The time now is Sat May 25, 2013 2:31 pm
 Forum index » PPM Zone » PPM News Network
TMP Studio 1.0 Released!
Moderators: Global Moderators
Post new topic   Reply to topic Page 2 of 2 [69 Posts] View previous topic :: View next topic
Goto page: Previous 1, 2
PostPosted: Thu Dec 29, 2011 10:37 am    Post subject: Reply with quote
I just came to this topic to install this on my laptop..
I forgot what a dick Icy was. PPM has gotten so much better since he did his little rage quit
"Good thing you paid attention in chemistry, sir", stated McGormly
"Don't kid yourself LT, I don't know what the hell any of this stuff really is", admitted Price
-Attack on Hammerfest
Edge
PostPosted: Thu Dec 29, 2011 12:35 pm    Post subject: Reply with quote
I think you can message Nikademis Von Hisson, he is allowed to distribute it.
Location: Iszkaszentgyorgy, Hungary ... silly php update broke accented locations -_-
PostPosted: Thu Dec 29, 2011 12:49 pm    Post subject: Reply with quote
Or reread this thread's first page, Aro putted it up. #Tongue
Orac wrote:
Any opinions you get from here will be honest, because so far nobody has really cared enough to lie to avoid hurting your feelings.
RP wrote:
I like this guy, that Graion Dilach. He seems to know one or two things about people. Mister Dilach can identify a moron in less than five posts!
Edge
PostPosted: Tue Jan 03, 2012 8:14 pm    Post subject: Reply with quote
Ah, didn't see that. lol
DaRTzO
Stealth Laser Trooper
PostPosted: Wed Jan 04, 2012 5:59 am    Post subject: Reply with quote
Thanks for uploading Aro. I didn't understand the bullshit floating around this program before either.
If you make a reasonable modding tool it should be released instead of teasing the damn community. Smile
Though TMP Studio is buggy as ztype.
Matthias M.
PostPosted: Tue Apr 30, 2013 5:03 am    Post subject: Reply with quote
I guess there is no code published so we can't fix this?
PostPosted: Tue Apr 30, 2013 9:13 am    Post subject: Reply with quote
correct, no public code.
But i predict that this tool and XCC TMP Editor will become useless at some point this year. Wink
btw, does OpenRA use TMPs for the terrain as well?
How does OpenRA handle/differ between the rectangular shaped cells from TD/RA1 and the diamond perspective cells from TS/RA2? Does it support both?
SHP Artist of Twisted Insurrection. Main Nod building SHP creator.
5 GDI, 5 Nod, 1 Mutant unit, 1 Scrin unit, 1 GDI building
TMP Shop
PostPosted: Tue Apr 30, 2013 10:19 am    Post subject: Reply with quote
I remember reading that OpenRA doesn't (or didn't?) support isometric cells yet.
I'll look forward to the fulfillment of your prophecy then Razz
Matthias M.
PostPosted: Wed May 01, 2013 7:05 am    Post subject: Reply with quote
yes
Isometric cells are not yet supported at all, but Sleipnir promised to clean up our coordinate system and add optional isometry someday.
PostPosted: Wed May 01, 2013 12:03 pm    Post subject: Reply with quote
Surely there must be a better system for terrain than TMP, at least removing the colour limits? I guess it was all designed originally to support RA1 as best as possible but removing the limitations would surely be nicer.
PostPosted: Wed May 01, 2013 12:34 pm    Post subject: Reply with quote
TMPs are good imo. They don't have a lot of redundant data and are nicely compressed.
The only issue is the palette, which could be fixed by allowing different TMPs of the same theater to use different palettes. e.g. an ini key for the TileSets in tem.ini/snow.ini.
A radical change like now supporting png or other fileformats for TMPs would be too much imo.
TMP Shop
PostPosted: Wed May 01, 2013 12:41 pm    Post subject: Reply with quote
IMO it'd be nice to support both modern formats and TMPs. If someone is creating a new game with the engine, (s)he shouldn't have to deal with limited color palettes.
PostPosted: Wed May 01, 2013 12:56 pm    Post subject: Reply with quote
true
but i fear that by supporting PNGs, the amount of data that needs to be stored for a map will increase by the factor 10 or even more.
Also PNGs don't work directly. A special custom format is still needed that can hold the additional data for TerrainType, SlopeType, Destroyable Terrain, TileHeight etc
TMP Shop
Matthias M.
PostPosted: Fri May 03, 2013 3:10 pm    Post subject: Reply with quote
We have a GUI Tileset Builder that can import a palette indexed PNG file and spit out the TMP set with tileset defintions in our modding SDK.
raminator
PostPosted: Fri May 03, 2013 5:48 pm    Post subject: Reply with quote
true
? why ?
having a standard png with some transparent color and adding all other info to yaml-files
sounds pretty "easy" to me.
"I eat resistance for breakfast!"
PostPosted: Fri May 03, 2013 6:20 pm    Post subject: Reply with quote
Storing the terraintype in a TMP for a single tile=1 byte in the tmp itself.
Storing the terraintype in an additional YAML file for a single tile around 30 bytes. Identifier, Header, additional nomenclature and formatting blow this unnecessarily up.
e.g. you have to specify
filename:     myterrain.png
# of Tiles:        3
Tile1:
    TerrainType:   Clear
    SlopeType:  Flat
    Height:  0
Tile2:
    TerrainType:   Rough
    SlopeType:  slopeNW (can be also stored as an integer from 0-7)
    Height:  1
Doing this for 2000 TMPs with 1-20 Tiles each makes the YAML about 600.000 Byte big.
Now take this times 3 for additional slopetype and height and you end up with almost 2MB just for the additional data. Reading that amount of data, synchronizing it with the corresponding terrainfiles (pngs) and other stuff makes this unnecessary slow and complicated.
Not to speak of the later bugfixing, when you have to scan through a MByte big text file, searching for the single false set tile information.
TMP Shop
PostPosted: Fri May 03, 2013 6:32 pm    Post subject: Reply with quote
Did you mean cells instead of tiles?
I agree that from a modder's perspective it would be very inconvenient to have to manually code every tile to tell the game which cell is what terrain type, height, which slope, etc.
Maybe a 16 bit TMP format could be added (along with an editor that can actually handle them of course)?
PostPosted: Fri May 03, 2013 6:55 pm    Post subject: Reply with quote
cells, tiles are for me the same when it comes to TMPs. A tmp can consist of one ore more tiles (cells).
16bit TMP format sounds interesting. I assume you then want each pixel to point on an index of a palette that supports 65536 colors?
Maybe better would be to directly have each pixel store the color instead. and then go up to 24 bit for a full 8bit per R,G and B value. Not sure how you then want to store transparent pixel though (e.g. in extra graphics). Going up to 32 bit with an additional alpha channel would make this quite big again.
But with 32 bit full alpha support, some really nice things could be done.
e.g. a semi transparent metal grid gangway above a normal ground tile. It would be a single TMP with 2 tiles on the same x,y position but on different heights. The upper tile having the metal grid style using alpha.
TMP Shop
Matthias M.
PostPosted: Sat May 04, 2013 8:10 pm    Post subject: Reply with quote
See https://github.com/OpenRA/OpenRA/blob/bleed/mods/ra/tilesets/temperat.yaml on how tileset definition currently work. It is probably easy to add native PNG support, just currently out of scope.
Post new topic   Reply to topic Page 2 of 2 [69 Posts] Goto page: Previous 1, 2
[ Time: 0.3304s ][ Queries: 13 (0.0245s) ][ Debug on ]
