The time now is Fri Apr 19, 2024 6:14 pm
Paradrop Tanks
Post new topic   Reply to topic Page 1 of 1 [20 Posts] Mark the topic unread ::  View previous topic :: View next topic
- geno -
PostPosted: Mon Dec 05, 2005 11:17 am    Post subject:  Paradrop Tanks Reply with quote  Mark this post and the followings unread
Open Rules.ini (MD is for Yuri's Revenge).
To make a paradrop plane that drops tanks is to Copy an existing Aircraft and add the aircraft a carryall=yes tag and make airport bound=no. In additional put a Weapon, so instead the weapon will be fired, the tank will be fire. Copy the codes here.
[PARAPLANE]
Image=PDPLANE
UIName=Name:PDPLANE
Name=Transport Plane
Strength=3000
Prerequisite=NARADAR
Category=AirPower
Primary=ParaDropWeapon
Armor=Heavy
Ammo=100
TechLevel=1
LeadershipRating=10
;Selectable=no
AirportBound=no
RadarInvisible=no
Sight=15
Landable=yes
MoveToShroud=yes
PitchAngle=0 ; default is 20 degrees
Speed=15
Carryall=yes
Owner=  ; Any of the Houses
Points=30
ROT=2
Crewed=yes
MaxDebris=2
Locomotor={4A582746-9839-11d1-B709-00A024DDAFD1}
MovementZone=Fly
ImmuneToPsionics=yes
CanPassiveAquire=no ; Won't try to pick up own targets
CanRetaliate=no; Won't fire back when hit
VoiceSelect=GenSovVehicleSelect
VoiceMove=GenSovVehicleMove
MoveSound=PDPlaneMoveLoop
DieSound=
CrashingSound=PDPlaneDie
ImpactLandSound=GenAircraftCrash
So The result of the aircraft will be like this
CLICK THIS LINK..
The Unit Paradrops the Tank because of the "CarryAll=yes" tag and The Weapon "Primary=#####"
Fight for the freedom side, March with the Imperial War Machine or Conquest for World Domination
https://www.facebook.com/YRZH.Mod/
https://www.moddb.com/mods/yr-zero-hour
View user's profile Send private message Send e-mail Visit poster's website ModDB Profile ID YouTube User URL Facebook Profile URL Twitter Channel URL Skype Account Yahoo Messenger Account
tobiasboon46
Shrapnel Sniper
PostPosted: Mon Dec 05, 2005 5:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
but in mission3/RA2/soviets the allies when u build psi beacon, they paradrop tanks like infantry
(and there is no mod!!!)
Err...the image above means no offence to the american people...It's a bit of what I feel about it's gov't >_>
Vincent93
PostPosted: Mon Dec 05, 2005 9:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Or you could just copy the tanks code and then make its TechLevel=-1 then give it a different [name] and add that to then Infantry Type list and there you go.
tobiasboon46
Shrapnel Sniper
PostPosted: Mon Dec 05, 2005 9:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
D'oh!!!
I've remembered that,in FA 2 YR,u can do teamgroups fos Singleplayer!!!!
That means that u can put different infantry(no matter who)in a parafrop,chronoshift(see final mission allies:How do u think that the MCV would be teleporting to there??)what ever!!!
Vincent93
PostPosted: Tue Dec 06, 2005 1:38 am    Post subject: Reply with quote  Mark this post and the followings unread
tobiasboon46 wrote:
D'oh!!!
Uh can we say oftopic, and flaming.
XxpeddyxX
PostPosted: Tue Dec 06, 2005 6:01 am    Post subject: Reply with quote  Mark this post and the followings unread
ayylmao on Discord
pd
PostPosted: Tue Dec 06, 2005 6:32 am    Post subject: Reply with quote  Mark this post and the followings unread
very interesting...
Still, where do you put the tank? in the ParadropInfantry list?
Everything put into an infantry list is considered infantry.
infantries are SHP.
IF you put a vehicletype into an infantry list, the game searches an Infantry with that ID.
for instance:
AmerParaDropInf=MTNK
would result in nothing unless you have an infantrytype called MTNK, which must be shp of course.
yes, you can drop tanks in maps.
but there's a special command that makes the game check VehicleTypes.
In skirmish, you have to fool the game.
that's basically what my rockpatch does.
but that isnt possible through INI coding.
To be honest, I didn't test this, but I really doubt it works.
it could only work if your primary weapon can spawn vehicletypes being paradropped, which isnt possible either...
Can anybody confirm it working?
I'd be really confused if it did  Confused
John Galt
PostPosted: Tue Dec 06, 2005 7:09 am    Post subject: Reply with quote  Mark this post and the followings unread
I can confirm exile's tut, which isn't anything new, I had a tut about that on my site for god knows how long.
Carryall=yes only works on AircraftTypes. Also, a variation of the same trick, AircraftTypes with both passengers and weaponry will drop Burst= number of passengers in one cell when told to fire, then shuffle to another cell, repeat until all the passengers are dropped, then, if it still has Ammo= left, it will fire the actual weapon. It's a known fact, I remember even paradropping multiple vehicles from such a plane back in YR 1.000. 1.001 , though, apparently patched the AircraftTypeas not to accept passengers with Size>1 or something.
Allied General
PostPosted: Tue Dec 06, 2005 9:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
no point in using this cos
1) paradropped vehicles from the place have hva issues
2) a landable transport plane looks silly
3) we have PaD rock patch
DoMiNaNt_HuNtEr
PostPosted: Wed Dec 07, 2005 2:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Dude, WW used a trigger for that.
IN-GAME NAME: MAKINTOKE
gog
PostPosted: Tue Apr 25, 2006 5:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey can u help me paradrop War Miners? THanks, and also is thier anway to use notepad to do it?
John Galt
PostPosted: Tue Apr 25, 2006 8:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Be more specific. Are you talking about a map or a mod?
ihateharriers
PostPosted: Tue Apr 25, 2006 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
easiest thing to do is download rockpatch and it's help files, open rulesmd.ini, and follow the instructions on the help file. thats it.
denilson2
PostPosted: Sun May 28, 2006 8:03 pm    Post subject: rockpatch where ?? Reply with quote  Mark this post and the followings unread
Hey where can I download rockpatch and it's help files, can't find it anywhere. Question
John Galt
PostPosted: Mon May 29, 2006 3:43 am    Post subject: Reply with quote  Mark this post and the followings unread
You obviously haven't looked very hard, have you? A link to it is in the pinned topic "Useful References" in the RA2 modding forum.
Zodiac
Gauss Rifle Trooper
PostPosted: Mon May 29, 2006 3:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
What is that map in the link and where ca i download it?
John Galt
PostPosted: Mon May 29, 2006 3:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's Bermuda Triangle (2-6), a stock YR map. The screenshot is a *mod*, not a *map* modification.
Zodiac
Gauss Rifle Trooper
PostPosted: Mon May 29, 2006 3:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
oops , i haven't noticed it... Oops!
denilson2
PostPosted: Wed Jun 14, 2006 12:50 pm    Post subject: Help Reply with quote  Mark this post and the followings unread
Hey all
I put the code in to the maps script and put an house in, but can't get it work. Please help. Smile
Allied General
PostPosted: Wed Jan 17, 2007 12:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
well late reply but it doesn't work in ra2 multiplayer only yr multiplayer if want side reinforcements, its all about create teams and looking at sov mission 3 for reference.
[ Time: 0.2311s ][ Queries: 11 (0.0087s) ][ Debug on ]
