The time now is Sat Apr 27, 2024 4:51 am
[SP] Infiltration and destroy
Post new topic   Reply to topic Page 1 of 1 [20 Posts] Mark the topic unread ::  View previous topic :: View next topic
LordCesare
PostPosted: Thu Jul 07, 2011 9:10 am    Post subject:  [SP] Infiltration and destroy
Subject description: Nod SP mission nod1a.map
hi guys i've made this map fro trying my knowledge about triggers and i'm not lucky...
here the map
Briefing: This night, an infiltration team landed on an harbor in GDI/Globotech blue zone, they have set up walls and gates around Tiberium so they can't spread, but the mutant came before us and they are destroying the entire harbor. We must regroup and destroy everything that look GDI,Globotech or those freaky mutants.
Objective 1: make contact with the lost base to the north
Objective 2:Destroy GDI,Globotech and Mutant survivors
i need help guys because:
My teamHouse (Nod) act like AI, when i produce infantry i can only move them, they attack only when they see the enemy without order, and if i give an attack order, they don't move.Even the bases Self repair when i have founds.
need help with Text i don't know how to where to write them and when they should start/finish.
Problem Resolved about this map
nod1a.map
 Filename:  nod1a.map
 Filesize:  195.5 KB
 Downloaded:  343 Time(s)
Team : Mentalmeister | Mapper for Mental Omega 3.0
Team : TO Project | Mapper for Tiberian Odyssey
ChronoSeth
Sergeant
PostPosted: Thu Jul 07, 2011 9:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Try setting the house's IQ to 0.
Dawn of the Tiberium Age staff member
LordCesare
PostPosted: Fri Jul 08, 2011 10:18 am    Post subject: Reply with quote  Mark this post and the followings unread
i've done it but nothing even build activity 0% but nothing.... i've maked another map for nod SP but when i have my base even the conyard don't let me build (build tech 5) i don't have any icon to produce, selfrepair ecc... maybe is something more? because The missions og Twisted Insurrection don't have these problems
LordCesare
PostPosted: Sat Jul 09, 2011 4:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
please can someone teach me more about mapping because i want to do the best for this mod ...
[TiberianFuture]
Scrin Overlord
PostPosted: Mon Jul 11, 2011 10:30 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't know about your infantry problems, I didn't experience any. Bases self repairing happened neither, but if that happens, reason is the IQ level.
What comes to text triggers, if you want them to be repeating, you have to use event: 13. Elapsed Time..., otherwise it won't work (like your 4. Revealed by Player).
To create new text lines, just open up tutorial.ini and type new lines there.
Your map was pretty good, I'd advice to use some time to make cliffs less repetitive (especially from backside). Marble Madness mode in Final TI will help a lot.
I suggest also tuning down the lightposts, as they're bright atm.
Which makes me wonder why Aro hasn't changed the default light values in the rules so it would be possible to make a map without having to change the light values every time.
Check out some TF Kane's Wrath action:
Tournament 3rd place.
Vs. bikeRushOwnz in tournament.
Ladder wars vs. bikeRushOwnz.
LordCesare
PostPosted: Mon Jul 11, 2011 10:42 am    Post subject: Reply with quote  Mark this post and the followings unread
ok 've done it but what about infantry? i've done another map and when i have the conyard i can't build...(where can i found the tutorial.ini?
[TiberianFuture]
Scrin Overlord
PostPosted: Mon Jul 11, 2011 11:18 am    Post subject: Reply with quote  Mark this post and the followings unread
I've got no idea for your infantry problem, I played trough your mission without any problems.
My guess for your Con Yard problem is that you're using the Nod/GDI Construction Yard, but you should use the CY with no factions names in it
(means the one just called Construction Yard). If that's not the case, then send me the map and I'll check it out.
Tutorial.ini can be extracted from the local.mix inside TWIINS.mix.
LordCesare
PostPosted: Mon Jul 11, 2011 11:59 am    Post subject: Reply with quote  Mark this post and the followings unread
i've resolved that thing about the infantry ... but still there are problem with the conyard ( i've used the normal conyard without GDI/Nod)
here
[Sometimes when i use the automatic cliff F TI crash]
[TiberianFuture]
Scrin Overlord
PostPosted: Tue Jul 12, 2011 8:15 am    Post subject: Reply with quote  Mark this post and the followings unread
That was weird, I couldn't solve it. If I placed war factory or hand of nod or helipad it worked just fine, but for some reason I couldn't build from the owner-changed CY.
I think you have to just use an MCV instead of CY, as it works that way.
Other things in that map that I took notice of was that you had used some weird resized Kazuars instead of the real unit (what's the purpose of those minis in the first place?).
Also you should probably give IQ=0 to NodA as it sells the base defences when they reach red health.
The EMP attack trigger causes an IE, see what I said about repeating triggers above.
I also experienced some weird black tiles occassionally, which disappeared when I looked away. Don't know what causes them.
Oh, and do place the cliffs manually (tileset 10), it will look a lot better than using autocliff tool.
LordCesare
PostPosted: Tue Jul 12, 2011 8:53 am    Post subject: Reply with quote  Mark this post and the followings unread
ok i set the Nod M.C.V. and normal kazuar, ( about little kazuars, i was corious lol) NodA now IQ 0 and i've set the EMP to "elapsed time" now i'll test it and then delete the above download and create a new post
[i've opened the TWIINS with the XCC mixer and i can't find the Tutorial.ini..]
[Even with the MCV (those called MCV and Nod MCV) when i deploy it i can't build]
[TiberianFuture]
Scrin Overlord
PostPosted: Tue Jul 12, 2011 9:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Haha I solved it Very Happy You gotta go to the house settings and change NodB's 'Acts Like' to '1 Nod'.
You have to open the local.mix located inside the twiins.mix to find the tutorial.ini.
LordCesare
PostPosted: Tue Jul 12, 2011 10:03 am    Post subject: Reply with quote  Mark this post and the followings unread
cool now i'll try it Wink
about text, after i add the text on the tutorial.ini, what should i do then?
Ixith
PostPosted: Tue Jul 12, 2011 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
What is the map height?
I have found that at heights of 12, 13, and especially 14 graphical errors will happen in game especially on slopes and will happen often when you first discover an area of terrain that is that high. Sometimes it will even replace the really steep slope piece for a different kind of slope piece. Other times it'll just show a black area such as you described.
add it into the map using triggers with the action to add text in.
As long as the tutorial.ini is in your directory it should pull from it.
Kalistia Crestland (2)
In Soviet Russia, grass grows on tiberium!
View user's profile Send private message Send e-mail Skype Account AIM Address
LordCesare
PostPosted: Tue Jul 12, 2011 10:47 am    Post subject: Reply with quote  Mark this post and the followings unread
done thanks to all guys i hope you will teach me more things about this some times Wink now il post this mission now comment this and the other maps =D
LordCesare
PostPosted: Tue Jul 12, 2011 3:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
what should i do if i want to modify the Briefing?
PostPosted: Tue Jul 12, 2011 3:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Mission.ini or something like that has all the briefings.
LordCesare
PostPosted: Tue Jul 12, 2011 6:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
I ve made another map where i have to find 2 trucks and escort them to a safely area.
i have the text trigger for
objective 1 find all trucks
objective 2 escort the trucks
i have them repeating but i want to stop the ob 1 after i've founded all the trucks. how can i do that? and how can i set Win trigger after the 2 trucks reach the safely zone ? how can i add constantly arrival of mutant lifeform (i mean 4 Tib fiend arrive and other 4 will arrive after 3 minutes)
[TiberianFuture]
Scrin Overlord
PostPosted: Tue Jul 12, 2011 6:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Put action '53 (or was it 54?) - disable trigger' to the objective 1 completed trigger, and disable the trigger with the text.
Set the win condition as '2 - entered by'.
To make constantly spawning units, make a repeating trigger that spawns teams of those creatures you want.
LordCesare
PostPosted: Wed Jul 13, 2011 1:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
i set them with scripts and waypont on another map but why they don't search for my units?
[TiberianFuture]
Scrin Overlord
PostPosted: Wed Jul 13, 2011 6:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Depends on what you put in the script.
[ Time: 0.1783s ][ Queries: 13 (0.0106s) ][ Debug on ]
