The time now is Sat Apr 20, 2024 9:24 am
TI: Internal Errors
Post new topic   Reply to topic Page 1 of 1 [48 Posts] Mark the topic unread ::  View previous topic :: View next topic
PostPosted: Wed Aug 25, 2010 2:13 pm    Post subject:  TI: Internal Errors
Subject description: This thread is for internal errors only.
This is the only topic here I don't want to see getting any replies. Hopefully there will be no Internal Errors, but if you do come across any, please upload the except.txt and logfile.txt here (check main TI directory and also the Client > Error Logs directory). A Description of what happened before the Internal Error occurred, what map and settings you had set would help us too.
Please report Bugs and Reconection Errors in their respective topics.
If you are having .NET Framework errors, please make sure you have .NET Framework 2.0 up to 4.0 installed.
Damfoos
PostPosted: Thu Dec 01, 2016 9:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Got an internal error when tried to load savegame from GDI 11, made on the same version of the game just yesterday.
SAVE5F90.SAV
 Filename:  SAVE5F90.SAV
 Filesize:  3.32 MB
 Downloaded:  211 Time(s)
EXCEPT_1_12_2016_12_22.TXT
 Filename:  EXCEPT_1_12_2016_12_22.TXT
 Filesize:  20.75 KB
 Downloaded:  185 Time(s)
except.txt
 Filename:  except.txt
 Filesize:  20.75 KB
 Downloaded:  198 Time(s)
e1k3
PostPosted: Tue Jul 18, 2017 5:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
i dont know if thats an actual TI and not just tiberian sun engine problem, but i keep getting crashes when an air transport dies while unloading units
(i gave the TD nod transport helicopter a usable tech level).
coming to think of it, that might be the reason you guys made them not available to players in the first place Smile
Yowza
PostPosted: Sat Dec 23, 2017 10:27 am    Post subject: Twisted Dawn - Nod M5 - IE on start - Win10 64-bit Reply with quote  Mark this post and the followings unread
Hello,
I am experiencing an Internal Error when starting the fifth Twisted Dawn Nod mission. The mission and briefing loads just fine, but then freezes/crashes with an Internal Error message when the briefing is closed.
I am running the game on a 64-bit installation of Windows 10.
(If relevant: The music still plays and I can not actually click the IE message, requiring me to force-quit the application).
I have attached the logfiles relevant to the error.
EXCEPT_23_12_2017_11_19.TXT
 Filename:  EXCEPT_23_12_2017_11_19.TXT
 Filesize:  20.75 KB
 Downloaded:  167 Time(s)
except.txt
 Filesize:  20.75 KB
 Downloaded:  129 Time(s)
E1 Elite
PostPosted: Sat Dec 23, 2017 3:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Assigning Primary=SuicideBomber to some unused Technotype in
rules.ini should solve it.
PostPosted: Sat Dec 23, 2017 9:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the report, this will be fixed in the next patch for 0.7.
Lucianhector
PostPosted: Wed Dec 27, 2017 5:14 pm    Post subject: Error Reply with quote  Mark this post and the followings unread
Hi guys,
Been advised to post my error here
I've received it on numerous occasions while sometime into a skirmish mission against AI on the map - heart of darkness (great map)
I've restarted my matches 3-4 times but get it in every game, and saving and loading the match doesn't stop it
Thank you
Spoiler (click here to read it):
Error code: EXCEPTION_ACCESS_VIOLATION
Description: The thread tried to read from or write to a virtual address for which it does not have the appropriate access.
Access address:00000105 was written to.
Exception occurred at 006BB297
Version 2.03
Internal Version 2.0
Release Build: 10 by STEVE_TALL - 06/05/2000 - 14:27:06
CPU 686, MMX Yes, Vendor: GenuineIntel
Details:
Eip:006BB297 Esp:00A9C494 Ebp:00A9C4B4
Eax:1737BBB0 Ebx:00000030 Ecx:00000101
Edx:049DB86C Esi:00000007 Edi:00000030
EFlags:00010293
CS:0023  SS:002b  DS:002b  ES:002b  FS:0053  GS:002b
Bytes at CS:EIP (006BB297)  : 89 79 04 8B 4C 13 04 8B 7C 13 08 03 5D F8 89 79 08 89 5D F4 8B FB C1 FF 04 4F 83 FF 3F 76 03 6A
Stack dump (* indicates possible code address) :
00A9C494: 049D83A0
00A9C498: 049DB870
00A9C49C: 00000000
00A9C4A0: 00000014
00A9C4A4: 1737CB10
00A9C4A8: 00000030
00A9C4AC: 00000000
00A9C4B0: 00000021
00A9C4B4: 00000014
00A9C4B8: 006B6807
00A9C4BC: 16DDAA3C
00A9C4C0: 0000003F
00A9C4C4: 00A9C530
00A9C4C8: 006B51D5
00A9C4CC: 049DB870
00A9C4D0: 00497DEE
00A9C4D4: 049DB870
00A9C4D8: 00000000
00A9C4DC: 00A9C530
00A9C4E0: 18E7B8A0
00A9C4E4: 17E64610
00A9C4E8: 00627854
00A9C4EC: 00000014
00A9C4F0: 00000000
00A9C4F4: 000DE666
00A9C4F8: 00000000
00A9C4FC: 00000010
00A9C500: 180EEA48
00A9C504: 004C17EC
00A9C508: 00000005
00A9C50C: 00000000
00A9C510: 180EEA48
00A9C514: 00000078
00A9C518: FFFFFFFF
00A9C51C: 00000010
00A9C520: 640E66EF
00A9C524: 180EEA48
00A9C528: 7FFFFFFF
00A9C52C: FFFFFFFF
00A9C530: 006D00E8
00A9C534: 049DB870
00A9C538: 0000000A
00A9C53C: 08330101
00A9C540: 0000000A
00A9C544: 0000000A
00A9C548: 00000000
00A9C54C: 00000000
00A9C550: 00000000
00A9C554: 00000000
00A9C558: 00000000
00A9C55C: 00000000
00A9C560: 00000000
00A9C564: 00000000
00A9C568: 00000000
00A9C56C: 00000000
00A9C570: 00000000
00A9C574: 00000000
00A9C578: 00000000
00A9C57C: 00000000
00A9C580: 00000000
00A9C584: 00000000
00A9C588: 00000000
00A9C58C: 00000000
00A9C590: 00000000
00A9C594: 00000000
00A9C598: 00000000
00A9C59C: 00000000
00A9C5A0: 00000000
00A9C5A4: 00000000
00A9C5A8: 00000000
00A9C5AC: 00000000
00A9C5B0: 00000000
00A9C5B4: 00000000
00A9C5B8: 00000000
00A9C5BC: 00000000
00A9C5C0: 00000000
00A9C5C4: 00000000
00A9C5C8: 00000000
00A9C5CC: 00000000
00A9C5D0: 00000000
00A9C5D4: 00000000
00A9C5D8: 00000000
00A9C5DC: 00000000
00A9C5E0: 00000000
00A9C5E4: 00000000
00A9C5E8: 00000000
00A9C5EC: 00000000
00A9C5F0: 00000000
00A9C5F4: 00000000
00A9C5F8: 00000000
00A9C5FC: 00000000
00A9C600: 00000000
00A9C604: 00000000
00A9C608: 00000000
00A9C60C: 00000000
00A9C610: 00000000
00A9C614: 00000000
00A9C618: 00000000
00A9C61C: 00000000
00A9C620: 00000000
00A9C624: 00000000
00A9C628: 00000000
00A9C62C: 00000000
00A9C630: 00000000
00A9C634: 00000000
00A9C638: 00000000
00A9C63C: 00000000
00A9C640: 00000000
00A9C644: 00000000
00A9C648: 00000000
00A9C64C: 00000000
00A9C650: 00000000
00A9C654: 00000000
00A9C658: 00000000
00A9C65C: 00000000
00A9C660: 00000000
00A9C664: 00000000
00A9C668: 00000000
00A9C66C: 00000000
00A9C670: 00000000
00A9C674: 00000000
00A9C678: 00000000
00A9C67C: 00000000
00A9C680: 00000000
00A9C684: 00000000
00A9C688: 00000000
00A9C68C: 00000000
00A9C690: 00000000
00A9C694: 00000000
00A9C698: 00000000
00A9C69C: 00000000
00A9C6A0: 00000000
00A9C6A4: 00000000
00A9C6A8: 00000000
00A9C6AC: 00000000
00A9C6B0: 00000000
00A9C6B4: 00000000
00A9C6B8: 00000000
00A9C6BC: 00000000
00A9C6C0: 00000000
00A9C6C4: 00000000
00A9C6C8: 00000000
00A9C6CC: 00000000
00A9C6D0: 00000000
00A9C6D4: 00000000
00A9C6D8: 00000000
00A9C6DC: 00000000
00A9C6E0: 00000000
00A9C6E4: 00000000
00A9C6E8: 00000000
00A9C6EC: 00000000
00A9C6F0: 00000000
00A9C6F4: 00000000
00A9C6F8: 00000000
00A9C6FC: 00000000
00A9C700: 00000000
00A9C704: 00000000
00A9C708: 00000000
00A9C70C: 00000000
00A9C710: 00000000
00A9C714: 00000000
00A9C718: 00000000
00A9C71C: 00000000
00A9C720: 00000000
00A9C724: 00000000
00A9C728: 00000000
00A9C72C: 00000000
00A9C730: 00000000
00A9C734: 00000000
00A9C738: 00000000
00A9C73C: 00000000
00A9C740: 00000000
00A9C744: 00000000
00A9C748: 00000000
00A9C74C: 00000000
00A9C750: 00000000
00A9C754: 00000000
00A9C758: 00000000
00A9C75C: 00000000
00A9C760: 00000000
00A9C764: 00000000
00A9C768: 00000000
00A9C76C: 00000000
00A9C770: 00000000
00A9C774: 00000000
00A9C778: 00000000
00A9C77C: 00000000
00A9C780: 00000000
00A9C784: 00000000
00A9C788: 00000000
00A9C78C: 00000000
00A9C790: 00000000
00A9C794: 00000000
00A9C798: 00000000
00A9C79C: 00000000
00A9C7A0: 00000000
00A9C7A4: 00000000
00A9C7A8: 00000000
00A9C7AC: 00000000
00A9C7B0: 00000000
00A9C7B4: 00000000
00A9C7B8: 00000000
00A9C7BC: 00000000
00A9C7C0: 00000000
00A9C7C4: 00000000
00A9C7C8: 00000000
00A9C7CC: 00000000
00A9C7D0: 00000000
00A9C7D4: 00000000
00A9C7D8: 00000000
00A9C7DC: 00000000
00A9C7E0: 00000000
00A9C7E4: 00000000
00A9C7E8: 00000000
00A9C7EC: 00000000
00A9C7F0: 00000000
00A9C7F4: 00000000
00A9C7F8: 00000000
00A9C7FC: 00000000
00A9C800: 00000000
00A9C804: 00000000
00A9C808: 00000000
00A9C80C: 00000000
00A9C810: 00000000
00A9C814: 00000000
00A9C818: 00000000
00A9C81C: 00000000
00A9C820: 00000000
00A9C824: 00000000
00A9C828: 00000000
00A9C82C: 00000000
00A9C830: 00000000
00A9C834: 00000000
00A9C838: 00000000
00A9C83C: 00000000
00A9C840: 00000000
00A9C844: 00000000
00A9C848: 00000000
00A9C84C: 00000000
00A9C850: 00000000
00A9C854: 00000000
00A9C858: 00000000
00A9C85C: 00000000
00A9C860: 00000000
00A9C864: 00000000
00A9C868: 00000000
00A9C86C: 00000000
00A9C870: 00000000
00A9C874: 00000000
00A9C878: 00000000
00A9C87C: 00000000
00A9C880: 00000000
00A9C884: 00000000
00A9C888: 00000000
00A9C88C: 00000000
00A9C890: 00000000
00A9C894: 00000000
00A9C898: 00000000
00A9C89C: 00000000
00A9C8A0: 00000000
00A9C8A4: 00000000
00A9C8A8: 00000000
00A9C8AC: 00000000
00A9C8B0: 00000000
00A9C8B4: 00000000
00A9C8B8: 00000000
00A9C8BC: 00000000
00A9C8C0: 00000000
00A9C8C4: 00000000
00A9C8C8: 00000000
00A9C8CC: 00000000
00A9C8D0: 00000000
00A9C8D4: 00000000
00A9C8D8: 00000000
00A9C8DC: 00000000
00A9C8E0: 00000000
00A9C8E4: 00000000
00A9C8E8: 00000000
00A9C8EC: 00000000
00A9C8F0: 00000000
00A9C8F4: 00000000
00A9C8F8: 00000000
00A9C8FC: 00000000
00A9C900: 00000000
00A9C904: 00000000
00A9C908: 00000000
00A9C90C: 00000000
00A9C910: 00000000
00A9C914: 00000000
00A9C918: 00000000
00A9C91C: 00000000
00A9C920: 00000000
00A9C924: 00000000
00A9C928: 00000000
00A9C92C: 00000000
00A9C930: 00000000
00A9C934: 00000000
00A9C938: 00000000
00A9C93C: 00000000
00A9C940: 00000000
00A9C944: 00000000
00A9C948: 00000000
00A9C94C: 00000000
00A9C950: 00000000
00A9C954: 00000000
00A9C958: 00000000
00A9C95C: 00000000
00A9C960: 00000000
00A9C964: 00000000
00A9C968: 00000000
00A9C96C: 00000000
00A9C970: 00000000
00A9C974: 00000000
00A9C978: 00000000
00A9C97C: 00000000
00A9C980: 00000000
00A9C984: 00000000
00A9C988: 00000000
00A9C98C: 00000000
00A9C990: 00000000
00A9C994: 00000000
00A9C998: 00000000
00A9C99C: 00000000
00A9C9A0: 00000000
00A9C9A4: 00000000
00A9C9A8: 00000000
00A9C9AC: 00000000
00A9C9B0: 00000000
00A9C9B4: 00000000
00A9C9B8: 00000000
00A9C9BC: 00000000
00A9C9C0: 00000000
00A9C9C4: 00000000
00A9C9C8: 00000000
00A9C9CC: 00000000
00A9C9D0: 00000000
00A9C9D4: 00000000
00A9C9D8: 00000000
00A9C9DC: 00000000
00A9C9E0: 00000000
00A9C9E4: 00000000
00A9C9E8: 00000000
00A9C9EC: 00000000
00A9C9F0: 00000000
00A9C9F4: 00000000
00A9C9F8: 00000000
00A9C9FC: 00000000
00A9CA00: 00000000
00A9CA04: 00000000
00A9CA08: 00000000
00A9CA0C: 00000000
00A9CA10: 00000000
00A9CA14: 00000000
00A9CA18: 00000000
00A9CA1C: 00000000
00A9CA20: 00000000
00A9CA24: 00000000
00A9CA28: 00000000
00A9CA2C: 00000000
00A9CA30: 00000000
00A9CA34: 00000000
00A9CA38: 00000000
00A9CA3C: 00000000
00A9CA40: 00000000
00A9CA44: 00000000
00A9CA48: 00000000
00A9CA4C: 00000000
00A9CA50: 00000000
00A9CA54: 00000000
00A9CA58: 00000000
00A9CA5C: 00000000
00A9CA60: 00000000
00A9CA64: 00000000
00A9CA68: 00000000
00A9CA6C: 00000000
00A9CA70: 00000000
00A9CA74: 00000000
00A9CA78: 00000000
00A9CA7C: 00000000
00A9CA80: 00000000
00A9CA84: 00000000
00A9CA88: 00000000
00A9CA8C: 00000000
00A9CA90: 00000000
00A9CA94: 00000000
00A9CA98: 00000000
00A9CA9C: 00000000
00A9CAA0: 00000000
00A9CAA4: 00000000
00A9CAA8: 00000000
00A9CAAC: 00000000
00A9CAB0: 00000000
00A9CAB4: 00000000
00A9CAB8: 00000000
00A9CABC: 00000000
00A9CAC0: 00000000
00A9CAC4: 00000000
00A9CAC8: 00000000
00A9CACC: 00000000
00A9CAD0: 00000000
00A9CAD4: 00000000
00A9CAD8: 00000000
00A9CADC: 00000000
00A9CAE0: 00000000
00A9CAE4: 00000000
00A9CAE8: 00000000
00A9CAEC: 00000000
00A9CAF0: 00000000
00A9CAF4: 00000000
00A9CAF8: 00000000
00A9CAFC: 00000000
00A9CB00: 00000000
00A9CB04: 00000000
00A9CB08: 00000000
00A9CB0C: 00000000
00A9CB10: 00000000
00A9CB14: 00000000
00A9CB18: 00000000
00A9CB1C: 00000000
00A9CB20: 00000000
00A9CB24: 00000000
00A9CB28: 00000000
00A9CB2C: 00000000
00A9CB30: 00000000
00A9CB34: 00000000
00A9CB38: 00000000
00A9CB3C: 00000000
00A9CB40: 00000000
00A9CB44: 00000000
00A9CB48: 00000000
00A9CB4C: 00000000
00A9CB50: 00000000
00A9CB54: 00000000
00A9CB58: 00000000
00A9CB5C: 00000000
00A9CB60: 00000000
00A9CB64: 00000000
00A9CB68: 00000000
00A9CB6C: 00000000
00A9CB70: 00000000
00A9CB74: 00000000
00A9CB78: 00000000
00A9CB7C: 00000000
00A9CB80: 00000000
00A9CB84: 00000000
00A9CB88: 00000000
00A9CB8C: 00000000
00A9CB90: 00000000
00A9CB94: 00000000
00A9CB98: 00000000
00A9CB9C: 00000000
00A9CBA0: 00000000
00A9CBA4: 00000000
00A9CBA8: 00000000
00A9CBAC: 00000000
00A9CBB0: 00000000
00A9CBB4: 00000000
00A9CBB8: 00000000
00A9CBBC: 00000000
00A9CBC0: 00000000
00A9CBC4: 00000000
00A9CBC8: 00000000
00A9CBCC: 00000000
00A9CBD0: 00000000
00A9CBD4: 00000000
00A9CBD8: 00000000
00A9CBDC: 00000000
00A9CBE0: 00000000
00A9CBE4: 00000000
00A9CBE8: 00000000
00A9CBEC: 00000000
00A9CBF0: 00000000
00A9CBF4: 00000000
00A9CBF8: 00000000
00A9CBFC: 00000000
00A9CC00: 00000000
00A9CC04: 00000000
00A9CC08: 00000000
00A9CC0C: 00000000
00A9CC10: 00000000
00A9CC14: 00000000
00A9CC18: 00000000
00A9CC1C: 00000000
00A9CC20: 00000000
00A9CC24: 00000000
00A9CC28: 00000000
00A9CC2C: 00000000
00A9CC30: 00000000
00A9CC34: 00000000
00A9CC38: 00000000
00A9CC3C: 00000000
00A9CC40: 00000000
00A9CC44: 00000000
00A9CC48: 00000000
00A9CC4C: 00000000
00A9CC50: 00000000
00A9CC54: 00000000
00A9CC58: 00000000
00A9CC5C: 00000000
00A9CC60: 00000000
00A9CC64: 00000000
00A9CC68: 00000000
00A9CC6C: 00000000
00A9CC70: 00000000
00A9CC74: 00000000
00A9CC78: 00000000
00A9CC7C: 00000000
00A9CC80: 00000000
00A9CC84: 00000000
00A9CC88: 00000000
00A9CC8C: 00000000
00A9CC90: 00000000
00A9CC94: 00000000
00A9CC98: 00000000
00A9CC9C: 00000000
00A9CCA0: 00000000
00A9CCA4: 00000000
00A9CCA8: 00000000
00A9CCAC: 00000000
00A9CCB0: 00000000
00A9CCB4: 00000000
00A9CCB8: 00000000
00A9CCBC: 00000000
00A9CCC0: 00000000
00A9CCC4: 00000000
00A9CCC8: 00000000
00A9CCCC: 00000000
00A9CCD0: 00000000
00A9CCD4: 00000000
00A9CCD8: 00000000
00A9CCDC: 00000000
00A9CCE0: 00000000
00A9CCE4: 00000000
00A9CCE8: 00000000
00A9CCEC: 00000000
00A9CCF0: 00000000
00A9CCF4: 00000000
00A9CCF8: 00000000
00A9CCFC: 00000000
00A9CD00: 00000000
00A9CD04: 00000000
00A9CD08: 00000000
00A9CD0C: 00000000
00A9CD10: 00000000
00A9CD14: 00000000
00A9CD18: 00000000
00A9CD1C: 00000000
00A9CD20: 00000000
00A9CD24: 00000000
00A9CD28: 00000000
00A9CD2C: 00000000
00A9CD30: 00000000
00A9CD34: 00000000
00A9CD38: 00000000
00A9CD3C: 00000000
00A9CD40: 00000000
00A9CD44: 00000000
00A9CD48: 00000000
00A9CD4C: 00000000
00A9CD50: 00000000
00A9CD54: 00000000
00A9CD58: 00000000
00A9CD5C: 00000000
00A9CD60: 00000000
00A9CD64: 00000000
00A9CD68: 00000000
00A9CD6C: 00000000
00A9CD70: 00000000
00A9CD74: 00000000
00A9CD78: 00000000
00A9CD7C: 00000000
00A9CD80: 00000000
00A9CD84: 00000000
00A9CD88: 00000000
00A9CD8C: 00000000
00A9CD90: 00000000
00A9CD94: 00000000
00A9CD98: 00000000
00A9CD9C: 00000000
00A9CDA0: 00000000
00A9CDA4: 00000000
00A9CDA8: 00000000
00A9CDAC: 00000000
00A9CDB0: 00000000
00A9CDB4: 00000000
00A9CDB8: 00000000
00A9CDBC: 00000000
00A9CDC0: 00000000
00A9CDC4: 00000000
00A9CDC8: 00000000
00A9CDCC: 00000000
00A9CDD0: 00000000
00A9CDD4: 00000000
00A9CDD8: 00000000
00A9CDDC: 00000000
00A9CDE0: 00000000
00A9CDE4: 00000000
00A9CDE8: 00000000
00A9CDEC: 00000000
00A9CDF0: 00000000
00A9CDF4: 00000000
00A9CDF8: 00000000
00A9CDFC: 00000000
00A9CE00: 00000000
00A9CE04: 00000000
00A9CE08: 00000000
00A9CE0C: 00000000
00A9CE10: 00000000
00A9CE14: 00000000
00A9CE18: 00000000
00A9CE1C: 00000000
00A9CE20: 00000000
00A9CE24: 00000000
00A9CE28: 00000000
00A9CE2C: 00000000
00A9CE30: 00000000
00A9CE34: 00000000
00A9CE38: 00000000
00A9CE3C: 00000000
00A9CE40: 00000000
00A9CE44: 00000000
00A9CE48: 00000000
00A9CE4C: 00000000
00A9CE50: 00000000
00A9CE54: 00000000
00A9CE58: 00000000
00A9CE5C: 00000000
00A9CE60: 00000000
00A9CE64: 00000000
00A9CE68: 00000000
00A9CE6C: 00000000
00A9CE70: 00000000
00A9CE74: 00000000
00A9CE78: 00000000
00A9CE7C: 00000000
00A9CE80: 00000000
00A9CE84: 00000000
00A9CE88: 00000000
00A9CE8C: 00000000
00A9CE90: 00000000
00A9CE94: 00000000
00A9CE98: 00000000
00A9CE9C: 00000000
00A9CEA0: 00000000
00A9CEA4: 00000000
00A9CEA8: 00000000
00A9CEAC: 00000000
00A9CEB0: 00000000
00A9CEB4: 00000000
00A9CEB8: 00000000
00A9CEBC: 00000000
00A9CEC0: 00000000
00A9CEC4: 00000000
00A9CEC8: 00000000
00A9CECC: 00000000
00A9CED0: 00000000
00A9CED4: 00000000
00A9CED8: 00000000
00A9CEDC: 00000000
00A9CEE0: 00000000
00A9CEE4: 00000000
00A9CEE8: 00000000
00A9CEEC: 00000000
00A9CEF0: 00000000
00A9CEF4: 00000000
00A9CEF8: 00000000
00A9CEFC: 00000000
00A9CF00: 00000000
00A9CF04: 00000000
00A9CF08: 00000000
00A9CF0C: 00000000
00A9CF10: 00000000
00A9CF14: 00000000
00A9CF18: 00000000
00A9CF1C: 00000000
00A9CF20: 00000000
00A9CF24: 00000000
00A9CF28: 00000000
00A9CF2C: 00000000
00A9CF30: 00000000
00A9CF34: 00000000
00A9CF38: 00000000
00A9CF3C: 00000000
00A9CF40: 00000000
00A9CF44: 00000000
00A9CF48: 00000000
00A9CF4C: 00000000
00A9CF50: 00000000
00A9CF54: 00000000
00A9CF58: 00000000
00A9CF5C: 00000000
00A9CF60: 00000000
00A9CF64: 00000000
00A9CF68: 00000000
00A9CF6C: 00000000
00A9CF70: 00000000
00A9CF74: 00000000
00A9CF78: 00000000
00A9CF7C: 00000000
00A9CF80: 00000000
00A9CF84: 00000000
00A9CF88: 00000000
00A9CF8C: 00000000
00A9CF90: 00000000
00A9CF94: 00000000
00A9CF98: 00000000
00A9CF9C: 00000000
00A9CFA0: 00000000
00A9CFA4: 00000000
00A9CFA8: 00000000
00A9CFAC: 00000000
00A9CFB0: 00000000
00A9CFB4: 00000000
00A9CFB8: 00000000
00A9CFBC: 00000000
00A9CFC0: 00000000
00A9CFC4: 00000000
00A9CFC8: 00000000
00A9CFCC: 00000000
00A9CFD0: 00000000
00A9CFD4: 00000000
00A9CFD8: 00000000
00A9CFDC: 00000000
00A9CFE0: 00000000
00A9CFE4: 00000000
00A9CFE8: 00000000
00A9CFEC: 00000000
00A9CFF0: 00000000
00A9CFF4: 00000000
00A9CFF8: 00000000
00A9CFFC: 00000000
00A9D000: 00000000
00A9D004: 00000000
00A9D008: 00000000
00A9D00C: 00000000
00A9D010: 00000000
00A9D014: 00000000
00A9D018: 00000000
00A9D01C: 00000000
00A9D020: 00000000
00A9D024: 00000000
00A9D028: 00000000
00A9D02C: 00000000
00A9D030: 00000000
00A9D034: 00000000
00A9D038: 00000000
00A9D03C: 00000000
00A9D040: 00000000
00A9D044: 00000000
00A9D048: 00000000
00A9D04C: 00000000
00A9D050: 00000000
00A9D054: 00000000
00A9D058: 00000000
00A9D05C: 00000000
00A9D060: 00000000
00A9D064: 00000000
00A9D068: 00000000
00A9D06C: 00000000
00A9D070: 00000000
00A9D074: 00000000
00A9D078: 00000000
00A9D07C: 00000000
00A9D080: 00000000
00A9D084: 00000000
00A9D088: 00000000
00A9D08C: 00000000
00A9D090: 00000000
00A9D094: 00000000
00A9D098: 00000000
00A9D09C: 00000000
00A9D0A0: 00000000
00A9D0A4: 00000000
00A9D0A8: 00000000
00A9D0AC: 00000000
00A9D0B0: 00000000
00A9D0B4: 00000000
00A9D0B8: 00000000
00A9D0BC: 00000000
00A9D0C0: 00000000
00A9D0C4: 00000000
00A9D0C8: 00000000
00A9D0CC: 00000000
00A9D0D0: 00000000
00A9D0D4: 00000000
00A9D0D8: 00000000
00A9D0DC: 00000000
00A9D0E0: 00000000
00A9D0E4: 00000000
00A9D0E8: 00000000
00A9D0EC: 00000000
00A9D0F0: 00000000
00A9D0F4: 00000000
00A9D0F8: 00000000
00A9D0FC: 00000000
00A9D100: 00000000
00A9D104: 00000000
00A9D108: 00000000
00A9D10C: 00000000
00A9D110: 00000000
00A9D114: 00000000
00A9D118: 00000000
00A9D11C: 00000000
00A9D120: 00000000
00A9D124: 00000000
00A9D128: 00000000
00A9D12C: 00000000
00A9D130: 00000000
00A9D134: 00000000
00A9D138: 00000000
00A9D13C: 00000000
00A9D140: 00000000
00A9D144: 00000000
00A9D148: 00000000
00A9D14C: 00000000
00A9D150: 00000000
00A9D154: 00000000
00A9D158: 00000000
00A9D15C: 00000000
00A9D160: 00000000
00A9D164: 00000000
00A9D168: 00000000
00A9D16C: 00000000
00A9D170: 00000000
00A9D174: 00000000
00A9D178: 00000000
00A9D17C: 00000000
00A9D180: 00000000
00A9D184: 00000000
00A9D188: 00000000
00A9D18C: 00000000
00A9D190: 00000000
00A9D194: 00000000
00A9D198: 00000000
00A9D19C: 00000000
00A9D1A0: 00000000
00A9D1A4: 00000000
00A9D1A8: 00000000
00A9D1AC: 00000000
00A9D1B0: 00000000
00A9D1B4: 00000000
00A9D1B8: 00000000
00A9D1BC: 00000000
00A9D1C0: 00000000
00A9D1C4: 00000000
00A9D1C8: 00000000
00A9D1CC: 00000000
00A9D1D0: 00000000
00A9D1D4: 00000000
00A9D1D8: 00000000
00A9D1DC: 00000000
00A9D1E0: 00000000
00A9D1E4: 00000000
00A9D1E8: 00000000
00A9D1EC: 00000000
00A9D1F0: 00000000
00A9D1F4: 00000000
00A9D1F8: 00000000
00A9D1FC: 00000000
00A9D200: 00000000
00A9D204: 00000000
00A9D208: 00000000
00A9D20C: 00000000
00A9D210: 00000000
00A9D214: 00000000
00A9D218: 00000000
00A9D21C: 00000000
00A9D220: 00000000
00A9D224: 00000000
00A9D228: 00000000
00A9D22C: 00000000
00A9D230: 00000000
00A9D234: 00000000
00A9D238: 00000000
00A9D23C: 00000000
00A9D240: 00000000
00A9D244: 00000000
00A9D248: 00000000
00A9D24C: 00000000
00A9D250: 00000000
00A9D254: 00000000
00A9D258: 00000000
00A9D25C: 00000000
00A9D260: 00000000
00A9D264: 00000000
00A9D268: 00000000
00A9D26C: 00000000
00A9D270: 00000000
00A9D274: 00000000
00A9D278: 00000000
00A9D27C: 00000000
00A9D280: 00000000
00A9D284: 00000000
00A9D288: 00000000
00A9D28C: 00000000
00A9D290: 00000000
00A9D294: 00000000
00A9D298: 00000000
00A9D29C: 00000000
00A9D2A0: 00000000
00A9D2A4: 00000000
00A9D2A8: 00000000
00A9D2AC: 00000000
00A9D2B0: 00000000
00A9D2B4: 00000000
00A9D2B8: 00000000
00A9D2BC: 00000000
00A9D2C0: 00000000
00A9D2C4: 00000000
00A9D2C8: 00000000
00A9D2CC: 00000000
00A9D2D0: 00000000
00A9D2D4: 00000000
00A9D2D8: 00000000
00A9D2DC: 00000000
00A9D2E0: 00000000
00A9D2E4: 00000000
00A9D2E8: 00000000
00A9D2EC: 00000000
00A9D2F0: 00000000
00A9D2F4: 00000000
00A9D2F8: 00000000
00A9D2FC: 00000000
00A9D300: 00000000
00A9D304: 00000000
00A9D308: 00000000
00A9D30C: 00000000
00A9D310: 00000000
00A9D314: 00000000
00A9D318: 00000000
00A9D31C: 00000000
00A9D320: 00000000
00A9D324: 00000000
00A9D328: 00000000
00A9D32C: 00000000
00A9D330: 00000000
00A9D334: 00000000
00A9D338: 00000000
00A9D33C: 00000000
00A9D340: 00000000
00A9D344: 00000000
00A9D348: 00000000
00A9D34C: 00000000
00A9D350: 00000000
00A9D354: 00000000
00A9D358: 00000000
00A9D35C: 00000000
00A9D360: 00000000
00A9D364: 00000000
00A9D368: 00000000
00A9D36C: 00000000
00A9D370: 00000000
00A9D374: 00000000
00A9D378: 00000000
00A9D37C: 00000000
00A9D380: 00000000
00A9D384: 00000000
00A9D388: 00000000
00A9D38C: 00000000
00A9D390: 00000000
00A9D394: 00000000
00A9D398: 00000000
00A9D39C: 00000000
00A9D3A0: 00000000
00A9D3A4: 00000000
00A9D3A8: 00000000
00A9D3AC: 00000000
00A9D3B0: 00000000
00A9D3B4: 00000000
00A9D3B8: 00000000
00A9D3BC: 00000000
00A9D3C0: 00000000
00A9D3C4: 00000000
00A9D3C8: 00000000
00A9D3CC: 00000000
00A9D3D0: 00000000
00A9D3D4: 00000000
00A9D3D8: 00000000
00A9D3DC: 00000000
00A9D3E0: 00000000
00A9D3E4: 00000000
00A9D3E8: 00000000
00A9D3EC: 00000000
00A9D3F0: 00000000
00A9D3F4: 00000000
00A9D3F8: 00000000
00A9D3FC: 00000000
00A9D400: 00000000
00A9D404: 00000000
00A9D408: 00000000
00A9D40C: 00000000
00A9D410: 00000000
00A9D414: 00000000
00A9D418: 00000000
00A9D41C: 00000000
00A9D420: 00000000
00A9D424: 00000000
00A9D428: 00000000
00A9D42C: 00000000
00A9D430: 00000000
00A9D434: 00000000
00A9D438: 00000000
00A9D43C: 00000000
00A9D440: 00000000
00A9D444: 00000000
00A9D448: 00000000
00A9D44C: 00000000
00A9D450: 00000000
00A9D454: 00000000
00A9D458: 00000000
00A9D45C: 00000000
00A9D460: 00000000
00A9D464: 00000000
00A9D468: 00000000
00A9D46C: 00000000
00A9D470: 00000000
00A9D474: 00000000
00A9D478: 00000000
00A9D47C: 00000000
00A9D480: 00000000
00A9D484: 00000000
00A9D488: 00000000
00A9D48C: 00000000
00A9D490: 00000000
EXCEPT_25_12_2017_0_20.TXT
Error log
 Filename:  EXCEPT_25_12_2017_0_20.TXT
 Filesize:  20.75 KB
 Downloaded:  171 Time(s)
zoohelp
PostPosted: Mon Jan 29, 2018 11:40 am    Post subject: Internal error Reply with quote  Mark this post and the followings unread
Happens randomly in NOD mission 15 - Dusk till Dawn
except.txt
 Filesize:  20.75 KB
 Downloaded:  163 Time(s)
FoxEM
PostPosted: Sun Feb 11, 2018 8:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi,
Game crashed on GDI Mission 08, but unfortunately I don't seem to have any logs or except files to help track this down.
All I can say is it happened at the moment a carryall was dropping a dragonfly, if that helps...
FoxEM
PostPosted: Sun Mar 04, 2018 1:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
And hi again,
GDI mission 11, crashes every time I try to load one of my saved games on it (I have a few, others work)
This time there is an except.log, kinda pointing to dividing by zero  Embarassed
except.txt
 Filesize:  20.67 KB
 Downloaded:  148 Time(s)
PostPosted: Sun Mar 04, 2018 7:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
The saved game is corrupted, there's nothing that can be done about it.
Maslo55
PostPosted: Tue Mar 27, 2018 6:13 pm    Post subject: Internal error shortly after save Reply with quote  Mark this post and the followings unread
I started getting an internal error shortly after I saved my Skirmish game. Happens every time I load it, so the bug is reproducible. The saved game as well as log files (and map settings) are included.
SkirmishSettings.ini
 Filename:  SkirmishSettings.ini
 Filesize:  347 Bytes
 Downloaded:  158 Time(s)
SAVE0029.SAV
 Filename:  SAVE0029.SAV
 Filesize:  2.7 MB
 Downloaded:  155 Time(s)
EXCEPT_27_3_2018_20_4.TXT
 Filename:  EXCEPT_27_3_2018_20_4.TXT
 Filesize:  20.75 KB
 Downloaded:  156 Time(s)
except.txt
 Filesize:  20.75 KB
 Downloaded:  173 Time(s)
stewarty33
PostPosted: Wed Apr 04, 2018 1:08 pm    Post subject: Downloaded TI and keeps crashing Reply with quote  Mark this post and the followings unread
Just downloaded this game really looking forward to playing but keeps crashing when i use TI launcher info as follows
Twisted insurrection has crashed. Error message
HRESULT: [0x887A0022], module:[SharpDXGI], ApiCode:
[DXGI_ERROR-NOT-CURRENTLY-AVAILABLE/NotCurrentlyAvailable]
Message: A resource is not available at the time of the call, but may become available later.
PostPosted: Thu Apr 05, 2018 6:57 am    Post subject: Re: Internal error shortly after save Reply with quote  Mark this post and the followings unread
Unfortunately we couldn't tell much from the logs, as if the error occurred outside the game code. It seems that the save is unrecoverable.
PostPosted: Thu Apr 05, 2018 4:51 pm    Post subject: Re: Downloaded TI and keeps crashing Reply with quote  Mark this post and the followings unread
This is usually caused by graphics drivers.
You can give a try to the XNA version of the client:
1) Download and install XNA Framework Redistributable 4.0 Refresh
2) Go to your TI directory, then to the "Resources" sub-directory, and from there run clientxna.exe
Does the client work then?
PostPosted: Thu Apr 05, 2018 7:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
sounds like a DirectX issue. Maybe old/incompatible/incomplete DirectX installation
Last edited by Lin Kuei Ominae on Thu Apr 05, 2018 7:43 pm; edited 2 times in total
TAK02
PostPosted: Thu Apr 05, 2018 7:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Can this be fixed by side-installing the min-DirectX alongside the game?
Or distrubuting DirectX installer/downloader/link with the game/mod?
One and only developer of the Command & Conquer Dune "C&C D" mod.
m7 wrote:
I tend to release things I create so that assets are never lost to hard drive problems, accidental deletion, or me having to pretend to care about rippers taking things from my project when it is done. #Tongue
View user's profile Send private message Send e-mail Visit poster's website ModDB Profile ID YouTube User URL Twitter Channel URL Skype Account
PostPosted: Thu Apr 05, 2018 7:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
DirectX issues are extremely rare because DX11 has been bundled with Windows ever since Windows 7 (and Vista's Platform Update also includes it). No separate DirectX 11 installer even exists.
Even the few remaining XP users don't need to worry about it, because the client needs .NET Framework 4.0, which needs Service Pack 3, which includes DX9.0c which was the last DX version that was ever released for XP.
Baalthezzar
PostPosted: Thu Apr 05, 2018 9:24 pm    Post subject: failing to load save Reply with quote  Mark this post and the followings unread
Hi guys, I'm playing GDI mission 13, but it won't load. it plays music in the backround while the green txt scrolls down, then it goes blank, and a little while after that the music stops playing and it just sits there, black screen. no mouse, no other controls. I cntl,alt,del and open manager, no mouse shows up, even switching to other programs if i have them running in the bg. i have to arropw down and delete the ti.exe, client is still there and opens right back up once the .exe is shut down. no log files or excepts.txt are generated. i have 4 saves from that map and none of them work. running reduced resolution on my screen, win10 64, some rules.ini changes
SAVE4D06.SAV
save file
 Filename:  SAVE4D06.SAV
 Filesize:  2.63 MB
 Downloaded:  169 Time(s)
PostPosted: Thu Apr 05, 2018 9:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Do you tried the unmodified TI already?
TAK02
PostPosted: Fri Apr 06, 2018 6:03 am    Post subject: Reply with quote  Mark this post and the followings unread
My HP Mini stopped at SP2 #Tongue
I COULD upgrade it, but kinda scared RA2 won't run anymore after that. So I'm not taking the risk.
I'll stick with my Loser10 for DTA & TI instead.
Deadworker
PostPosted: Thu May 17, 2018 6:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey,
im experiencing an Internal Error, i guess it's the same one every time, but i cannot tell for sure, as it seems to be random, or i could not find anything related yet. Im playing in shirmish the "Finale"-Map where i usually try to build up the big fortress to the northwest. Game Mode is Ultimate Insurrection with 2 Allies and 3 Enemys. It happens randomly somehwhat 10-15 minutes after loading my save or 15-20 minutes when starting a new. Im usually just busy with putting buildings to the right spot and enlarging my build-area with light-post-props. I did edit the map a little bit my removing all damaged walls in and around the fortress, but im pretty sure that the error occured before i did that on the original map aswell.
I did upload all 4 except.txt for each occurrence, not sure though if that log-file is what you meant.
Edit: I did at least once save just a couple seconds before the error, but it did not happen right after loading again, but about 10 minutes later.
Edit2: So it seems to be heavily related to the Ultimate Insurrection GameMode. I now startet a new skirmish - Sad - with Timeless Insurrection and i didnt encounter any Internal Error yet, where at Ultimate Insurrection i already had have at least one. It seems aswell, that the AI ist buggy in it, as they mass harvesters at their base(Instant-build is activated) and get stuck, while at Timeless Insurrection they build proper Bases and do not yet stuck around.
Edit3: Well did get an internal error now and i cant even reload the savegames, i always have 2 savegames, which i  am alternately saving on and both give an immediate internal error. that is very frustrating Sad .
 Filesize:  299 Bytes
 Downloaded:  157 Time(s)
TI.LOG
 Filename:  TI.LOG
 Filesize:  7.81 KB
EXCEPT_17_5_2018_19_41.TXT
 Filename:  EXCEPT_17_5_2018_19_41.TXT
 Filesize:  20.75 KB
 Downloaded:  133 Time(s)
EXCEPT_17_5_2018_19_37.TXT
 Filename:  EXCEPT_17_5_2018_19_37.TXT
 Filesize:  20.74 KB
 Downloaded:  135 Time(s)
EXCEPT_17_5_2018_19_9.TXT
 Filename:  EXCEPT_17_5_2018_19_9.TXT
 Filesize:  20.74 KB
 Downloaded:  166 Time(s)
EXCEPT_16_5_2018_14_29.TXT
 Filename:  EXCEPT_16_5_2018_14_29.TXT
 Filesize:  20.75 KB
 Downloaded:  159 Time(s)
Anxoczt
PostPosted: Sun Sep 09, 2018 12:32 pm    Post subject: Crashes Reply with quote  Mark this post and the followings unread
Hi, after receiving my answer from ModDB page i decided to post the crash logs here. Since the skirmish is crashing relentlessly. So relentlessly that i can force the game to crash for unknown reason under a minute.
Not sure how many people reported it before so if my logs will be actually remotely useful.
Also, i got a video, two of them actually. One crashes at one and half minute and the second crashes under one minute. The first one has glitched audio for some reason but the second one sounds normal.
Here is the safe file, sitrep is as you can see that i flanked GDI base and took out the MCV and now i am mopping the rest of the base with my forces. Its 2v2v2 matchup.
Furthermore
No superweapons or support powers
Tech 7
Harvester bounty
Build off ally
Crates
Safe crates
Ion storms can happen
Free radar
Uncrushable infantry
Capturable base defences
crash log related files.zip
Contains all crashes that happened on 6p maps, also contains the save file of the map in the video, the previous crashes are mostly other 6p player maps. Contains the TI.log with the recent crash from the video.
 Filename:  crash log related files.zip
 Filesize:  1.1 MB
 Downloaded:  161 Time(s)
PostPosted: Sun Sep 09, 2018 2:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
This won't help you solve the problem, but might be useful for devs.
Aside from one, all the EXCEPTs in the ZIP are caused by bad pointers. Checking the stack reveals that Is_Techno (maybe checks whether an object is a TechnoType?) gets a bad pointer to an object. Is_Techno is in all these cases called by TechnoClass::Evaluate_Cell. I don't know what this function really does either, but from the name and parameters I can guess that it's related to checking a cell (or its surroundings?) for threats. Checking this against some logs that the staff has sent me before, it seems that this crash is quite common.
The only exception is the crash that happened on 6th happened when trying to allocate memory. Probably not worth looking deeper into.
Dweil89
Guest
PostPosted: Wed Jan 23, 2019 2:26 pm    Post subject: Nod 14 freeze Reply with quote  Mark this post and the followings unread
Nod mission 14 Compulsions keeps freezing, some minutes into the game. No error files are made and windows only reports the problem to Microsoft. I know this is not much to go on, but what I did so far (to no avail) is:
- Disable hardware acceleration
- Update UHD driver
I saw another user on here who was also experiencing the same issue, but it had only one reply on the game speed maybe being the issue, but this didn't help... Any suggestions as to what may fix this?
RoofontheFiddler
PostPosted: Fri Sep 20, 2019 10:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ran into an internal error during "Mechanical Man." Tried approaching the main GDI base when the game crashed on me. Attached are the exception and save files. Also I experienced another internal during "Fields of Green." I crashed when I made $40k. Exception file attached, but I don't have the save because I went into the Nod campaign and overwrote it by accident
EDIT: Made a GDI save regarding the 2nd internal
SAVE6784.SAV
 Filename:  SAVE6784.SAV
 Filesize:  1.5 MB
EXCEPT_20_9_2019_0_20.TXT
 Filename:  EXCEPT_20_9_2019_0_20.TXT
 Filesize:  20.75 KB
 Downloaded:  125 Time(s)
EXCEPT_20_9_2019_18_21.TXT
 Filename:  EXCEPT_20_9_2019_18_21.TXT
 Filesize:  20.75 KB
SAVE18BE.SAV
 Filename:  SAVE18BE.SAV
 Filesize:  1.66 MB
 Downloaded:  182 Time(s)
Last edited by RoofontheFiddler on Sat Sep 21, 2019 7:45 pm; edited 1 time in total
LudiG
PostPosted: Sat Sep 21, 2019 1:08 pm    Post subject: GDI Mission 5 "Fields of Green" - Credit Count Crash Reply with quote  Mark this post and the followings unread
Hi guys, I'm also getting an internal error during GDI TI Mission 5 "Fields of Green" when I approach certain credit counts (it was $40k at first, but with numerous reloads I managed to get to around $50k before crashing again). Seems like maybe some triggers are giving trouble? I've attached the error log and a save game where I'm just under the $50k count that causes the crash.
SAVE5876.SAV
The save game file.
 Filename:  SAVE5876.SAV
 Filesize:  1.5 MB
 Downloaded:  195 Time(s)
EXCEPT_21_9_2019_14_47.TXT
The error log.
 Filename:  EXCEPT_21_9_2019_14_47.TXT
 Filesize:  20.75 KB
 Downloaded:  165 Time(s)
VeNoM4u2
Guest
PostPosted: Sat Sep 21, 2019 8:11 pm    Post subject: Game Crash- GDI Mission 5 Reply with quote  Mark this post and the followings unread
GDI Mission 5 keeps crashing on me. It is a reoccurring crash.  Any ideas on how to fix would be appreciated. I've tried reinstalling as well. Thanks!
https://imgur.com/OIuNy10
V/r,
VeNoM4u2
P.S. Cross posted on thread Bug Tracker but I figure this is probably the more appropriate thread. Thanks!
Talles
Guest
PostPosted: Sun Sep 22, 2019 10:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey I found a bug, on GDI mission 5 the game will crash before the player reach 40000 credits.
Note: Saving and loading before it happens don't work, the game will crash as soon as you load.
There's another one, infantry somethimes will run wen your order to atack, but they Run without leaving the place.
Mod version: the actual one.
Guest
PostPosted: Sun Sep 22, 2019 10:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh and there's also one in Nod mission 8, same problem, the game crash.
PostPosted: Mon Sep 23, 2019 6:22 am    Post subject: Reply with quote  Mark this post and the followings unread
The aforementioned issues with missions GDI 5 and Nod 11 crashing are now fixed in patch 0.8.0.5.
This is the first time I hear Nod 8 crashing, but it's possible the issue was fixed in the same patch.
Marnok
PostPosted: Wed Jun 17, 2020 2:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Figured it out... turns out i'm an idiot Very Happy Do not put the files in the TS folder ^_^
(sorry if i'm not suppose to post like this please move it to the proper section i tried looking around the forums first before posting.)
Hi, new here.
Came across this mod started reading the story was pretty interested to play.
Download, dragged files from zip into ts folder, client works (and updated) tried to play a campaign mission (i tried everything that is in the list) and i keep getting internal error's.
So i swap the Renderer Default-> cnc-ddraw->ts/ie/ddwrapper/ddrawcompat/dxwnd window mode/ borderless compatibility fixes enabled.
and nothing works i keep getting errors.
also skirmish doesn't work.
Like my game engine refuses to work, its a Origin install version of Ts but cncnet works fine on it so did i miss any steps? did i install it wrong even thought the launcher works? its on version 0.8.0.7
My hardware is very up to date i9-9900k
2080 with latest drivers, netframework is installed etc..
Kinda clueless at this point, maybe someone has an idea?
EXCEPT_17_6_2020_4_9.TXT
 Filename:  EXCEPT_17_6_2020_4_9.TXT
 Filesize:  20.6 KB
 Downloaded:  138 Time(s)
TI.log
 Filename:  TI.log
 Filesize:  2.09 KB
PostPosted: Wed Jun 17, 2020 8:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Yep, TI is fully standalone and should be installed to a clean folder. Trying to install it on top of TS will not work.
TAK02
PostPosted: Wed Jun 17, 2020 12:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Why would TI crash when installed on top of TS? Any TS files would be replaced by TI's, and if anything should crash it'd be TS due to user-induced "corruption"?
PostPosted: Sat Jun 20, 2020 8:26 am    Post subject: Reply with quote  Mark this post and the followings unread
No, TI doesn't replace every file of TS, like firestrm.ini, which will corrupt the build.
C&C5PLS
Guest
PostPosted: Tue Jun 30, 2020 4:22 pm    Post subject: NOD 11 (again?) Reply with quote  Mark this post and the followings unread
I have downloaded the latest ver. (0.8.0.7?) and i get an internal error msg when i gain vision of the deepest part of the GDI base.
Jova
Guest
PostPosted: Sun Jul 19, 2020 3:36 pm    Post subject: internal error M.13 GDI Isolation Reply with quote  Mark this post and the followings unread
08.07 GDI m.13 Isolation:
internal error when carryall land and reinfrocements start to move; no informations about files involved
the messiah
Guest
PostPosted: Mon Sep 07, 2020 11:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi guys so I installed TI yesterday and I can not launch any game from the client either campaign or skirmish.
I have tried every render option there is but nothing seems to work all of them except for one give me the error game executable has stopped working.
The only render option that does not give me the error is TS-DDraw but when I choose and try to launch a game the window just dances around a bit then the client opens again.
I have the latest version of TS 0.8.0.7
PostPosted: Tue Sep 08, 2020 8:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Did you install Twisted Insurrection on an empty folder? If you have Tiberian Sun (TS) installed, do not install TI on top of it. TI is standalone, meaning it does not require TS, on the contrary it does not work on top of TS.
ItJustWorks
Guest
PostPosted: Sat Nov 21, 2020 5:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello guys,
Had not played this game in years. The C&C Remastered just put me back in the mood for some C&C action.
Downloaded TI, fresh install in new folder. Launcher works perfect, updates right away.
However, I can't launch anything, be it campaign or skirmish. Screen goes black as in going to load the game, and then "poof", back to launcher. Not even an error message.
What am I missing?
PostPosted: Sat Nov 21, 2020 10:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Have you tried a different renderer? Go to the client (launcher) settings -> Display tab, and select from the Renderer dropdown list. Which renderer works best depends on your system setup, but CnC-DDraw and TS-Ddraw work best on most modern systems.
Guest
PostPosted: Sat Nov 21, 2020 3:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
CnC-DDRaw was the answer. Thanks so much Cirmsonum! Love this community! Love this game!
Richard
Guest
PostPosted: Sun Oct 10, 2021 11:29 am    Post subject: Reply with quote  Mark this post and the followings unread
I am getting an Internal Error crash if I scroll to the lower right corner of GDI Mission 6 (Clean Slate)
jmutt18
Guest
PostPosted: Thu Dec 30, 2021 5:37 am    Post subject: Internal Error on GDI Mission "Walk" Reply with quote  Mark this post and the followings unread
I keep getting an Internal Error 1-2 minutes after I load a save from the Mission "Walk"
I had been able to save/load/etc up until this point but ~1 hour ish into the mission it started to give me internal errors.
jmutt18
Guest
PostPosted: Thu Dec 30, 2021 6:05 am    Post subject: Re: Internal Error on GDI Mission "Walk" Reply with quote  Mark this post and the followings unread
OK! So it 100% happens when a group of Termite APCs shows up on main island base...despite this occurrence happening numerous times previously without issue
KpNuts
PostPosted: Fri Dec 31, 2021 1:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi , When playing Nod Mission 14: Compulsions the game keeps crashing just after the Machinist has entered the NOD temple and the screen tries to move over to the rebel NOD base being attacked by GDI.
The crash logs show it keeps failing because of an "EXCEPTION_ACCESS_VIOLATION"
Crash logs.zip
 Filename:  Crash logs.zip
 Filesize:  80.51 KB
 Downloaded:  180 Time(s)
Tycho452
PostPosted: Sun Jan 16, 2022 3:16 am    Post subject:  Corrupted safe files Reply with quote  Mark this post and the followings unread
Around a third of the time when I save my game the safe file ends up corrupted and can't be loaded.
There is no indication during safe that something went wrong and I can continue to play the game, but when I later try to load my safe I get a divide by zero exception.
I can't find a pattern and it happens in every mission so far.
I tried different render and compatibility settings during loading, but no difference.
EXCEPT_2022_01_15_18_59.TXT
 Filename:  EXCEPT_2022_01_15_18_59.TXT
 Filesize:  20.67 KB
TI.log
 Filename:  TI.log
 Filesize:  7.52 KB
 Downloaded:  170 Time(s)
except.txt
 Filesize:  20.67 KB
 Downloaded:  179 Time(s)
Guest
PostPosted: Tue Sep 05, 2023 6:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Exact same problem, happening years later. Exception report claims it to be an Access Violation when trying to read or write to a virtual address.
[ Time: 0.3247s ][ Queries: 13 (0.0124s) ][ Debug on ]
