The time now is Sat Apr 27, 2024 1:00 am
FINAL TI map editor question
Lopunny777
PostPosted: Fri Aug 15, 2014 11:39 pm    Post subject:  FINAL TI map editor question Reply with quote  Mark this post and the followings unread
how do i make the map appear after i saved it in the skirmish map folder it wont pop up anywhere?
PostPosted: Fri Aug 15, 2014 11:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Save your file as a .MAP file and place it in the Maps > Custom directory. To save a map as a .MAP file, simply type .MAP at the end of your map name when saving, for example: MYMAP.MAP
Lopunny777
PostPosted: Sat Aug 16, 2014 3:55 am    Post subject: Reply with quote  Mark this post and the followings unread
i did but it hasnt popped up once...that was my first assumption so im out of ideas
Edit: nevermind i fixed it I think it was me..sorry to trouble you. In that case how do i make buildings owned to a player?
Q45
Tiberian Fiend
PostPosted: Sat Aug 16, 2014 8:30 am    Post subject: Reply with quote  Mark this post and the followings unread
You mean buildings that are already on the map when the game starts? That requires a bit of trigger work, nothing too difficult.
Create a new trigger and name it whatever you want, the trigger's house doesn't matter so leave it to GDI. Then give it the event "8 Any Event" to make it run immediately when the game starts. Then add the action "14 Change House...", and in the parameter value select one of the "50 Spawn 1-8" ... "57 Spawn 1-8" options. The first one means the player who spawns at waypoint 0, the second one the player spawning at waypoint 1 and so on up to waypoint 7. Then place your buildings on the map and attach them to this trigger.
If you want to give buildings to more than just one player then you have to make one of these trigger for each player and change the action to match with their starting waypoint.
I don't know how much you know about mapping and triggers, so ask if I wasn't clear enough.
Twisted Insurrection's Lead Campaign Developer
Lopunny777
PostPosted: Tue Aug 26, 2014 5:40 am    Post subject: Reply with quote  Mark this post and the followings unread
i have no knowledge of this editor...i have set up the trigger but i cant seem to make it do it for player 1 in a skirmish...i just wish the editor or the game was on a better engine....would benefit alot from that...ill do that for this game once its done but back to my case it doesnt seem to give control to me
Q45
Tiberian Fiend
PostPosted: Tue Aug 26, 2014 8:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's an example map that shows you how to do it, look at how the triggers are set up. Also double click on the buildings and you see that the triggers are attached to them in the attached tag dropdown.
However, while testing this feature I noticed that the AI players will sell these buildings immediately when they get them.. Rolling Eyes I wonder if the triggers still work with all human players in online games.
example map.map
 Filename:  example map.map
 Filesize:  116.73 KB
 Downloaded:  22 Time(s)
[ Time: 0.1577s ][ Queries: 13 (0.0112s) ][ Debug on ]
