Joined: 10 Sep 2006 Location: Birmingham, United Kingdom
Posted: Sun Jan 02, 2011 5:57 am Post subject:
TI Mappers Guide
With all of the new Twisted Insurrection terrain, even experienced mappers can find it difficult to get used to it and use it properly. I've written up this guide to show you a few tricks and show you how certain tiles are supposed to be used. This should prevent the TI mappers asking the same questions over and over again, some of you could even pick up a few new tricks.
Right, lets start off with what certain tiles are supposed to be used for.
Tiberium Death Causes Visceroids
This is ESSENTIAL for every map, some of the weapons used in Twisted Insurrections rules.ini file rely on this tag to work properly, so in every map please use TiberiumDeathToVisceroid=yes. To do this simply set 'Visceroid because of death in Tiberium:' to 'yes' under the BASIC section in FinalTI, or simply open the map in wordpad or any similar program and search for TiberiumDeathToVisceroid= and set the tag from no to yes.
Types of Tiberium
All 4 types (green,blue,red,purple) of Tiberium can be used already.
In FinalTI on the left menu under "Special/Overlay - All Overlay" you can find all 4 tiberium types.
BTIB01-BTIB12 is purple tiberium cruentus (they grow and spread extremely slow ingame; interestingly they appear red in FS)
TIB2_01-TIB2_20 are the blue tiberium vinifera (in FS only TIB2_01 appears blue; 02-04 appear red and 5-20 appear green; don't ask me why)
TIB3_01-TIB3_20 are the red tiberium arboreus (in FS they all appear green, but ingame they work as they should and appear red)
The value for the different types is as follows (per bail [full Nod Harv/ full GDI Harv])
Riparius (green) : 25 [625 / 875]
Vinifera (blue) : 45 [1125 / 1575]
Arboreus (red) : 110 [2750 / 3850]
Cruentus (purple) : 180 [4500 / 6300]
Each Tiberium also has its own crystal
All crystals spawn tiberium. Purple and white spawn cruentus. The white crystal should be placed only as decoration on terrain that doesn't allows tiberium to spread there.
Tiberium Spreaders
Under Buildings/Other you can find 4 buildings called
Invisible Green Riparius Spreader [TIBSPRDR]
Invisible Purple Cruentus Spreader [TIBSPRDC]
Invisible Blue Vinifera Spreader [TIBSPRDV]
Invisible Red Arboreus spreader [TIBSPRDA]
These nifty little add-ons make Tiberium look much more realistic as they spawn tiberium patches over a wide area. They act exactly the same as invisible light posts but also spread Tiberium, be sure to only use them on Tiberium patches and not on areas that just require lighting. More information here and here.
You can also use them between green Moss and blue Mold areas where you want a constant but very small tiberium growth, so it looks like Moss and Mold contaminate the area with tiberium.
Warning: Do not place the Cruentus spreader near slopes as this causes an Internal Error when it tries to spawn a patch on a slope.
Note: All 4 Spreader should be placed at least 6 cells away from water, as they use debris to spawn the small patches of tiberium over a wide area and the debris would cause an irritating random splash when landing in water.
Here is a GIF showing via splashes the general range of the spreader.
The spreader dummy building is placed on the same cell as the crystal, but as you can see is the spread area a bit north-heavy. So you could place the spreader one cell to the south to create an even distributed area of spawned tib-patches around the tibtree or crystal.
Hum-Vee for Ion Storm Maps
If your map contains an Ion storm, please include this code somewhere in the map file. This code allows the hov-vee to become the hum-vee in-game. This is Vital.
The first four tiles in this set are supposed to be placed underneath Tiberium tree's to give off a sprouting from the ground effect. The rest of the tiles in the set are just eye-candy and can be used where-ever.
The Tiberium trees are to put put right in the middle of these tiles in order to look right.
Cliff Shadow Fixes
As new terrain can't just be given shadows attached to them (which is really gay), Lin Kuei Ominae made a little workaround overlay which gives the illusion of the cliffs casting a shadow. Another advantage to this is that in Vanilla Tiberian Sun, the water cliff corners were also missing shadows. Three overlays have been made, one for the missing water cliff corner shadow, one for the High concrete cliffs and another one for the low concrete cliffs.
To locate these overlay tiles in the map editor, go to Special / Overlay in the sidemenu and then go to All overlay, near the bottom of the list, there are three overlays: CSHADFXA, CSHADFXB and CSHADFXC.
CSHADFXA is the tile that is to be used on the missing water cliff corners, this applies to both the thorn water cliffs and the normal water cliffs. ALSO Don't forget that thorn and normal water waterfalls require this overlay too as they also miss the corner shadow.
CSHADFXB is the tile that is to be used on the high concrete cliffs corner.
CSHADFXC is the tile that is to be used on the low concrete cliffs corner.
Making Concrete Attach To New Concrete Tiles (Other fixes)
Due-to certain limitations, you can't use auto-lat concrete on the TI concrete additions (unfortunately). There is a terrain set in the LAT list called 'Pavement Fix A (No Auto-LAT)', this set is used on any TI new concrete additions such as the low cliffs, paved road fixes, city pavement etc. This will take longer to do, but it's definitely worth the results. I'm hoping that you're all aware of this by now so I don't have to do any more explaining. If you have any questions regarding this however, feel free to ask.
There is a few more things similar to this in the TI terrain list. As you can't use auto-lats to auto-attach to new terrain, quite a few fix sets had to be made, including fix sets for the Crystal LAT tile and the Blue Mold Tile. Those tiles are to be used the same way on any new Mold / Crystal tiles (like the blue mold cliffs for example). There is also a tile set called 'Clean Grass Fix' which I put together specifically for urban areas, this is so you can create squares of grass in cities without worrying about it auto-smoothing when you get in-game.
Again, the majority of you should already know this, but if you have any questions, feel free to ask.
Don't forget: When you're placing down new LAT's be sure to know their passability settings, It's annoying when you're making a map and you can't figure out why your units wont go past a piece of terrain. Common sense really, you should all know the terrain passability settings by now.
Anyway, those are the essentials, now here are a few tricks for extra detail and variety.
Copying and Pasting terrain
Some of you may have tried doing this with the Vanilla TS terrain in order to create some new terrain styles. Obviously in TI, you don't need to copy and paste Paved roads and what-not together to make new terrain as we already have plenty of additional terrain that TS really should of included. Anyway, if you have tried this before, you should try it with some of the TI terrain, mix some things together, you could come up with some excellent results (I recommend experimenting with the Rough Ground and Clear LAT additions sets).
Going Over Other Terrain
This trick is pretty much similar to the above, but not actually using the CnP function. If you've made a large map and don't like repeating the same terrain tile very often, why not go over some with other terrain to create something that looks new? A good example of this would be on the Ditches and Jaggeds set. As repetitive terrain isn't that good and there isn't exactly a huge amount of ditches and jaggeds (and other bits) I like going over particular terrain to either remove bits of it I don't like or just to create the illusion of a separate terrain tile. Like this for example.
This trick doesn't apply to just ditches and jagged tiles, try using it on Rough ground, Cracked dirt (large tiles) etc. and see what you come up with. This doesn't work well on every tile however, make sure while trying this you avoid making any blocky terrain.
Map size
The map size is basically up to you, however you should take care that at least 4 to 5 cells are left outside the playable area which is set via the blue border in FinalSun.
This isn't only useful for trains which you might want to move outside the playable area for a short distance, but also to prevent aircraft getting stuck at the map border. Some aircraft in TI have a quite big turning circle and when they hit the red border, they get stuck there until the player manually orders them back into the map (which he might not be able if he forgot to assign them to a group and hasn't selected them anymore).
Thus the best is, if you even leave up to 10 cells space.
Since I added lighting - both standard and invisible light posts - to my map, it crashes at least three out of five times when I try to start a match there... QUICK_EDIT
Are you sure you didn't accidently place the Cruentus spreader instead of a purple light post? If Cruentus is spread on a slope, the game crashes. _________________
