The time now is Mon Mar 31, 2025 10:20 am
Nod Sam Turret
Moderators: Global Moderators, Media Hut Moderators, OpenRA Moderators, Red Alert 2 Moderators, Tiberian Sun Moderators
Post new topic   Reply to topic Page 1 of 1 [21 Posts] Mark the topic unread ::  View previous topic :: View next topic
Regulus
PostPosted: Tue Jan 12, 2010 5:00 am    Post subject:  Nod Sam Turret
Subject description: Quick "Fix"
It has always bothered me that the Nod SAM Turret uses the GDI SAM Turret art. So I decided to make a new one today. Cheerio.
Just replace the art entries for the NASAM_A with this:
; SAM site turret
[NASAM_A]
LoopStart=0
LoopEnd=32
LoopCount=-1
Rate=0
Surface=yes
NewTheater=yes
EDIT
I uploaded the base that I remade here. It makes a small difference but a difference none the less.
 Filesize:  12.34 KB
 Viewed:  7237 Time(s)
Ingames with original base.
 Filesize:  19.56 KB
 Viewed:  10995 Time(s)
nasam.zip
 Filename:  nasam.zip
 Filesize:  2.95 KB
 Downloaded:  125 Time(s)
ntsam_a.shp
SHP
 Filename:  ntsam_a.shp
 Filesize:  12.06 KB
 Downloaded:  360 Time(s)
You come for the modding but you stay for the Crap Forum.
Askhati
Jumpjet Infantry
PostPosted: Tue Jan 12, 2010 6:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Is that red dot on the left side of the launcher a targeting laser or what? It looks a little out of place.
Has anyone ever thought of making a voxel version of the SAM turret?
Adapt or die
Regulus
PostPosted: Tue Jan 12, 2010 6:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Its on the FMV render, so I put it there.
PostPosted: Tue Jan 12, 2010 12:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Why do you want a vxl, while SHPs do look a lot better and more detailed. Confused
Askhati
Jumpjet Infantry
PostPosted: Tue Jan 12, 2010 2:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
So that we can use it on a tank chassis without it having to deploy...? *facepalm*
Adapt or die
PostPosted: Tue Jan 12, 2010 2:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
A voxel turret can face any direction, whereas a SHP turret can only face 32 directions.
PostPosted: Tue Jan 12, 2010 3:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Behave yourself!
If you're too lazy to create a simple single turret for a certain unit, you obviously haven't understood yet, that modding is more than just simple copy and pasting different things together.
@Crimsonum: The engine renders voxel in only 32 facings too. Take a very long/big voxel and you can clearly see the 32 facings when it rotates.
Since building turrets don't have to tilt, it's always better to create them via a more detailed SHP.
PostPosted: Tue Jan 12, 2010 3:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's another problem with SHP turrets. The turret can only be fixed into specific angle, whereas voxel turrets can rotate horizontally.
Morpher
PostPosted: Tue Jan 12, 2010 4:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
What happens if you have say...
NASAM
NASAMTUR.SHP
NASAMTUR.VXL - (Invisible)
NASAMBARL.VXL
Or is it not possible to have a voxel and shp turret on the same object, or even a shp turret and a voxel barrell? Most barrels for tanks and etc are just a blank line / cannon.
Tony
PostPosted: Tue Jan 12, 2010 5:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not bad. ;p
SuperJoe
PostPosted: Tue Jan 12, 2010 5:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Really dig it, and included it in my mod. If you use this, I suggest to change the PrimaryFireFLH and SecondaryFireFLH under [NASAM] to:
PrimaryFireFLH=160,50,100
SecondaryFireFLH=160,-50,100
With the default values the missiles seem to pop inside the turret.
PostPosted: Tue Jan 12, 2010 7:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
It looks a bit blobby to me, tbh. I can't make out the details as well as I can on the WW sam..
Dark Templar X
PostPosted: Tue Jan 12, 2010 8:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's not perfect but a lot better than a lazy solution. Now give it a less conspicuous base and it'd be win.
Regulus
PostPosted: Tue Jan 12, 2010 8:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
o___________________________________________________________o
I just made the turret because I thought everyone would like to have a non GDI Turret on their SAM. I didn't do anything to the base.
Dark Templar X
PostPosted: Tue Jan 12, 2010 8:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
lolwut
0warfighter0
PostPosted: Tue Jan 12, 2010 10:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's what he meant and I agree.
Changing the base to (yellow/black lines) make it fit better would make this even better.
Although your turret looks awesome! Wink
Askhati
Jumpjet Infantry
PostPosted: Wed Jan 13, 2010 6:03 am    Post subject: Reply with quote  Mark this post and the followings unread
@ LKO:
Sorry man - I though it would be very obivous as to why someone would prefer a VXL turret over a SHP
@ Regulus:
Assuming you still have the 3d model you used to make this turret, could you maybe make another version of the turret that is a VXL instead? I have an idea for a Mobile SAM Site for Nod, would like to use this new SHP turret of yours for the building... But I would also need a voxel equivalent for the vehicle when it is undeployed.
Adapt or die
Regulus
PostPosted: Wed Jan 13, 2010 8:45 am    Post subject: Reply with quote  Mark this post and the followings unread
This SAM turret took me all of five minutesto model and make. It wouldn't be that hard to make the turret as an Voxel, but I am too busy with TS:AE to make public stuff. Sorry.
Askhati
Jumpjet Infantry
PostPosted: Wed Jan 13, 2010 10:02 am    Post subject: Reply with quote  Mark this post and the followings unread
"five minutes to make" vs "too busy to do it"... Wink
Well, here's hoping we'll see it in TS:AE then!
Adapt or die
PostPosted: Wed Jan 13, 2010 10:53 am    Post subject: Reply with quote  Mark this post and the followings unread
NASAM
NASAMTUR.SHP
NASAMBARL.VXL
Just look at the FS Juggernaut Wink It has a SHP turret combined with a VXL barrel. This works for buildings only.
If you want a unit, just look at the Titan.
Regulus
PostPosted: Thu Jul 10, 2014 4:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Added a new base complete with snow and buildup animations. It makes only a slight difference. I may make a new base later if what I anticipate happening happens.
[ Time: 0.3143s ][ Queries: 15 (0.0658s) ][ Debug on ]
