The time now is Thu Apr 25, 2024 3:44 pm
Starting Funds In Skirmish Mode PB5
Post new topic   Reply to topic Page 1 of 1 [11 Posts] Mark the topic unread ::  View previous topic :: View next topic
isaac103
PostPosted: Sun Jul 20, 2014 9:38 pm    Post subject:  Starting Funds In Skirmish Mode PB5
Subject description: Not enough starting funds in skirmish to fully enjoy the match
Can someone please tell me why I am constantly running out of cash? Seems like my harvesters don't have enough storage space to carry enough tiberium back to their refineries.....can the mod be updated to increase the amount of starting cash from 1000 to maybe 5000 or more?
PostPosted: Sun Jul 20, 2014 9:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Build more refineries. Something like 5 refineries (with 5 harvesters - don't build any extra from the War Factory) should be sufficient most of the time. And 10 000 is a good amount of starting cash, leaving room for making an early rush but also forcing you to take care of your economy.
isaac103
PostPosted: Sun Jul 20, 2014 9:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Was that the same case with the vanilla game too? It's been quite a while since I've played Tiberium Sun.......
DoMiNaNt_HuNtEr
PostPosted: Sun Jul 20, 2014 10:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
You need to get 5 refs up asap. You could still rush with a couple tanks and an engy while you get your economy going.
IN-GAME NAME: MAKINTOKE
PostPosted: Sun Jul 20, 2014 10:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, it was, for the most part. The only real difference is that some tiberium types are actually more valuable in TI, tiberium grows faster in TI, and having multiple factories gives you higher production speed in TI (having multiple factories had no effect on production speed in TS).
PostPosted: Sun Jul 20, 2014 10:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
TI is much faster paced than TS and resource collecting is also much quicker as TS annoyed the life out of me for being such a slow build-up at times. You'll get it eventually!
Nordos
Cyborg Cannon
PostPosted: Mon Jul 21, 2014 8:17 am    Post subject: Reply with quote  Mark this post and the followings unread
I think the downtime in harvesthing tib fields could be because of the 'tiberium spawner'.
Let me try to explain what I mean: When in TS you harvested a field, the tiberium tree would spawn a full tiberium patch. In TI, to make it a bit more realistic, there is a spawner which covers a large area, creating Tiberium via Debris. Since Tiberium created by Debris is always the first stage of Tiberium, it doesn't wield that much money - and somtimes the Tiberium spawned in this way will block the tiberium spawned by the Tiberium Trees.
Thats what I think anyway. Otherwise, when the field is completely full, it gives more money then in TS.
So, yeah, I've created a new acc. 'cause no one could remember Ordosherrscher - and I didn't like that name anyway.
[TiberianFuture]
Scrin Overlord
PostPosted: Mon Jul 21, 2014 9:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Rampa, are you trolling the noobs? #Tongue
Get two or max three refineries and two extra harvs each and you're good.
The unload time is so short that you could probably run even more harvs per ref. No need to build refs that simply aren't used for most of the time.
Check out some TF Kane's Wrath action:
Tournament 3rd place.
Vs. bikeRushOwnz in tournament.
Ladder wars vs. bikeRushOwnz.
PostPosted: Mon Jul 21, 2014 9:10 am    Post subject: Reply with quote  Mark this post and the followings unread
2 harvs on 1 ref is always bad. 1 harv with a long route and on his way back can block for ages the other harv, which is standing already right next to the ref.
While building harvs, you block your warfactory from building something useful like tanks.
Refineries on the other hand can be build parallel, next to the tanks producing warfactory.
[TiberianFuture]
Scrin Overlord
PostPosted: Mon Jul 21, 2014 9:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Don't long distance harvest/leech fields and there's no problems.
Building refs blocks you from teching up, which is more important than getting a few low-tier tanks. Infantry can be used to fend off early rushes.
PostPosted: Mon Jul 21, 2014 7:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Twisted Insurection update PB5.007 available via the launcher. This update adds some extra credits options for Skirmish and Online players (as requested) and fixes some problems in GDI Mission 11.
View the complete changelog here: http://ti.ppmsite.com/updates/changelog.txt
[ Time: 0.1435s ][ Queries: 11 (0.0079s) ][ Debug on ]
