The time now is Fri Apr 19, 2024 10:11 am
Features that CAN'T be implemented for some reason
Moderators: Reaperrr, red_rebel
Post new topic   Reply to topic Page 1 of 1 [28 Posts] Mark the topic unread ::  View previous topic :: View next topic
Reaperrr
PostPosted: Sun Jun 26, 2005 9:47 pm    Post subject:  Features that CAN'T be implemented for some reason Reply with quote  Mark this post and the followings unread
- airstrike (TS doesn't have the necessary code)
- TD-style transport helicopters (transport logic was f***ed up with TS patch 2.0x)
- singleplayer campaign (lack of time)
Clarkson
PostPosted: Mon Jun 27, 2005 12:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Morpher. im working on the visceroid so it works/moves EXACTLY like the TS one,yet uses the TD ones image,by the way. its a huge fuckin copy/paste job though.
DoMiNaNt_HuNtEr
DAMN!!!!! Those features are C-R-I-T-I-C-A-L for ultimate success with this TC..... Damn. Oh well.
But, why don't U have enough time for the campaign? Tis summer holidays man. PLUS, U could easily look back at the original TD campaign, so thinking up ideas shouldn't be a problem.
IN-GAME NAME: MAKINTOKE
Clazzy
Karma Police
PostPosted: Mon Jun 27, 2005 7:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Reaperr, to fix the patch could you not use a modified version of an older game.exe instead? However, you'd probably get more online issues whilst playing, or TS may become compelled to update itself, I'm not sure.
XxpeddyxX
PostPosted: Mon Jun 27, 2005 8:38 am    Post subject: Reply with quote  Mark this post and the followings unread
ayylmao on Discord
Anderwin
PostPosted: Mon Jun 27, 2005 10:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Reaperrr
Can't you just make a building some the air come and blow. like some 1 did whit superweapon in YR.
Make a build or a singnal and then the air bomb the build ! but the enemy much kill the building first that's was some 1 some did i think Embarassed
Can you hide from me Wink?
Reaperrr
PostPosted: Tue Jun 28, 2005 10:09 am    Post subject: Reply with quote  Mark this post and the followings unread
pre-2.0x exes of TS have much less flexible support for ecache/expand mixes, for example I could only get sounds work when putting them into sounds.mix, not ecache. Also, older versions of TS won't support some features like BurstDelayX. Support for the custom Main Menu would be lost, too.
Plus the issues you mentioned above.
@others: TS isn't YR. things like airstrikes would need to be coded into the exe. EVEN if I knew how to code an airstrike, it wouldn't be possible to implement it without the TS source code, which will most probably never get released to public.
OutOfAmmo
PostPosted: Fri Jul 01, 2005 5:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
What about the helicopter rotor animation for the siege copter and parachute deflating(RA2/YR)? Are those possible?
Man, I hope that open-source petition works Wink
RS Name: Skittles22. Everything else: OutOfAmmo
"Yes, I love technology, but not as much as C&C...but I still love technology, always and forever"
Tyler Adams
PostPosted: Fri Jul 01, 2005 7:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
No. You can't make rotors spin withouth glitches.
"Banned" RP here
PUOJACKZ
PostPosted: Mon Jul 04, 2005 11:05 am    Post subject: Re: Features that CAN'T be implemented for some reason Reply with quote  Mark this post and the followings unread
IMHO, you could creare a little new version of the game, with "Single Player Mission" option, in the main menu, available. Doing this, you could let the other player to create some solo-player missions (maybe the same of the TD game?), without you need to work on them (if you don't have time to spend on these ones).
Reaperrr
PostPosted: Mon Jul 04, 2005 11:45 am    Post subject: Re: Features that CAN'T be implemented for some reason Reply with quote  Mark this post and the followings unread
I don't like to do that, since as long as there aren't any missions yet you'll get internal errors when clicking on the button.
Besides that, it can quite easily be enabled, you just need to extract the newmenu.ini and enable the button there (currently it's just commented out with an ';' ).
No need to release an extra version of the mod.
Jah
PostPosted: Mon Jul 04, 2005 9:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Actually TD-style trasport helicopter is possible but:
It needs an shp image (so double rotors would work);
It must be a vehicle type and produced from a factory;
It must use a jumpjet locomotor and therfore be invincible in the air.
The last fact is the worst I suppose. Its still up to you if you want it to do this way.
in 2009 to Florence. Viva Italia!
PUOJACKZ
PostPosted: Thu Jul 07, 2005 12:44 pm    Post subject: Re: Features that CAN'T be implemented for some reason Reply with quote  Mark this post and the followings unread
The important point of the discussion is: the modders must known of this little patch, in order to start creare some solo-player mission, for this incredible TC. So, probably, is good make an official post, saying about how to turn on this feature.
Maybe with the hope to see some solo players maps, in the next future.
Clarkson
PostPosted: Fri Jul 08, 2005 2:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Nyerguds' leet chem lab missions in RoTD would...well...own. Smile
PUOJACKZ
PostPosted: Fri Jul 08, 2005 10:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think, in this way, that GunBoat won't be available too. Maybe, could be introduced in any future MODs of ROTD...
PostPosted: Wed Aug 03, 2005 7:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
lol. Prob is I don't know anything about TS mission making, Carno.
Painkiller
PostPosted: Thu Aug 04, 2005 7:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Can't you figure somethin out to make airstrikes work? after all Worm came up with a way to put RA2 Nuke in TS with that coding
christophski the great
PostPosted: Fri Aug 05, 2005 9:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Singer-Songwriter Christie Isaac
j4m3sb0nd
PostPosted: Thu Aug 11, 2005 10:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, Drop pods are very durable when it comes to 'reinforcements' or air attacks. Wink
Jah
PostPosted: Fri Aug 12, 2005 4:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Easier than anything... Just create a ship locked on its path. Remember, it wasn't even buildable.
X-Trade
PostPosted: Fri Aug 12, 2005 11:15 am    Post subject: Reply with quote  Mark this post and the followings unread
the airstrike coult be re-created..... not to exactly the same effect, but maybe you could just have a buildable A-10, that fires 6 or 7 napalm missiles (as opposed to dropping bombs, as that does not work in TS)
i tried making aircraft by making very fast helicopters, and it is similar, except they circle the target and take hours to land.
but buildable a-10s is better than no airstrike whatsoever!
http://www.AoFP.co.uk - Home of the Alliance Of Freelance Programmers, my post-modding computing efforts, (allthough theres much more than just whats on that site!)
Reaperrr
PostPosted: Fri Aug 12, 2005 4:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
umm, it doesn't? since when? Wink *thinksoforcabomber*
Remus
Rocket Cyborg
PostPosted: Fri Aug 12, 2005 6:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Anderwin wrote:
Reaperrr
You're thinking of the Fake Super Weapons like Psycho's Ion Cannon, Meteor Storm, and Airstrike SWs. These cannot be done in TS because they required the use of skirmish/online game mode ini files to work in YR. No such ini files are used in TS.
Von Kriplespac
PostPosted: Tue Aug 16, 2005 11:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
... Buildable A-10s suck actually...  Confused
So please, stop asking over the A-10s.
geekspeek
PostPosted: Wed Oct 12, 2005 2:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
I could do part of copying original TD campaign, I just can't do it alone (not enough time on my hands for that).
This mod is dead!
Ackron wrote:
It would be good if it was better.
Surrealistik
PostPosted: Thu Oct 07, 2010 3:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
PostPosted: Thu Oct 07, 2010 3:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Everything in that video is and has been known for a long time, it is far from a decent work-around for working rotors / air transports due-to the huge amount of flaws and issues, both graphical and game-play related.
deltapilot
PostPosted: Sun May 08, 2011 1:06 am    Post subject: Reply with quote  Mark this post and the followings unread
its really great but a shame about the campaign...
You know they say the elephant never forgets, i forgot what the elephant remembered......
http://www.ppmsite.com/forum/viewtopic.php?t=30346
[ Time: 0.1980s ][ Queries: 11 (0.0103s) ][ Debug on ]
