The time now is Fri Apr 26, 2024 8:14 am
Client Update failed
TheLostSabre
PostPosted: Thu Aug 14, 2014 2:28 am    Post subject:  Client Update failed Reply with quote  Mark this post and the followings unread
Uh oh, I just updated to .31 from .29 and I can't play TI. Getting 'Client Update failed' when the updater was finished. Sad
Specially, TI_Launcher.exe doesn't function after I updated.
PostPosted: Thu Aug 14, 2014 6:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Could you post a screenshot of the issue?
PostPosted: Thu Aug 14, 2014 8:37 am    Post subject: Reply with quote  Mark this post and the followings unread
I have no idea why this would be occuring, I test every update to make sure this doesn't happen, In PB5.030 there seemed to be a problem with the new LOCAL.MIX so I had to fix it in PB5.031 but both updated worked fine.
TheLostSabre
PostPosted: Thu Aug 14, 2014 3:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here you go.
 Filesize:  5.01 MB
 Viewed:  1842 Time(s)
PostPosted: Thu Aug 14, 2014 7:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
TheLostSabre
PostPosted: Thu Aug 14, 2014 8:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
No, it doesn't work.
PostPosted: Thu Aug 14, 2014 11:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
What happens / what error message do you get when you try to run TI_Launcher.exe?
TheLostSabre
PostPosted: Fri Aug 15, 2014 12:45 am    Post subject: Reply with quote  Mark this post and the followings unread
!!! STATUS REPORT !!!
It's my antivirus Avast. Apparently, it was set up in aggressive scan mode and was preventing the updater from running properly. So sorry for causing so much trouble for you guys. Sad
Consider this problem solved.
PostPosted: Fri Aug 15, 2014 8:17 am    Post subject: Reply with quote  Mark this post and the followings unread
It's not trouble, don't worry. It's handy to know these things for when people have troubles in the future (well, if they have troubles). Glad you got it working.
[ Time: 0.1538s ][ Queries: 14 (0.0119s) ][ Debug on ]
