INSIDE the Mix file.
You can't get the filenames off of the EXE, not all of them anyway, the ini files in the mix files also reference names for example.
I talk about code.
I talk about the whole thing. As in making a program thats compatible with the current mods which use custom mix files as well as the normal TS/Ra2/YR ones.
Siberian GRemlin
PostPosted: Mon Aug 28, 2006 4:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Put junk in mix is stupid!
I agree, it's may be possible. I researched this problem, but making of solution is very hard!
stucuk
Geek
PostPosted: Mon Aug 28, 2006 5:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Its not junk and its better than storeing it externaly. Its much better for users than having 2 files to have to deal with. Since its the EXACT same information its stupid to say 'your' way is any way better than doing it how Olaf does it. His way makes it much less likly for users to screw things up b4 eather forgetting to have the ini file in the same dir, some ppl could play with it screwing things up etc.
Also i never said what u quoted, CNC Did.
VK
Pyro Sniper
PostPosted: Mon Aug 28, 2006 8:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's imposible. You can't convert back when u loose data.
No. Forget about stupid method?
Enumerate all names and check all IDs? (But very slow)
However I found something interesting things Smile
[ Time: 0.2540s ][ Queries: 16 (0.0120s) ][ Debug on ]
