The time now is Fri Apr 19, 2024 8:41 am
IDEAS FOR UPGRADES
adamstrange
Tiberian Fiend
PostPosted: Thu Dec 25, 2014 10:14 pm    Post subject:  IDEAS FOR UPGRADES Reply with quote  Mark this post and the followings unread
The Tiberium Monitoring Station once captured can be used to give access to a harvester that's more expensive but can carry double the load and has a small cannon.
The Globotech Warehouse could also be used, once captured to also allow to build the the Globotech Walls.
The Armory should allow to build all the Globotech stationary weapons.
What do you guys think.
PostPosted: Fri Dec 26, 2014 10:48 am    Post subject: Re: IDEAS FOR UPGRADES Reply with quote  Mark this post and the followings unread
Harvesters with weapons will conflict with their harvesting logic. Also, the Tiberium Monitoring Station is simply a map prop, not meant to be capturable.
I thought it allows construction of GT vehicles? The Armory might be better for granting GloboTech walls. But even then, do you really need to build the security walls when you have regular GDI/Nod concrete walls? Unless you mean the City Protection walls, but those might be too big to let the player build them.
Maybe, but they currently have no build-up animations.
[ Time: 0.1791s ][ Queries: 11 (0.0081s) ][ Debug on ]
