The time now is Fri Apr 26, 2024 12:13 pm
Supress=yes
Post new topic   Reply to topic Page 1 of 1 [4 Posts] Mark the topic unread ::  View previous topic :: View next topic
PostPosted: Fri Mar 25, 2011 12:37 am    Post subject:  Supress=yes
Subject description: Does it work?
Does Supress=yes work and can the FireSupress tag be the deglobalised?
LH_Mouse
PostPosted: Fri Mar 25, 2011 11:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Supress=yes(note it is spelled as "Supress", "Suppress" does not work) DOES work in YR. Each unit has a threat value. When a unit picks target it will search for nearby targets and picks the one with the highest threat value to attack. If a unit's weapon has Supress=yes then the engine will scan for friendly units near that target and for each one found, halve that target's threat value. If the threat value is decreased below 1(in which case it'll become 0 when converted to __int64) then that target will not be automatically acquired.
P.S. A normal unit usually has a threat value around 100,000.
Fusion Reactor upgrade is complete.
We will prevail!!!
PostPosted: Sat Mar 26, 2011 11:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Okay, but can the FireSupress tag be deglobalised?
Can it be made as per-unit tag like FlightLevel that works on AircraftTypes.
LH_Mouse
PostPosted: Sat Mar 26, 2011 11:22 am    Post subject: Reply with quote  Mark this post and the followings unread
No.
We will prevail!!!
[ Time: 0.1409s ][ Queries: 11 (0.0082s) ][ Debug on ]
