The time now is Tue Apr 01, 2025 9:25 pm
Nod Structures
Post new topic   Reply to topic Page 1 of 1 [35 Posts] Mark the topic unread ::  View previous topic :: View next topic
PostPosted: Tue Mar 24, 2015 4:15 pm    Post subject:  Nod Structures Reply with quote  Mark this post and the followings unread
[ Nod Infantry ] - [ Nod Vehicles ] - [ Nod Aircraft ] - [ Nod Structure ] - [ Nod Dawn Units ]
Construction Yard
The Construction Yard is where all life begins. It allows the player to build other structures, so defending it should be a top priority of any successful commander. In some missions, the player starts with an MCV, which can be deployed into a Construction Yard. In other missions, the Construction Yard has already been placed.
  • Cost: N/A
  • Requires: N/A
  • Purpose: Construction
  • Armour: Very Heavy
  • Power Drain: 0
  • Tech Level: N/A
Tiberium Reactor
Nod Tiberium Reactors are the basic source of power for the Brotherhood of Nod in order to keep their bases and outposts up and running at all times. The Tiberium Reactors also double as a Tiberium Silo for additional Tiberium storage.
  • Cost: 400
  • Requires: Construction Yard
  • Purpose: Power Output, Storage
  • Armour: Average
  • Power Output: +100
  • Storage: +60
  • Tech Level: 1
Core Reactor
Nod Core Reactors produce a massive amount of power to be supplied to a base. It does not have the ability to store extra Tiberium like standard Tiberium Reactors, however, due to its greater size and efficiency, Core Reactors generate more than twice as much power as a regular Tiberium Reactor making them valuable strucures. Caution is advised as Core Reactors are known to explode violently once destroyed.
  • Cost: 800
  • Requires: Construction Yard, Tiberium Reactor, RADAR
  • Armour: Average
  • Power Output: +250
  • Tech Level: 7
Hand of Nod
The Hand of Nod is the basic training area for all of the Brotherhoods Infantry. When In control of the hand of Nod, particular infantry can be trained on command.
  • Cost: 500
  • Purpose: Infantry Production
  • Armour: Average
  • Power Drain: -15
  • Tech Level: 1
Nod Tiberium Refinery
The refinery converts the Harvester loads of Tiberium into credits for the player. It also stores a certain amount of Tiberium. Once a refinery is full, silos must be created in order to store excess Tiberium. If there is no available storage capacity at a refinery or silos, excess Tiberium will be lost.
  • Cost: 1900
  • Purpose: Resource Collection
  • Armour: Heavy
  • Storage: +90
  • Power Drain: -30
  • Tech Level: 1
Fist of Nod
Functionally similar to GDI's War Factory, The Fist of Nod is responsible for producing the majority of Nod's armoured combat vehicles. Underneath the surface levels is a large assembly plant, requested units are manufactured here. Once ready the elevator delivers the newly commissioned vehicle to the field.
  • Cost: 2000
  • Requires: Construction Yard, Tiberium Reactor, Tiberium Refinery
  • Purpose: Vehicle Production
  • Armour: Heavy
  • Power Drain: -30
  • Tech Level: 2
RADAR
The Nod RADAR is like a second pair of eyes for Nod Commanders allowing them to view scouted parts of the battlefield, enemy and friendly units on a small computer screen. The Nod RADAR also has the ability to detect enemy subterranean units and stealth units, once the Nod RADAR has detected an enemy, a light will flash on one of it's many antennae in the direction of which the enemy unit is approaching.
  • Cost: 1000
  • Purpose: Support, RADAR
  • Armour: Average
  • Power Drain: -40
  • Tech Level: 3
Repair Bay
Used to repair vehicles and aircraft. A vehicle or aircraft can land on this structure and if enough credits are available, the unit will be fully repaired. Units can be queued onto the pad by bandbox selecting all the units and targeting the service bay.
  • Cost: 800
  • Requires: Construction Yard, Tiberium Reactor, Fist of Nod
  • Armour: Average
  • Purpose: Support
  • Power Drain: -30
  • Tech Level: 6
Helipad
These structures are the primary re-arming point for all of Nod's attack aircraft.
  • Cost: 1000
  • Requires: Construction Yard, RADAR
  • Purpose: Aircraft Production
  • Armour: Average
  • Power Drain: -10
  • Tech Level: 5
Hall of Faith
The Hall of Faith is an advanced Hand of Nod which is where the construction of advanced cyborg technology takes place.
  • Cost: 1750
  • Requires: Construction Yard, RADAR, War Factory
  • Purpose: Cyborg Production
  • Armour: Heavy
  • Power Drain: -30
  • Tech Level: 6
Technology Centre
These structures provide additional technology to Brotherhood Commanders granting them access to more advanced units, infantry and structures.
  • Cost: 2500
  • Purpose: Research
  • Armour: Heavy
  • Power Drain: -100
  • Tech Level: 7
Wraith Production Facility
These large heliports are where all supplies necessary to construct the Brotherhood of Nod's Wraith Bombers are held. Without at least one facility located in a Nod base, construction of the huge bombers is impossible.
  • Cost: 1500
  • Requires: Construction Yard, Helipad, Technology Centre
  • Purpose: Research
  • Armour: Heavy
  • Power Drain: -75
  • Tech Level: 9
Quake Generator
The Quake Generator projects a focused seismic wave causing an earthquake at a point specific location. The force of the wave itself is capable of bring the tallest structure tumbling to the ground. While the side effects of this activity unearths mounds of rock capable of hindering both infantry and vehicles alike. It is unknown how Nod have developed this weapon as none of these devices have been captured intact.
  • Cost: 1750
  • Requires: Construction Yard, Technology Centre
  • Superweapon: Earthquake
  • Purpose: Superweapon Control, Defence
  • Armour: Heavy
  • Power Drain: -100
  • Tech Level: 8
Temple of Nod
The Temple of Nod is an architectonic wonder, a monolithic structure that enemies fear. It functions as a high-class technology research centre, providing plans and equipment needed for highly powered and technologically advanced units and structures. The Temple itself is heavily armoured, capable of withstanding an immense amount of damage. The structure also has a secondary function; it houses a superweapon known as the Apocalypse Missile. Like the name suggests, it can level entire battlefields with one strike.
  • Cost: 2000
  • Superweapon: Apocalypse Missile
  • Power Drain: -200
  • Tech Level: 10
Chain-Link Fence
This basic base defence structure is effective in stopping infantry, however they are easily crushed by large vehicles.
  • Cost: 50
  • Requires: Construction Yard, Hand of Nod
  • Purpose: Defence
  • Armour: Light
  • Power Drain: 0
  • Tech Level: 2
Fortress Walls
This basic base defence structure is effective in stopping both infantry and vehicles. Only certain units can fire over Nod walls.
  • Cost: 100
  • Purpose: Defence
  • Armour: Heavy
  • Power Drain: 0
  • Tech Level: 4
Pavement
Pavement is designed to protect your base from burrowing units as well as prevent heavy weapons fire and explosions from making craters in your base. In addition, units on Pavement will move faster compared to normal terrain. Unlike placing other structures, Pavement can still be placed down when any parts of its placement bib are red. Only the squares that are white at the time will be paved. Pavement can not be placed on slopes or over existing roads
  • Cost: 75
  • Purpose: Defence
  • Armour: Concrete
  • Power Drain: 0
  • Tech Level: 4
Fortress Gates
This structure prevents enemy units and Tiberium growth from entering a base. The gate automatically opens to allow friendly units to pass but will not open for enemy units.
  • Cost: 250
  • Purpose: Defence
  • Armour: Average
  • Power Drain: 0
  • Tech Level: 4
LASER Turret
The LASER is Nod's main base defence, primarily used for anti-infantry purposes. Like its larger cousin, the Obelisk of Light, the LASER fires a focused LASER beam at enemy units.
  • Cost: 500
  • Primary Weapon: Anti-Infantry LASER
  • Purpose: Defence, Anti-Infantry
  • Armour: Average
  • Power Drain: -20
  • Tech Level: 2
SAM Bunker
These powerful anti-aircraft defence structures fire out multiple heat-seeking projectiles at once making short work of most enemy aircraft. Whilst very effective, these Bunkers are a heavy drain on the Brotherhood of Nod's power source and take up more space than any other basic defence structure.
  • Cost: 1250
  • Primary Weapon: Heat-Seeking Missiles
  • Purpose: Defence, Anti-Aircraft
  • Armour: Average
  • Power Drain: -50
  • Tech Level: 5
Obelisk of Light
The Obelisk of Light has been used by Nod for decades. The Obelisk is designed to eliminate any form of ground opposition with great ease using an extremely powerful LASER beam. Due-to the large quantities of power required to keep a single Obelisk of Light on-line, it is not equipped with anti-air weaponry.
  • Cost: 1500
  • Primary Weapon: Anti-Armour LASER
  • Purpose: Defence, Anti-Armour
  • Armour: Heavy
  • Power Drain: -100
  • Tech Level: 8
Web Spider
Designed for the purpose of lightning fast base protection, Web Spiders are capable of deploying energy beams extremely dangerous to all forms of infantry and vehicles making them completely impassible. Alongside their mobility attributes, Web Spiders are able to travel underground in order to reach their appointed destinations at a much faster pace. In order for a Web Spider to function correctly, there must be a minimum of two deployed parallel to each other at all times.
  • Cost: 750
  • Primary Weapon: LASER Turret
  • Primary Ability: LASER Fence
  • Purpose: Defence, Sneak Attack
  • Armour: Average
  • Power Drain: 0
  • Tech Level: 7
Stealth Generator
The Stealth Generator can cloak all units and structures in a large area. The base will remain cloaked until the stealth generator is turned off, the base becomes underpowered or the stealth generator is destroyed. Base defences and units under the effect will uncloak only when firing or leaving the area of effect. It should be noted that units exiting from a War Factory or Hand of Nod and Harvesters exiting a refinery will be visible briefly before the stealth generator adjusts and cloaks them.
  • Cost: 1500
  • Purpose: Defence
  • Armour: Average
  • Power Drain: -350
  • Tech Level: 9
DoMiNaNt_HuNtEr
PostPosted: Wed Mar 25, 2015 2:33 am    Post subject: Reply with quote  Mark this post and the followings unread
I gotta say the web spiders are like the coolest thing ever. To travel with the mobile base, its ztyping PERFECT! Now the only thing would be to get the fence section able to open/close for friendlies like a gate in YR, so that factories/refs can get protected from engies, but our guys can still access them.
Is this possible? Is anything possible?
IN-GAME NAME: MAKINTOKE
PostPosted: Mon Jun 08, 2015 1:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
All the animated ingame previews are gone?
This as overview with links to the original separate topics would've been better imo. Also to allow discussions for a certain object only.
PostPosted: Mon Jun 08, 2015 4:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't think every building or unit needs its own topic. I hate to say it but I don't see an abundance of discussion anyway.
Speeder
PostPosted: Mon Jun 08, 2015 5:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
What's the point of this anyway, if there's a nice website with all the information included in it?
mentalomega.com
PostPosted: Mon Jun 08, 2015 7:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
A forum topic is where things can be discussed, there is no discussion board on the website. #Tongue
PostPosted: Fri Apr 01, 2016 6:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
PostPosted: Tue Oct 25, 2016 7:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tiberium Reactor and Laser Turret updated with new images of their new graphics by Lin Kuei Ominae. Check them out! We've also given the Web Spider a facelift too. Smile
PostPosted: Tue Oct 25, 2016 8:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just as I was posting that, LKO shared another new Nod Structure amongst the staff group, check out his new Nod Stealth Generator. Smile
The structure stats will be updated to compensate for the smaller foundation)
Damfoos
PostPosted: Tue Oct 25, 2016 10:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Glad to see that LKO have finally found enough motivation to continue with Nod buildings, I hope the set will be completed one day and it will not take another several years long break to happen.
Nice approach to Laser Turret design btw, looks very stylish. And the rotating core of the Stealth Generator is a nice and interesting touch.
PostPosted: Thu Oct 27, 2016 3:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
LKO completed the new Nod Tiberium Refinery image yesterday too. Smile
PostPosted: Thu Oct 27, 2016 3:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
damn, just thought there are bad bright pixel on the tower (e.g. due to a changed palette on your side), until i noticed that's the smoke of the damage smoke anim. Face palm!
Anderwin
PostPosted: Thu Oct 27, 2016 11:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
haha L!
Anyway good work on the refinery!
Can you hide from me Wink?
PussyPus
PostPosted: Fri Oct 28, 2016 3:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
The repair bay model is an old one, Except for the other, And will we be able play as globotech in the future?
If you are a MetalHead (Heavy Metal Fan) and don't want to be a metalhead, Just remove your metal ball from your head. �:p .
View user's profile Send private message ModDB Profile ID Skype Account
PostPosted: Sat Oct 29, 2016 1:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
This must be the apocalypse, LKO is actually doing stuff and not bragging. I am genuinely impressed.
It's good job, but I never expected these getting done at all.
Stygs
Cyborg Cannon
PostPosted: Sun Oct 30, 2016 9:34 am    Post subject: Reply with quote  Mark this post and the followings unread
The red parts seem to be a lot darker compared to previous structures, but otherwise it looks great Smile
ICQ Number
PostPosted: Sun Oct 30, 2016 10:03 am    Post subject: Reply with quote  Mark this post and the followings unread
The PP and Ref have in addition to small glowing remap stripes also non-glowing normal remap on the structure, while all other structues have glowing remap stripes only, but these bigger and more prominent.
The idea was to make these low-tech buildings a little less remap flashy.
PostPosted: Sun Oct 30, 2016 6:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
New structure added to the Nod arsenal by LKO:
Core Reactor
Here's a glimpse at what the in-game animations look like:
This structure went under a few changes while it was being produced in the staff forum, which is why the stuff in the cooling towers is now a red glow instead of green goo, though the green has been kept for other uses.
Keeper
Cyborg Engineer
PostPosted: Mon Oct 31, 2016 1:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
I get the feeling that destroying one of those things is going to create quite the explosion.
ErastusMercy
PostPosted: Mon Oct 31, 2016 5:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Demo
PostPosted: Tue Nov 29, 2016 2:28 pm    Post subject: The Nod Laser Turret Reply with quote  Mark this post and the followings unread
First of all, I'd like to praise the designer of the Nod buildings. It's a feat few people could've finished successfully. A lot of buildings give the typical "Nod" feeling when taking a glance at it.
However, I want to talk about the new Nod Laser turret, which doesn't appeal to me at all. Don't get me wrong, designing a new look takes effort and we all appreciate the work. But the turret doesn't resemble anything Nod stands for.
Take a look at the turrets Nod used in the original C&C games:
http://vignette3.wikia.nocookie.net/cnc/images/5/53/CNCTW_Laser_Turret_Cameo.png/revision/latest?cb=20131129012731
http://vignette2.wikia.nocookie.net/cnc/images/e/ea/Viper_Turret.jpg/revision/latest/scale-to-width-down/250?cb=20130118022322
Most of these smaller turrets look extremely different to the Nod turret in this mod; they would employ barrels and look way more conventional. I might be wrong on this, and perhaps legitimate reasons are used for the design of the turret. If so, could you explain to me what are the key reasons the turret looks so differently and "(un)Nod-ish" according to your opinion?
It just bothers me how the turret is looking more Ordos than Nod  Very Happy
http://dune2k.com/Images/Duniverse/Games/Emperor/Structures/Ordos/O-PopupTurret-Big.jpg
(If you get an error page the first time, just press retry, and you'll be correctly directed.)
Nevertheless, again, I'd like to stress that this is meant as constructive criticism, most of the redesigns are extremely nicely pulled off! Kudos.
(It seems most of the pictures didn't show as I have would liked, however the links are probably still functional and would direct you to the pictures I meant.)
The dictator you would vote for.
PostPosted: Tue Nov 29, 2016 2:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
basically my thoughts were like this
-not the 100th reincarnation of the same design again
-something organic, almost creepy
-no long, thin barrel and very fine details which cause many pixel holes when rendering and ugly visual bugs when firing up/down cliffs where the barrel can't tilt, yet the laser is going with a sharp bend up/down at the barrel end
-a bigger design, allowing me to add the typical glowing stripes animation
-i like the turrican boss monster, which this was based on
ArchlordII
PostPosted: Tue Nov 29, 2016 11:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
I, for one, really like the new laser turret. It looks kinda like a flying saucer/banshee.
Peace through overwhelming POWER!
PostPosted: Tue Nov 29, 2016 11:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
It just occurred to me that images here are outdated, I will fix that shortly.
ArchlordII
PostPosted: Tue Nov 29, 2016 11:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Which images?
PostPosted: Tue Nov 29, 2016 11:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Banshee Pad and Repair Bay.
Vulture
PostPosted: Wed Nov 30, 2016 8:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Does that mean all Nod buildings, with the exception of the Construction Yard, are completed?
Edit: No. The Seismic Projector uses a placeholder still as well.
Tales of War
PussyPus
PostPosted: Wed Nov 30, 2016 2:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
When all these missing images be gone? After updating their artwork? (seismic projector and conyard for Nod, repair bay and orca helipad for GDI)
I hope the new update contains the following:
-New playable 4th faction
-Globotech gets available on skirmish with 14 other new missions
-New artworks for the following: GDI repair bay (make its design as a GDI eagle inside circle), Nod seismic projector, GDI orca helipad, GDI uplink tower. GDI firestorm generator, firestorm wall sections, And all official globotech buildings (fusion reactor, barracks, tiberium monitoring center, warehouse, radar array, unity tower, research tower, scientific facility/research lab,cityprotection wall, sentry gun, batteries, artillery, conoutpost, armory, and a new superweapon for them)
And i think Mod DB site was down for some minutes.
PostPosted: Wed Nov 30, 2016 8:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
There we go, images updated. Only two more Nod structures left. Very Happy
PussyPus
PostPosted: Wed Nov 30, 2016 10:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Seems Globotech has a harvester too, I think it's going to be used when globotech be available on skirmish with 14 other missions.
Vulture
PostPosted: Sun Dec 11, 2016 4:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hm... I have a question (not directly related to Nod buildings, but considering LKOs Refinery was the last uploaded building, I ask it here).
What are the dimensions (X meters × X meters) of a tile?
In other words: How big are the buildings, actually?
Tales of War
PostPosted: Sun Dec 11, 2016 6:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
this is pretty hard to tell.
Especially since some buildings had to be done a tad smaller/bigger and not using a consistent scale, to make everything fit into the rather small space.
But for my buildings a tile is about 15 meter x 15 meter.
-The Core Reactor is about 26m high (the peak of the thin center tower). The diameter of the open tower top (from one of the 3 reactor towers) about 11m, the diameter on ground about 30m (the 3 towers intersecting on ground)
-The refinery docking area having the roof at about 11m height.
The turntable on the ground having a diameter of about 18m.
One of the small silos having a diameter of 5.6m (which is the height from ground to top, since they lay down 90° rotated), the length about 9m
Attached an image showing a human dummy (in front of the south entrance), which i used as reference on many buildings. A biped which represents a human of about 1.8m height.
This scaling would be consistent for most buildings, but the temple for example would be probably 150% the size in reality, as the center door on the SE side would probably have a height of about 8 meter in reality and not only 5.5m.
Though don't even try to scale units according to these numbers. Wink
 Filesize:  1020.22 KB
 Viewed:  32377 Time(s)
Vulture
PostPosted: Sun Dec 11, 2016 9:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice, thanks!
The faction buildings seem pretty consistent compared to each other. The biggest throwoff for me what made an accurate guess so hard were the civilian structures, but now I think of it, quite a few of them are still from Tiberian Sun, aren't they?
PostPosted: Sun Dec 11, 2016 9:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
In that regard i tried to stay close to the civil buildings scale.
In TS, 8 pixel in height equal roughly 2 to 2.5 meter (because usually one floor on a civil building is about 8 pixel high) and i tried to stay close to that with my buildings too.
Vulture
PostPosted: Sun Dec 11, 2016 9:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
I see, thanks Smile
I have been checking things in the map editor - with the buildings obviously cluttered together for a better sense of scale - and it is indeed less out of whack as it sometimes looks like, with the exception of the Village set.
Special mention for the Farm House.
Edit: I think the Village set is also less bad as it seems, it's just due to the way the buildings are positioned on the tiles that the buildings feel a bit out of scale.
Farm House still makes no sense, though. Seriously, how big is that thing...
Tales of War
[ Time: 0.3227s ][ Queries: 14 (0.0114s) ][ Debug on ]
