The time now is Fri Mar 14, 2025 10:42 am
Coloured lighting on buildings
Post new topic   Reply to topic Page 1 of 1 [19 Posts] Mark the topic unread ::  View previous topic :: View next topic
Ixonoclast
PostPosted: Wed Aug 13, 2008 2:47 pm    Post subject:  Coloured lighting on buildings Reply with quote  Mark this post and the followings unread
Is it possible to make the lighting of lightposts and buildings similar to the remap? So your buildings would actually get the colour of your current team?
PostPosted: Wed Aug 13, 2008 3:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Impossible IIRC...
PostPosted: Wed Aug 13, 2008 3:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
the only workaround is afaik a transparent activeanim which looks like glow and which is in the team color.
Ixonoclast
PostPosted: Wed Aug 13, 2008 3:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
And this could be used on Construction yards, defenses and powerplants?
PostPosted: Wed Aug 13, 2008 4:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
sure, just add to them another activeanim of the glowing light.
However these lights won't have the fade out effect than normal alphalights.
Ixonoclast
PostPosted: Wed Aug 13, 2008 4:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
You mean it will look like picture 2, opposed to the ideal picture 1?
 Filesize:  23.48 KB
 Viewed:  4676 Time(s)
PostPosted: Wed Aug 13, 2008 4:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
None of both. It will be a solid colour; you can't see anything beneath it (terrain, other structures or units)...
PostPosted: Wed Aug 13, 2008 4:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
of course you can see through it.
Just add, as i've said already, the translucent key on the activeanim.
With UseNormalLight it also get's some kind of glow on dark maps.
PostPosted: Wed Aug 13, 2008 4:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
I fail epicly >_< You're completely right LKO Smile
PostPosted: Wed Aug 13, 2008 5:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
a 10min job
just an SHP with a red circle on 3 frames with then 3 clear frames.
if you don't want it to cover the whole building too, you simply have to cut out its shape from the circle
 Filesize:  53.89 KB
 Viewed:  4661 Time(s)
Ixonoclast
PostPosted: Wed Aug 13, 2008 5:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Mmmm, this will take some experimentation.
*throws it in the to-do warehouse*
Back to the drawing table.
PostPosted: Wed Aug 13, 2008 6:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Actually, you could make it "fade away" by making, say, 3 transparent animations with each one representing a stage of the light. The first one is closest to the building, and it has, say (again), 25% translucency. The next one is further, and has 50% translucency...and so on. To avoid the animations overlaping each other, cut the shape of the previous animation from the animation you want to put next.
PostPosted: Wed Aug 13, 2008 7:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
This gives me ideas for new buildable light posts #Tongue
PostPosted: Wed Aug 13, 2008 8:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
@Crimsonum
the shown pic uses already Translucency=75 and as you can see it is still quite thick on dark maps. Since a higher translucency isn't available, i doubt that 50 or even only 25% would help a lot. But since it looks quite well on bright maps, removing the UseNormalLight key might help.
Another problem is that you can use only 4 activeanims. Many buildings would this way reach very fast their limit if you use 3 different transparent glow anims.
But a colored lightpost should work.
Another very useful thing about this light effect is, that you can make this way animated lights. like a custom moving spotlight or in the air beaming searchlights.
Maybe some more research using ExtraLight= or some other keys would improve the light effect.
But also keep in mind that a complete base using this "light" would cause a massive lag, because TS really has a great performance problem if there are many transparent anims.
Ixonoclast
PostPosted: Wed Aug 13, 2008 9:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, lagging could be a problem for people who build a lot of power plants... :/
Through, giving only defenses, ConYards and Powerplants light would cut the game some slack...
Imagine Helipads with lighting. In a multiplayer game.
Slava_92
PostPosted: Fri Oct 03, 2008 12:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
i want make the first picture , how i do that ??
Ixonoclast
PostPosted: Fri Oct 03, 2008 2:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Invisible lightposts.
PostPosted: Sat Oct 04, 2008 4:44 am    Post subject: Reply with quote  Mark this post and the followings unread
ExtraLight= is a tag mappers use to djust how lighting affects units.
Normally, units are automatically adjusted to the ambient light, but for whatever reason, you can use the ExtraLight= tag to make them brighter or darker than they show.
At least, IIRC.. I've never used this tag myself #Tongue
PostPosted: Sun Oct 05, 2008 12:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's used in RA2... It makes the units look more like in the comics #Tongue
[ Time: 0.2374s ][ Queries: 15 (0.0150s) ][ Debug on ]
