The time now is Sat May 25, 2013 10:23 am
 Forum index » Modding Central » Media Hut » SHPs
Amphibious Engineer (a little help for new modders)
Moderators: Global Moderators, Media Hut Moderators, Red Alert 2 Moderators, Tiberian Sun Moderators
Post new topic   Reply to topic Page 1 of 1 [17 Posts] View previous topic :: View next topic
geof101
PostPosted: Tue Jun 12, 2012 12:42 am    Post subject:   Amphibious Engineer (a little help for new modders) Reply with quote
just a little help for the new modders Smile
hope it'll help a little
[EngineerSequence]
Ready=0,1,1
Guard=0,1,1
Prone=86,1,6
Walk=8,6,6
FireUp=164,6,6
Down=212,2,2
Crawl=86,6,6
Up=228,2,2
FireProne=164,6,6
Idle1=56,15,0,S
Idle2=71,15,0,E
Die1=134,15,0
Die2=149,15,0
Die3=0,1,1
Die4=0,1,1
Die5=0,1,1
Paradrop=244,1,0
Cheer=245,8,0,E
Panic=8,6,6
Tread=253,6,6
Swim=301,6,6
WetAttack=350,6,6
WetIdle1=397,15,0,S
WetIdle2=412,15,0,E
WetDie1=427,15,0
WetDie2=447,15,0
engineer.shp
 Filename:  engineer.shp
 Filesize:  219.99 KB
 Downloaded:  219 Time(s)
PostPosted: Tue Jun 12, 2012 7:34 am    Post subject: Reply with quote
Remove the attack frames. Or just change the sequence.
 Filesize:  546.99 KB
 Viewed:  1985 Time(s)
Zenothist wrote:
I would like to add very quickly that the 'Magnetit' tank is the best name for a tank. Ever.
PostPosted: Tue Jun 12, 2012 11:40 am    Post subject: Reply with quote
One day someone will shop the suitcase in there.
PostPosted: Tue Jun 12, 2012 2:19 pm    Post subject: Reply with quote
Or make a totally new SHP with one who's riding an inflatable raft...
Technically you could argue he straps the suitcase onto his chest/back along with the scuba gear.
~~~Stay calm & be one with Yuri~~~
You can call me Jem if my Username is too long.
~Peace through Ponies
PostPosted: Tue Jun 12, 2012 2:27 pm    Post subject: Reply with quote
I require this engineer to now have a raft.
PostPosted: Tue Jun 12, 2012 2:32 pm    Post subject: Reply with quote
Someone get Rami or Mad to make us a new amphibious engineer. #Tongue
PostPosted: Tue Jun 12, 2012 2:38 pm    Post subject: Reply with quote
I think i can come up with something for it...
Yey for Lao Tze...
And then just give one of those water explosions as it's death anims...
And it's Idle Frames will be the same one but with the Water Wake being layered underneath... I'll see what i can do.
Edit: I know the North one is a bit lower, I'll be fixing that on the final one.
Whoosh...
 Filesize:  4.97 KB
 Viewed:  1918 Time(s)
PostPosted: Wed Jun 13, 2012 7:51 am    Post subject: Reply with quote
That is very nice. Approved
PostPosted: Wed Jun 13, 2012 8:11 am    Post subject: Reply with quote
The rubber raft should be smaller so 3 on the same cell don't overlap each other that much.
Also nice would be a paddle animation. Smile
SHP Artist of Twisted Insurrection. Main Nod building SHP creator.
5 GDI, 5 Nod, 1 Mutant unit, 1 Scrin unit, 1 GDI building
TMP Shop
PostPosted: Wed Jun 13, 2012 9:16 am    Post subject: Reply with quote
It's supposed to be a motor boat. Very Happy
I use TS-size infantry anyway so they're slightly smaller for my mod... Laughing
Infantry seem to be unable to use a water wake... so i'll have to probably to give it a custom swim animation (Bubbly Foams from the back motor) or find a workaround...
Also from what i've seen so far during my tests you'll need to make a clone of each one for each side for this one. (Image=XXX doesn't seem to work properly for this)
PostPosted: Wed Jun 13, 2012 5:53 pm    Post subject: Reply with quote
Pretty sure there was already a dinghy Engineer and Boris made somewhere several years ago, possibly by Lefthand.
PostPosted: Thu Jun 14, 2012 2:46 am    Post subject: Reply with quote
Any links to it?
I'll probably finish this one today or tomorrow and i'll upload it.
geof101
PostPosted: Thu Jun 14, 2012 1:40 pm    Post subject: Reply with quote
nice, it's better Smile
PostPosted: Wed Jun 27, 2012 4:30 am    Post subject: Reply with quote
@Noodles: I demand my raft-engineer. #Tongue
PostPosted: Wed Jun 27, 2012 4:55 am    Post subject: Reply with quote
It has no death animation but it has the Raft as its Water Frames...
[EngineerSequence]
Ready=0,1,1
Guard=0,1,1
Prone=86,1,6
Walk=8,6,6
FireUp=164,6,6
Down=212,2,2
Crawl=86,6,6
Up=228,2,2
FireProne=164,6,6
Idle1=56,15,0,S
Idle2=71,15,0,E
Die1=134,15,0
Die2=149,15,0
Die3=0,1,1
Die4=0,1,1
Die5=0,1,1
Paradrop=244,1,0
Cheer=245,8,0,E
Panic=8,6,6
Tread=253,1,1
Swim=253,1,1
WetDie1=253,1,1
WetDie2=253,1,1
You'll need to make 3 seperate Engineers for each version, The palette gets messed up somehow on the YENGINEER & SENGINEER if you use Image tag.
And on the Infantry replace/add the following tags...
SpeedType=Amphibious
Locomotor={4A582744-9839-11d1-B709-00A024DDAFD1}
MovementZone=AmphibiousDestroyer
EnterWaterSound=TanyaEntersWater
LeaveWaterSound=TanyaLeavesWater
P.S. The Engineer is Tiberian Sun Size (ala 25% smaller than RA2 ones) and I forgot to back up one in RA2 Size... Razz
engineer.shp
 Filesize:  86.11 KB
 Downloaded:  161 Time(s)
Krow *lazy to login*
PostPosted: Wed Jun 27, 2012 9:19 am    Post subject: Reply with quote
Could you also attach the clean raft images? I'd like them too please. Very Happy *too lazy to login. Posting through my phone atm.
PostPosted: Wed Jun 27, 2012 10:28 am    Post subject: Reply with quote
http://graveyards.cncguild.net/LaoTze/raft.zip
It's in PCX...
[ Time: 0.2138s ][ Queries: 18 (0.0314s) ][ Debug on ]
