The time now is Sat Apr 27, 2024 7:30 am
ETS 3.40 #0018
Moderators: Global Moderators, VK
Post new topic   Reply to topic Page 1 of 1 [27 Posts] Mark the topic unread ::  View previous topic :: View next topic
Do you have "Please reinstall" msg box after installing ETS 3.40?
Yes
50%
 50%  [ 5 ]
No
50%
 50%  [ 5 ]
Total Votes : 10
VK
Pyro Sniper
PostPosted: Sat May 05, 2007 7:47 pm    Post subject:  ETS 3.40 #0018
Subject description: released!
Extended Tiberian Sun 3.40 released!
Start revision #0018
Current revision: #0018
*New SW type - Animation
*Upgrade SW is updated.
*New upgrade system
*More stable
ETS 3.40 - for users
Download here.
ETS 3.40 MDK - for modders
Download here.
Report bugs in But Tracker.
MadHQ
PostPosted: Sat May 05, 2007 8:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice to see you working on ETS. Smile
MadHQ's Graveyard - Click here!
(Permissions) - (F.A.Q.)
*blackheartstar*
PostPosted: Sat May 05, 2007 9:06 pm    Post subject: Re: ETS 3.40 #0018 Reply with quote  Mark this post and the followings unread
Very nice Smile
Only thing
This was left out of the MDK.
I noticed this to
C&CVK wrote:
You can specify more than one upgrade type at the same time. UpgradeDuration isn't supported in RP 1.10.
which sounds very promising Smile
What is UpgradeDuration supported in? Its not mentioned as a feature in ETS either.
Morpher
PostPosted: Sun May 06, 2007 3:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Great work there this looks very interesting however I am not sure what this new upgrade system is or how it works?
IcySon55
PostPosted: Sun May 06, 2007 5:02 am    Post subject: Reply with quote  Mark this post and the followings unread
The system activates when units reach Veteran status.
It effectively changes one unit into another. This is achieved by the use of the map trigger that Westwood used to change the loaded TruckA into TruckB in the missions. Reuse of code is awesome ^_^.
djohe
Cyborg Informer
PostPosted: Sun May 06, 2007 6:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow this is great now I can do a complex upgrade system for my infantry and vehicles, I realy missed this feature and now im happy!
And when you released 3.30 #0012 I thought the only thing I miss now is the AnimationSW and you implented it great!
The only thing I miss now is the documentation for the AnimationSW but I can check RockPatch or Game.exe for that.
C&CVK wrote:
*More stable
Whats the stability fix for? Was there a error in #0012? and what was it on? I just want to know.
Great work anyway! Very Happy Smile
Im not getting the Please Reinstall error but I also never got it with previous versions either.
Also the ETSLauncher is still not working good for me. Sun.exe works doh.
Another thing that aint important but wrong in ETS is the hidden version screen. It says this for me:
ETS Version 3.30
VK
Pyro Sniper
PostPosted: Mon May 07, 2007 8:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
it's easy to use:
Type=Animation
Animation=<Animation>
wait next MDK Sad
again copy-paste error. This page (and others)(and code also) were ported from RP 1.10 MDK.
This is called "look to the future", I reserved space for this variable and parse it from INI file, but do nothing with it.
why?
ETS Version 3.30
will be corrected.
Also I think about dialog, like Info page in RP.
some multi-mod system update also CD path code update.
ARM forever - x86 sucks
gufu
PostPosted: Thu May 10, 2007 1:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Do I need 2.03? or 2.00 works fine?
DUNK!
Morpher
PostPosted: Thu May 10, 2007 6:09 am    Post subject: Reply with quote  Mark this post and the followings unread
2.03 as always Gufu, download the installer and it clearly says that, don't ask stupid n00b questions no matter how hard you may find it.
VK
Pyro Sniper
PostPosted: Thu May 10, 2007 9:44 am    Post subject: Reply with quote  Mark this post and the followings unread
of course only 2.03.
you can download a update from westwood ftp server.
gufu
PostPosted: Thu May 10, 2007 3:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
I did so from planet cnc... but it's BSing about some random .ini misssing...
DUNK!
gufu
PostPosted: Thu May 10, 2007 5:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Every time I install ETS - I get "unable to initializa - please reinstal" message... I fully patched both TS and FS... Help?
DUNK!
Black hawk
PostPosted: Fri May 11, 2007 7:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
lol xd dont no how to use it with a mod because it won't work xd Laughing
Love MLRS, its the worlds most dangerous artillery!!
Thanks bittah for the sig .
MY TS/V forum
gufu
PostPosted: Fri May 11, 2007 8:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
1)Fully patch TS and FS
2)Instal the MODers MDK
3)You can now use new tags
DUNK!
Morpher
PostPosted: Sat May 12, 2007 5:09 am    Post subject: Reply with quote  Mark this post and the followings unread
If you get fail to initialize copy all mix files and sizzle.vqa from your disc to your TS folder and see if that works. This includes MOVIES01 and 02.MIX, SCORES.MIX and 01.MIX SIDECD01 AND 02.MIX MAPS01 and 02.mix and MULTI.MIX. And some of the other disc MIX files. It should hopefully work then. As it did for Blubb.
Also why the hell is ETS exe working like a No CD crack exe where you need all disc mix files in your TS directory?
Creagor
PostPosted: Sat May 12, 2007 9:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Because the no-cd crack is VK's "solution" to making ETS compatible with TFD.
Morpher
PostPosted: Sat May 12, 2007 9:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Well using the NoCD crack version will make it difficult for people who don't use the no cd crack, as unless they have read the no cd crack readme they will not understand what files to use in order for the game to start.
gufu
PostPosted: Sat May 12, 2007 4:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
nope, doesn't work - I did move ALL mixes to TS directory...
DUNK!
Morpher
PostPosted: Sat May 12, 2007 4:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
But your Gufu.
If it worked for Blubb, I am presuming it will work for anyone else who copies there CD mix files to thier directry, and ran ETS over TS 2.03 ( remember that Gufy!? Smile ). However I am not going to post up anything NoCD crack related as I am not sure Banshee would throw a party over the idea of it.
gufu
PostPosted: Sat May 12, 2007 6:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok... after downloading westwoods originaly 2.03 patch for TS - the game works... the problem is - even if I add aacombat=yes to ORCA and HARPY - they still can't attack while enemy(or forced fire friend) is in MID-air. They projectiles ARE AA=yes.
DUNK!
VK
Pyro Sniper
PostPosted: Sat May 19, 2007 8:52 am    Post subject: Reply with quote  Mark this post and the followings unread
aacombat=yes
AACombat=yes, not aacombat=yes.
gufu
PostPosted: Sat May 19, 2007 7:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
; Apache Chopper
[APACHE]
Name=Harpy
Prerequisite=NAHPAD
Primary=HarpyClaw
Strength=225
Category=AirPower
Armor=light
TechLevel=5
Sight=2
RadarInvisible=yes
Landable=yes
MoveToShroud=no
Dock=NAHPAD,GAHPAD
PipScale=Ammo
Speed=14
PitchSpeed=.16
Owner=Nod
Cost=1000
Points=20
ROT=5
Ammo=12
Crewed=yes
GuardRange=30
AACombat=yes
MaxDebris=3
VoiceSelect=30-I000,30-I002,30-I004,30-I006
VoiceMove=30-I014,30-I016,30-I018,30-I022
VoiceAttack=30-I022,30-I030,30-I034,30-I036
Locomotor={4A582746-9839-11d1-B709-00A024DDAFD1}
MovementZone=Fly
ThreatPosed=15 ; This value MUST be 0 for all building addons
;Harpy Vulcan Cannon
[HarpyClaw]
Damage=60
ROF=36
Range=5
Projectile=Invisible2
Speed=100
Warhead=SA
Report=CYGUN1
[Invisible2]
Inviso=yes
Image=none
ROT=3
AA=yes
AG=yes
DUNK!
*blackheartstar*
PostPosted: Mon May 21, 2007 1:50 am    Post subject: Reply with quote  Mark this post and the followings unread
gufu wrote:
; Apache Chopper
[APACHE]
Name=Harpy
Prerequisite=NAHPAD
Primary=HarpyClaw
Strength=225
Category=AirPower
Armor=light
TechLevel=5
Sight=2
RadarInvisible=yes
Landable=yes
MoveToShroud=no
Dock=NAHPAD,GAHPAD
PipScale=Ammo
Speed=14
PitchSpeed=.16
Owner=Nod
Cost=1000
Points=20
ROT=5
Ammo=12
Crewed=yes
GuardRange=30
AACombat=yes
MaxDebris=3
MovementZone=Fly
You are missing the Fighter=yes tag in this section. I belive that is it Smile
gufu
PostPosted: Mon May 21, 2007 8:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh shit...
DUNK!
gufu
PostPosted: Mon May 21, 2007 10:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Meh... doesn't work either...
DUNK!
Morpher
PostPosted: Mon May 21, 2007 10:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Um I had this working without any Fighter=yes tag :S. I dn't think Gufu has ETS installed correctly, thus not working.
gufu
PostPosted: Mon May 21, 2007 11:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
1)TS patch from FTP
2)FS
3)instalation of ETS again... gives the known error...
DUNK!
[ Time: 0.2003s ][ Queries: 13 (0.0147s) ][ Debug on ]
