The time now is Sat Apr 27, 2024 12:04 am
Loyalty Map Unplayable ?
adamstrange
Tiberian Fiend
PostPosted: Fri Feb 20, 2015 6:10 am    Post subject:  Loyalty Map Unplayable ? Reply with quote  Mark this post and the followings unread
The loyalty map can't be played because that green gas just continues to destroy everything you place on the map.
As soon as the game starts the MCV has it emitting from the building.
I added a second one to the map and after the first one blew up the gas started coming from the second MCV.
PostPosted: Fri Feb 20, 2015 7:58 am    Post subject: Reply with quote  Mark this post and the followings unread
There is no GAS issue on the public version.
You should know what you're doing when you mod and mess up your TI version. Wink
Please report bugs only concerning the public version, not your modified TI. For that we can no longer give any support.
PostPosted: Fri Feb 20, 2015 8:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Either LKO is correct and you've done some editing that has gone horribly wrong, or you're referring to burst pods exploding? These things only blow up when damaged, so either avoid inflicting damage to them or destroy them before you build your base.
PostPosted: Fri Feb 20, 2015 8:30 am    Post subject: Reply with quote  Mark this post and the followings unread
He said his conyard is emitting the gas and also constantly, so i'm pretty sure it's not the pods which emit gas only once.
PostPosted: Fri Feb 20, 2015 10:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, which sounds absolutely bizarre. #Tongue I'd like to see a screenshot.
[ Time: 0.1525s ][ Queries: 11 (0.0082s) ][ Debug on ]
