The time now is Thu Apr 25, 2024 6:57 am
Map editor not working
Sharpshooter
PostPosted: Sat Nov 23, 2013 3:46 am    Post subject:  Map editor not working Reply with quote  Mark this post and the followings unread
I was trying to use the map editor that came in the TI folder that I downloaded, but when I tried opening it it said TibSun.mix could not be loaded. How do I fix this?
Scorched Earth
PostPosted: Sat Nov 23, 2013 4:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Open up the TI folder, and inside the folder that contains the map editor, open FinalSun.ini in wordpad.
Under [TS], edit the line to reflect the location of TI.
For example, mine is "Exe=C:\Users\Christopher\Desktop\TI\TI_Launcher.exe" because my TI folder is located on my desktop.
Hope that helped!
EDIT: If yours is on your desktop too, just copy and paste the location of my TI and replace my name with your username and replace the line under [TS] with that and it should work as well.
Okay, my signature was starting to annoy even me.
Sharpshooter
PostPosted: Sat Nov 23, 2013 5:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Tried what you said, still doesn't work. Same error message.
RP
PostPosted: Sat Nov 23, 2013 3:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Probably registry entry.
/ppm/'s stupidity
Zaaz
Disk Thrower
PostPosted: Sat Nov 23, 2013 11:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
The directory path you set in the .ini must contain the .exe AND TibSun.Mix.
Is that right?
RP
PostPosted: Sun Nov 24, 2013 1:08 am    Post subject: Reply with quote  Mark this post and the followings unread
No, only the EXE name like: "C:\Westwood\Tiberian Sun\SUN.EXE", though in registry that does not matter (adding SUN.EXE), so it might not matter here either.
The problem might be in his registry.
/ppm/'s stupidity
[ Time: 0.1497s ][ Queries: 11 (0.0075s) ][ Debug on ]
