The time now is Wed May 22, 2013 4:09 pm
 Forum index » Featured Projects » Twisted Insurrection » Your Input
Minor suggestions
Post new topic   Reply to topic Page 1 of 1 [15 Posts] View previous topic :: View next topic
Vulture
Disk Thrower
PostPosted: Wed Aug 03, 2011 1:43 pm    Post subject:   Minor suggestions Reply with quote
After playing TI extensively last few days (also for the crate bug) came up with a few minor suggestions.
- In a low tech game, a Nod AI got two Stealth Tanks. No way to counter it, and no way to find them. They harassed my harvesters and retreated, and I couldn't detect them until they attacked my deployed Goliaths (something a human would not do Laughing ) - therefore, my suggestion is to lower the tech level requirement for the Mobile Sensor Array (to 2, maybe 3).
- Well, the crate bug; crate effect removement when an unit deploys/undeploys.
Don't say it doesn't happen in TS, because that is irrelevant in TI - and it certainly does happen in TI.
But this might take quite a lot of time to fix, therefore, I suggest it should be mentioned in the TI unit manual, so it at least doesn't suprise people anymore.
PostPosted: Wed Aug 03, 2011 1:57 pm    Post subject: Reply with quote
The crate bug is a hardcoded issue of the engine which we can't fix via a simple ini edit. But yes, it happens in TI as well as in vanilla TS.
None the less, thanks for the feedback. Smile
SHP Artist of Twisted Insurrection. Main Nod building SHP creator.
5 GDI, 5 Nod, 1 Mutant unit, 1 Scrin unit, 1 GDI building
TMP Shop
PostPosted: Wed Aug 03, 2011 4:45 pm    Post subject: Reply with quote
The fact that the AI ignores prerequisites (and in this case, TechLevels) is being worked on Wink
Vulture
Disk Thrower
PostPosted: Wed Aug 03, 2011 5:33 pm    Post subject: Reply with quote
Well, it hasn't anything to do with units being built, but with units being found in crates. The AI obeys the Tech Levels quite nicely, but crates do not...
ChronoSeth
Jumpjet Infantry
PostPosted: Thu Aug 04, 2011 2:55 am    Post subject: Reply with quote
There's no way of fixing that.
Besides, it just means that random vehicles are a more valuable crate in lower-tech games.
Dawn of the Tiberium Age staff member
Vulture
Disk Thrower
PostPosted: Thu Aug 04, 2011 7:03 am    Post subject: Reply with quote
Indeed. However, making the Mobile Sensor Array a low-tech unit would solve at least the Stealth issue. Luckily the AI spends against your forces.
Otherwise there aren't much problems, aside from a Mammoth MK II during low tech games and crates.
PostPosted: Thu Aug 04, 2011 7:08 am    Post subject: Reply with quote
Build 20 Infantry, place them in a line, then let them move forward in their line formation. Voilą, you have a big mobile sensor array and once the cloaked unit is visible, they can also attack it right away.
TMP Shop
Scorched Earth
PostPosted: Thu Aug 04, 2011 7:23 am    Post subject: Reply with quote
Great LKO, you've just suggested exactly what they did in Bosnia with landmines. Razz
Okay, my signature was starting to annoy even me.
PostPosted: Thu Aug 04, 2011 9:47 am    Post subject: Reply with quote
That's a damned expensive Sensor Array. And squishy too.
Lord Unforgiven
PostPosted: Thu Aug 04, 2011 10:31 am    Post subject: Reply with quote
True, but if the Stealth Tank is all that remains of the enemy, why not?
Vulture
Disk Thrower
PostPosted: Thu Aug 04, 2011 11:32 am    Post subject: Reply with quote
In that case you can bring a Goliath or Eclipse with your infantry, or even an entire army of them if you still have a lot of forces left ^^.
However, is the infantry sensor sight that much? It isn't more than four, is it?
Anyway, I don't think anybody is enough of a dick to move the Stealth Tank on the water (and the AI just attacks your forces with them).
PostPosted: Thu Aug 04, 2011 11:41 am    Post subject: Reply with quote
Infantry can detect cloaked units only direct near them on the adjacent cell.
Only the jumpjet can detect them over a longer distance while he is flying.
TMP Shop
PostPosted: Thu Aug 04, 2011 12:39 pm    Post subject: Reply with quote
From my experience, they can detect stealth units while grounded, too.
Vulture
Disk Thrower
PostPosted: Thu Aug 04, 2011 1:35 pm    Post subject: Reply with quote
Exclamation Don't Stealth tanks swat Jumpjets just out of the sky within seconds once they found it? They just move away and are cloaked again (and somewhere else).
But again, I don't think someone is enough of a dick to just lame around with a single stealth tank Razz
PostPosted: Thu Aug 04, 2011 1:56 pm    Post subject: Reply with quote
But only on the directly adjacent cell like any other infantry. The special CloakDetectionRadius, which uncloaks them in a higher radius, works only while the jumpjet is flying.
TMP Shop
[ Time: 0.1830s ][ Queries: 10 (0.0168s) ][ Debug on ]
