The time now is Tue Apr 23, 2024 10:34 pm
SOME THINGS THAT ARE MISSING
adamstrange
Tiberian Fiend
PostPosted: Thu Dec 25, 2014 9:02 pm    Post subject:  SOME THINGS THAT ARE MISSING Reply with quote  Mark this post and the followings unread
In the editor there are some objects that don't appear when you select them.
The Coastal Gun Battery
The Coastal Machine Gun Battery
Also what do the Sensor Tower and Windlmill do ?
PostPosted: Fri Dec 26, 2014 10:59 am    Post subject: Re: SOME THINGS THAT ARE MISSING Reply with quote  Mark this post and the followings unread
That's right, if you place those two buildings in a map, they will be visible ingame. The entire building image is composed of a single turret animation, which is not shown in the map editor.
The Sensor Tower detects subterranean and cloaked objects (if I remember correctly), and the Windmills generate a little power.
adamstrange
Tiberian Fiend
PostPosted: Sun Dec 28, 2014 1:07 am    Post subject: Reply with quote  Mark this post and the followings unread
I placed the buildings and they work but for some reason you can't capture them.
Another thing that's missing is the globotech ambulance and the surveillance drone.
Ok I figured out how to capture them.
[ Time: 0.1272s ][ Queries: 11 (0.0070s) ][ Debug on ]
