The time now is Tue Apr 23, 2024 7:10 am
Finalsun Singleplayer map help
Nightwolf117
Chameleon Spy
PostPosted: Thu Sep 19, 2013 7:39 am    Post subject:  Finalsun Singleplayer map help
Subject description: How do i play a custom singleplayer map that i have created?
Hello, I'm having trouble figuring out how to play a map i have created in final sun, It is a single-player map and i have tried the 2 ways the manual said to save it and play it but it must be different for the twisted insurrection mod for tiberian sun.
Sorry if this is posted in the wrong part of the forum, I am new here and i don't really know much about forums.
Q45
Tiberian Fiend
PostPosted: Thu Sep 19, 2013 11:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Rename the map to g1.map and start a new GDI campaign. Or n1.map and start the Nod campaign.
Twisted Insurrection's Lead Campaign Developer
PostPosted: Thu Sep 19, 2013 12:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Q is correct. We don't use the standard gdi1a.map/nod1a.map filenames.
Darkstorm
PostPosted: Thu Sep 19, 2013 3:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, it is different. As mentioned before you can name it to g1.map (for GDI) or n1.map (for Nod), or you can extract and edit the battle.ini to append it to the list separately.
By the way, TI has it's own version of FinalSun iirc. It's going to be a little more compatible than normal old FinalSun. (Looking around I don't see it so I don't know where to get it but that's what I'm using.)
[ Time: 0.1592s ][ Queries: 11 (0.0073s) ][ Debug on ]
