The time now is Fri Apr 26, 2024 9:19 am
Epsilon City (6) minor bug
Post new topic   Reply to topic Page 1 of 1 [4 Posts] Mark the topic unread ::  View previous topic :: View next topic
Lopunny777
PostPosted: Tue Aug 06, 2013 12:28 am    Post subject:  Epsilon City (6) minor bug Reply with quote  Mark this post and the followings unread
in the bottom right corner at the globatech base you cant access the mineral field as the tunnel is glitched and you cant go through it...i wanted to build a base there but sadly the bugged tunnel doesnt open that possibility up..if you have spare time can you fix this for next version?
PostPosted: Wed Aug 07, 2013 9:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am aware of the issue and will hopefully have it fixed soon.
PostPosted: Thu Aug 08, 2013 6:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Really? I thought the tunnel was working properly. I'll look into it.
Lopunny777
PostPosted: Thu Aug 08, 2013 1:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok thank you Very Happy
[ Time: 0.1590s ][ Queries: 11 (0.0081s) ][ Debug on ]
