The time now is Thu Apr 25, 2024 5:02 am
New Allied Sidebar [YR] (Ares!)
Moderators: Global Moderators, Media Hut Moderators, Red Alert 2 Moderators, Tiberian Sun Moderators
Dawe
PostPosted: Tue Oct 15, 2013 1:11 pm    Post subject:  New Allied Sidebar [YR] (Ares!)
Subject description: Dark blue colored sidebar buttons with a new radar animation.
New sidebar for Allied. Only works with Ares!
You have to add this tag:
->[GDI]
Sidebar.YuriFileNames=yes
 Filesize:  293.62 KB
 Viewed:  3049 Time(s)
allied-sidebar.zip
 Filename:  allied-sidebar.zip
 Filesize:  565.44 KB
 Downloaded:  123 Time(s)
Darkstorm
PostPosted: Wed Oct 16, 2013 3:15 am    Post subject: Reply with quote  Mark this post and the followings unread
I assume the change is only the radar? Does it animate?
Atomic_Noodles
PostPosted: Wed Oct 16, 2013 3:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks more purplish as well though.
~ Excelsior ~
Darkstorm
PostPosted: Wed Oct 16, 2013 3:52 am    Post subject: Reply with quote  Mark this post and the followings unread
You're right. Although it looks a bit more closer to the RA1 Allied color.
Dawe
PostPosted: Wed Oct 16, 2013 12:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
The buttons are darker than the original and yes, the radar is animated.
Dawe
PostPosted: Fri Nov 22, 2013 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
2 shp files (pbeacon.shp, rdrbeacn.shp) are missing from the previous upload.
This is the fix!
allied-sidebar-fixed.zip
 Filename:  allied-sidebar-fixed.zip
 Filesize:  570.84 KB
 Downloaded:  55 Time(s)
Dawe
PostPosted: Fri Nov 22, 2013 10:18 am    Post subject: Reply with quote  Mark this post and the followings unread
If somebody doesn't like the new radar anim, this is the version with original radar.
 Filesize:  242.69 KB
 Viewed:  2692 Time(s)
allied-sidebar-original-radar.zip
 Filename:  allied-sidebar-original-radar.zip
 Filesize:  506.85 KB
 Downloaded:  71 Time(s)
[ Time: 0.1532s ][ Queries: 15 (0.0110s) ][ Debug on ]
