The time now is Sat Apr 20, 2024 4:39 am
PRC Building Pack
Moderators: Global Moderators, Media Hut Moderators, OpenRA Moderators, Red Alert 2 Moderators, Tiberian Sun Moderators
Post new topic   Reply to topic Page 1 of 2 [61 Posts] Mark the topic unread ::  View previous topic :: View next topic
Goto page: 1, 2 Next
Mig Eater
PostPosted: Fri Dec 09, 2011 4:35 pm    Post subject:  PRC Building Pack Reply with quote  Mark this post and the followings unread
Here is a pack of Chinese buildings converted from C&C Generals for RA2. They include damage frames, buildups & alternative snow versions. There is also Gfx for the nuke missile so you can make a fully working superweapon.
The War factory & Airfield had to be heavily modified to work in RA2 BTW. I'm not happy with them tho so I'll probably make new ones when I have time.
I'm away for Xmas & new years but once I'm back I'll also convert the GLA & USA buildings from Generals too.
PS: You can find cameos & a sidebar to go with these buildings on my site.
 Filesize:  845.97 KB
 Viewed:  40102 Time(s)
prcbuild.zip
 Filename:  prcbuild.zip
 Filesize:  1.75 MB
 Downloaded:  16520 Time(s)
PostPosted: Fri Dec 09, 2011 4:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
These actually look amazing. Would it be possible to do C&C3 structures?
m7
PostPosted: Fri Dec 09, 2011 5:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
ztype those are good. Ace work, I'm all for spotlighting these bad babies.
Mig Eater
PostPosted: Fri Dec 09, 2011 5:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would presume so, once I'm done with the Generals buildings I'll look into it.
Sir Shockwave
PostPosted: Fri Dec 09, 2011 5:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
I wouldn't spotlight these just yet - unless Miggy has code that wasn't supplied, SHP Builder is showing some fuzziness on some of the animations (specifically, what I presume is the War Factory's buildup sequence).
Otherwise, not bad for a first go.
Krow
PostPosted: Fri Dec 09, 2011 6:12 pm    Post subject: Re: PRC Building Pack Reply with quote  Mark this post and the followings unread
I vote spotlight after you've uploaded the whole set for GLA and USA. Smile
Team Black wrote:
Mig Eater
PostPosted: Fri Dec 09, 2011 6:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
By fuzziness I presume you mean the slight colour variance between frames because I used the the diffusion dither when applying the pal.
TBH... that's just being really picky o.0
Sir Shockwave
PostPosted: Fri Dec 09, 2011 6:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
No, I mean this -
Now this could be my lack of experiance, or it could be the fact no tool of mine ever works properly, or my tool is outdated (i've been using the one from the old page links to YRAG) - but that to me looks like the SHP corrupted somewhere along the way. I get the same result with 90% of the SHP files on Selphir's Stuff - I've found it does present problems when sequencing, especially for Infantry SHP's.
So far, I've only found this animation - the War Factory Build Up - to be doing this.
Cranium
PostPosted: Fri Dec 09, 2011 6:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Must be just you, I just checked them all and everything is fine
and you dont need codes to spotlight something.
Sir Shockwave
PostPosted: Fri Dec 09, 2011 6:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Maybe, I'm not discounting the possiblity, nor do I mean to say these are terrible - they're not, and clearly Miggy worked on them.
May I ask what program version your using to check them? I'm running SHP Builder 3.36.
Cranium
PostPosted: Fri Dec 09, 2011 6:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
I use the same one, 3.36
Check your load settings.
Sir Shockwave
PostPosted: Fri Dec 09, 2011 6:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Load setting set to Supra Load (which apparently restores corrupted files) and Auto Detect Compression. Any closer?
Cranium
PostPosted: Fri Dec 09, 2011 6:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
ues Os Shp Builder Offset Way for loading. You dont need to use Supra unless your trying to load a corrupted shp file.
Oh, and great stuf Mig! Approved
Sir Shockwave
PostPosted: Fri Dec 09, 2011 6:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Seems to have fixed it. I was wondering for ages why I was getting that issue.
So thank you Cranium and my condolences and apologies to Mig Eater.
As a crazy off-topic, I think Mig has a weird sense of timing with this upload - we're a day (two if your from Europe) off from hearing about what many speculate is going to be Generals 2...
...I know it's coincidence, but ztype Mig if your timing isn't uncanny O.O
Mig Eater
PostPosted: Fri Dec 09, 2011 7:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah I see, well I'm sorry if I sounded a bit harsh too.
Sir Shockwave
PostPosted: Fri Dec 09, 2011 7:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's perfectly fine. I'm used to something being wrong with my tools X3
Allied General
PostPosted: Fri Dec 09, 2011 7:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice present =)
Only recommendation would be art code to avoid hassle unless stock is ok
Bu7loos
PostPosted: Fri Dec 09, 2011 7:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ace !!
Edit: Spotlight !!
Darkstorm
PostPosted: Fri Dec 09, 2011 9:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
MUST SPOTLIGHT!
It has everything you need for a faction minus a tactical superweapon, a naval yard and a support structure:
Construction Yard
Power Plant
Refinery
Barracks
Radar Building
Airfield
War Factory
Tech Center
Anti-Infantry Defense
Misc Defense
Advanced Defense
Strategic Superweapon
FistOfFire
Light Infantry
PostPosted: Fri Dec 09, 2011 11:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for taking time to make public assets.
Definitely spotlight.
Looking forward to C&C 3 structures.
Perhaps you could write a tutorial on how to convert generals structures to something that fit RA2(in other words, how you did)? I would like to convert some buildings from Remix.
FurryQueen
PostPosted: Fri Dec 09, 2011 11:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sweet Jesus. This is made of win and epic.
KGR | AT
AZUR
Discord: theastronomer1836
Steam
Mig Eater
PostPosted: Sat Dec 10, 2011 12:04 am    Post subject: Reply with quote  Mark this post and the followings unread
So you want me to show you how to rip assets from other mods... TBH they aren't that hard to convert, anyone with basic 3DS Max skills can do it. It just takes fecking ages tho, took me roughly 30 hours over 3 days to do this set.
@Fen: I was thinking of you & AG when I made this pack, I hope you put it to use #Tongue
FurryQueen
PostPosted: Sat Dec 10, 2011 12:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh. I will be putting it to use as a side project for sure. Very Happy
KGR | AT
AZUR
Steam
Death Cultist
PostPosted: Sat Dec 10, 2011 2:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Does the Nuke silo has firing animations?
Beta Tester for Mental Omega 3.0
PostPosted: Sat Dec 10, 2011 2:46 am    Post subject: Reply with quote  Mark this post and the followings unread
The Propaganda Tower could be improved by the removal of the matte grey bits between the scaffolding.
FistOfFire
Light Infantry
PostPosted: Sat Dec 10, 2011 3:28 am    Post subject: Reply with quote  Mark this post and the followings unread
heywow lets take it easy fella. It is for personal use.
My guess for the time consuming process is that you also converted many animations and the buildups.
Doing buildings only(damage frame, no buildup) shouldn't take much time
Translator
PostPosted: Sat Dec 10, 2011 4:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Better than mine Smile
Nikademis Von Hisson
PostPosted: Sat Dec 10, 2011 4:11 am    Post subject: Reply with quote  Mark this post and the followings unread
If these came from generals, any chance you can put the actual models up?
Dragon Prime
PostPosted: Sat Dec 10, 2011 5:25 am    Post subject: Reply with quote  Mark this post and the followings unread
it's...it's amazing~
Tiberian Tear is making, and I will try my best.
MadHQ
PostPosted: Sat Dec 10, 2011 6:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice!!
MadHQ's Graveyard - Click here!
(Permissions) - (F.A.Q.)
Mig Eater
PostPosted: Sat Dec 10, 2011 9:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Yep, everything you need to make a SW.
I presume it's possible to do that with a mask or something, but ATM I'm unsure how.
All you need to do is extract the W3D files from the game & then run a import script in 3DS Max.
kenosis
PostPosted: Sat Dec 10, 2011 10:06 am    Post subject: Reply with quote  Mark this post and the followings unread
that is the script.
w3dimporter.rar
 Filename:  w3dimporter.rar
 Filesize:  9.49 KB
 Downloaded:  504 Time(s)
Tired of grabbing my random SHP conversions? Why not learn to create SHPs for yourself?
View user's profile Send private message Send e-mail Visit poster's website Skype Account Yahoo Messenger Account
PostPosted: Sat Dec 10, 2011 5:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Funny to see that after all these years, only now someone has remade the Generals structures as SHP's. No offence Miggy #Tongue
PostPosted: Sat Dec 10, 2011 6:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Fantastic!
PostPosted: Sat Dec 10, 2011 6:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some issues i noticed
-nggatt_a.shp doesn't rotates even by 11.25° at each frame. Some frames it's faster and others it's slower, which will make it ingame face slightly aside on some directions.
-some buildings move at the last buildup frame slightly to one direction, which looks strange. e.g. ngbarkmk moves at the last frame to northeast by about 1 pixel. ngbunkmk 1 pixel to southwest.
-all the buildup anims could be much better. Instead of raising the whole building, you should have used a slice modifier in 3dsmax, where you move the slice plane upwards and let it only show the model below the plane. This way the plane moves like an invisible barrier upwards, revealing more and more of the building, which makes it look like it is really build up. Or split the building in several parts, which will the build up at different frames.
Other than that nice job.
Do you made the damage frames or did the model had them already?
Last edited by Lin Kuei Ominae on Sun Dec 11, 2011 9:56 am; edited 1 time in total
kenosis
PostPosted: Sat Dec 10, 2011 8:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Volgin
PostPosted: Sat Dec 10, 2011 9:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
One request mig, one. Could you convert the militia tank (the t-54) to voxel? otherwise, totally epic set.
Victory!
PostPosted: Sat Dec 10, 2011 9:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
MasterHaosis
PostPosted: Sat Dec 10, 2011 11:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Spotlight! Nothing more to say.
PPM Halloween Season 2021
PostPosted: Sun Dec 11, 2011 9:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Spotlighted.
Though i would still like to see the issues fixed, which i've mentioned above.
Mig Eater
PostPosted: Sun Dec 11, 2011 10:12 am    Post subject: Reply with quote  Mark this post and the followings unread
@Dutchy: I know, I only just stared using 3DS Max & I managed to do it, why hasn't anyone else bothered before now!
@LKO:
I animated the turret to turn 360o over 33 frames & that's what I got #Tongue
I only had a few days to make this pack, otherwise I would have spent longer on the buildups. I feel they are ok for now tho, after all most buildings for d/l don't even come with buildups.
Starkku
PostPosted: Sun Dec 11, 2011 10:45 am    Post subject: Reply with quote  Mark this post and the followings unread
I've noticed that atleast for me, just doing 32 frame 360° rotation animation causes that particular issue, where all turns are not 11.25°. Not an expert user of Max so haven't bothered to figure out why it does that so I'll just rotate it by 45° every 4 frames and it works fine.
kenosis
PostPosted: Sun Dec 11, 2011 10:53 am    Post subject: Reply with quote  Mark this post and the followings unread
use 32 key frames,each 11.5o,and you will get a perfect rotation anim.
Cranium
PostPosted: Sun Dec 11, 2011 9:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was converting Generals stuff last year, and actually have quite a bit of stuff rendered, just not in .shp form yet. I was making them for Aro and some reason just fell away from it. There are a couple of things for download from Generals that i posted already. Razz
For the turret thing. The easiest way to do it for me is, set your turret facing North, click autokey, scroll the animation time line to frame 32, rotate your turret 380* degrees, untick the autokey and you have your rotation frames. just remember to delete the last frame so you'll only have 32 frames. "Max frames start at 0"
Oh, and congrats on the spotlight. Razz
Gangster
PostPosted: Sun Dec 11, 2011 10:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
and dont forget to switch keyframe's animation to be linear. otherwise angle betwin each rotation stage will be not equal. MAX sets smoth keyframes by default.
4StarGeneral
PostPosted: Mon Dec 12, 2011 12:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Gangster wrote:
and dont forget to switch keyframe's animation to be linear. otherwise angle betwin each rotation stage will be not equal. MAX sets smooth keyframes by default.
0-31 frames, and this ^. Default autokey anims accelerate in beginning/decelerate at the end.
"Don't beg for things; Do it yourself or you'll never get anything."
View user's profile Send private message Send e-mail YouTube User URL
Machine
PostPosted: Mon Dec 12, 2011 1:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Just adding something to what gangster said.
Max defaults the keyframe tangents to soft, so the animation accelerates at the start and deaccelerates at the end (which is quite nice for deploying animations).
In the case of rotation, this would mean that it won't turn the same amount of degrees with each frame.
You can set the tangents to linear to fix this. To do so just change the option in the button that's to the right of "set key".
Alternatively, you can open the "mini curve editor" (to the left of the keyframes and time slider), select the keys that you want to turn linearly and set their tangents to linear.
Though making it turn 11.25º manually is probably a better idea.
Allied General
PostPosted: Sat Dec 31, 2011 2:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
cool stuff =)
 Filesize:  268.18 KB
 Viewed:  39191 Time(s)
Speeder
PostPosted: Sat Dec 31, 2011 4:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hah, terrain makes a big difference. They look so much better with Mig's grass in the background.
mentalomega.com
Zengar_Zombolt
Plasma Trooper
PostPosted: Wed Jan 11, 2012 8:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is there a Naval yard?
I am Zengar Zombolt, The Sword That Cleaves Evil!
There is Nothing I can not Cut!
Post new topic   Reply to topic Page 1 of 2 [61 Posts] Goto page: 1, 2 Next
[ Time: 3.7193s ][ Queries: 15 (3.4311s) ][ Debug on ]
