Posted: Thu Jul 15, 2010 11:03 am Post subject:
Dune-like pavements
Hello,
I wanted to make new pavements for Tiberian Sun,that would not look like dirty gray dirt that you can barely tell apart from what was on the map from the start.
I wanted the clean look of Dune 2 pavements (215-dune-2-la-bataille-d-arrakis-13.jpg)
And maybe adapt the "multiple rectangles" shape of dune 2000 pavements (261432__dune2000_1.jpg),because dune 2 look was for a top view,and dune 2000 shape might be better for the views from the side (even if in TS,the pavement itself would be viewed from the side)
I somehow managed to do something that work,but it's...THAT THING called mywork2.jpg (demonstrated ingame in mywork.jpg).
I went for 4 squares instead of 2 rectangles because of the shape in the middle,it would look bad with 2 rectangles.
Graphics are definitely not my thing,so I would need a pvclr01.tem and pvclr01.sno (not shown here,but it was only brighter,if I did it properly) made by somebody else.
Can I find what i'm looking for in publics assets somewhere?
If not,I would be grateful to anybody able to provide those.
I will be back to thank anybody that might have helped,and to remove all those attachments once they are useless.
edit: I added "new pavements for Tiberian Sun",just in case,because while reading myself again,I saw I didnt make it obvious from the start for which game I wanted my pavement.
1.1 KB
2610 Time(s)
18.47 KB
2610 Time(s)
71.79 KB
2610 Time(s)
89.36 KB
2610 Time(s)
Last edited by Cantdrawbutmod on Fri Jul 16, 2010 7:04 am; edited 1 time in total QUICK_EDIT
Hmm, don't think thats true. At least there is a tool on Fed2k that can extract them however I don't think they're higher quality. _________________ QUICK_EDIT
