The time now is Fri Apr 19, 2024 6:58 pm
NCO Bug (PB5.029)
Re:Specto
PostPosted: Sun Aug 10, 2014 11:26 am    Post subject:  NCO Bug (PB5.029)
Subject description: "New construction options" bug Nod with GDI MCV
Hi PPM/TI
I just discovered the evil NCO Bug in the new TI (PB5.029)
it happens with Nod if you don't have nod mcv, and you capture a GDI MCV,
it will show the Nod "Hall of Faith" in the buttom of the list, but it is unbuildable.
every building you build will give you the evil fake "New construction options" Twisted Evil
steps to reproduce:
play nod mission 05: the sea of sand
capture the GDI MCV in the middle-top of the map
build anything.
saved game attached
SAVE26E9.SAV
 Filename:  SAVE26E9.SAV
 Filesize:  2.09 MB
 Downloaded:  17 Time(s)
luxycomplex
PostPosted: Sun Aug 10, 2014 11:22 pm    Post subject: Not found Reply with quote  Mark this post and the followings unread
Updating to the new TI (PB5.029) ...
I just replay your saved file and I don't find the supposed bug...
The only weird thing I found is a GDI harvester that got stuck over tiberium field at the north edge of the map... Question
...and those pesky annoying floater attacking your harvester... Laughing
Make sure you are not using edited/modified the rules.ini...
Good hunting on those GDI+Globotech oppressor... Very Happy
Die with GDI+Globotech... Mad
Re:Specto
PostPosted: Mon Aug 11, 2014 1:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
hmm that's wired bro
have you tried to build something? have you seen the nod "hall of faith" at the end of the building list afterward? no NCO? maybe try to restart the level and reproduce it yourself
and no I haven't edited anything, the gave is fully stock!
BTW, AFAIK the rules.ini (and other major ini setting) in TS and RA2 ( so I assume in TI too) is carried over with the savegame anyway...
FYI i've been modding TS and RA2 alot back in the day so, worry not you ain't dealing a n00b here bro  Cool
anyway, I captured a video of the bug, so when it finish uploading finally (damn my ISP! #evil ) I"ll post it here so you can take a look
3 Hours later....
Edit: OK here we go: https://www.youtube.com/watch?v=ksWH5__g5dI
[ Time: 0.1559s ][ Queries: 13 (0.0083s) ][ Debug on ]
